Question about Frigidaire Ovens
I have an older model Frigidaire electrical range and after pulling it apart, I still cannot find the model # to get further assistance. Any ideas?
    Problem Solver:
  • 13 Answers
My understanding is that the industry standard is for mfg,s to place nameplate info on the frame of the drawer opening, below the oven, on the left hand side. You may have to crouch down to see it, it may be obscured by the oven door. They put it there because it is below the hottest surfacesof the oven, and a service tech can read it without pulling the unit away from the wall. Good luck! Rob
Posted on Jan 01, 2011
To check sensor harness between EOC &sensor probe what do i set the ohms meter at
Hello Jim, I appreciate your post!
Based off the information you have provided you would like to know the where to set the ohms meter to check the sensor and EOC (electronic oven control) on your Frigidaire oven. In order to research this information further I would need to have your model number. You can locate your model number on a wall oven on the inside left hand wall or the door frame. If this is a range you would need to pull out the bottom drawer and it is located on the door frame. Once I have that information I would be able to assist you further. -Matt
Jan 13, 2016 | Frigidaire Ovens
The oven door lock is stuck. I can't close the door. How do I release the lock? model #FEF369CGSa
Hey Susan, thank you for your inquiry!
Based off the information you have provided the oven door on your Frigidaire range is locked and will not close. You can press and hold the cancel button down for at least 15 seconds. If that does not work, you can perform a reset on your range by disconnecting the power from it for at least ten minutes. If you continue to experience issues with the range please comment back. I would be happy to assist you further. -Matt
Dec 26, 2015 | Frigidaire 30" Self-Cleaning Freestanding...
Gibson stove model CEc4S8DX/B how do I turn oven on to bake?
Good Morning Trudy, thank you for your inquiry! Being that it is a 1994 unit (nearly two decades old); Frigidaire no longer has information available. That being said, we do know that the unit is an electric range, so it would be safe to assume the unit would have similar instructions of some of Frigidaire rated ranges. Since many Frigidaire ranges today are built more energy efficient, it may be a good idea to check some of the newly-rated models to get the best value for your hard-earned dollars.
Aug 02, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire fault code F3
Within my research I was able to locate code "F3" which indicates a possible error with the oven probe. It is recommended that a Service Specialist assist you with further diagnosing the issues.
Jan 05, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Oven light sockit for cmef377cisi electric range
Hello Muhammad Alvi - What exactly is the problem you are experiencing? With this information I can assist you further with the issue the range is having or any part information you are requesting.
Dec 16, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Replace oven door handle
Hi blah_blah894 - Are you trying to replace the oven door handle or need part number? If so, I would like to further assist you but in order to do so; do you happen to have the exact model number?
Sep 27, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
My kenmore model 970(frigidaire) electric range displays F10 fault when i use the oven shutting down the oven and beeping. Help me please
Hi
Thanks for using FixYa. F10 error indicates that the Electronic Range control (ERC) has gone bad and should be replaced. However, before replacing it you can take the screws out and then blow some air with the help of hair dryer so that if there is any moisture it blows it off. If still the issue is not resolved then replaced the ERC. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 22, 2010 | Frigidaire Ovens
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Older Frigidaire electyri-clean range Model REG 533 * HD
I wish I had a solution for you...unfortunately I don't. However, if you know anywhere I might find a thermostat knob for this model I would be eternally grateful. I've been searching for 2 years for my mother. It's the knob with 5 settings (off, bake, broil, time-bake and clean).
Jun 08, 2010 | Frigidaire Ovens
Older Ceramatop GM Frigidaire oven stopped working-stovetop works
If it has a timer of any description, make sure it is set to manual, refer to your instruction book.
Dec 10, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Ovens Logo
41 people viewed this question
Top Frigidaire Ovens Experts
Oloyede Monsuru
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
