Question about Hampton Technologies Brinks Timer
I bought brinks ez dial mini timer, have set it several times and it will not come on.I pluged it up to my coffee pot which does not have a timer, thought this would be easier than bying a new coffee pot.
  • Anonymous Mar 25, 2014
    Am wanting to set the timer to be on M - F. Off on Saturday and Sunday. How do i set the timer. Can i get a manual for this timer?
    Thanks !
Smart thinking using wall timer instead of buying new coffee pot.
I'll remember that tip.
I test timers.
A lot of timers arrive defective, and other stop working short while later.
Some last for many years.
On your timer, make sure slide switch is pushed all the way over to TIMER or TIMER ON.
Plug regular lamp into timer, turn lamp ON, and manually rotate timer dial clockwise to see if timer trippers will turn lamp ON-and-OFF.
If timer functions with manual rotation, then see if dial rotates on it's own.
The dial should rotate, or else timer is defective.
If dial rotates, and timer works for lamp, then double check that your coffee pot is ON at all times.
The timer just opens the circuit to coffee pot, but coffee pot has to be ON.
Also take advantage of fixya phone support for any type of problem.
For a price, fixya expert talks to you over phone to resolve repair issues.
Posted on Jan 01, 2011
    Sergeant:
    Champion:
  • 226 Answers
Did you trun the coffee pot on went pluged it in it got to be on.
Let me know if this help
Posted on Dec 31, 2010
Where are the tabs on a brinks mini timer 42-1oo6
try pressing in on the outer ring on individual tabs around the dial.
Oct 22, 2014 | Hardware & Accessories
Setting brinks ez 42-1006 timer
1) Copy following link:
http://waterheatertimer.org/How-to-set-timers.html
2) Use link above to Experiment with features
Dec 14, 2012 | Hampton Technologies Brinks Timer
Brinks 42-1009 ez vacation timer instructions
The Brinks 42-1009 EZ Vacation Timer is preset with 7 full days. You cannot choose when it goes on and off.
To set, spin the dial (clockwise only) until the arrow in the upper right of the center face is near the current day and time. Plug everything in and switch the upper tab to the right. On certain days, it will turn on in the early morning as well as evening or late night.
You cannot choose when to turn the light off. However, if you are home, you can turn the light on by switching the upper tab to the left. Remember to switch it back to the right in order to activate the timed on/off periods.
Jun 10, 2012 | Hampton Technologies Brinks Timer
Got a brinks EZ- dial timer model42-1034B @ Walmart a few days ago can not seem to get it to work, Inst, seem so easy too. I read on some forum online someone thought the am/pm may be backwards to how it...
1) This Brinks timer is a bit lightweight for an appliance (unless for coffeemaker or tiny gerbil-feeding motor)
You might need 1/3 HP (horsepower) appliance timer like Woods 59201
http://waterheatertimer.org/Woods-timers-and-manuals.html#59201
http://www.amazon.com/Woods-59201-Appliance-Grounded-3-Prong/dp/B001Q9EFTQ
Intermatic HB113C is for heavier appliances
http://www.amazon.com/Intermatic-Hb113c/dp/B000GHKO6C
http://waterheatertimer.org/images/Intermatic-HB114C-plug-in-4.jpg
2) How to set the Brinks:
I will use lamp as example since you can easily test the timer using a lamp.
Turn lamp ON. Make sure bulb is good.
Leave lamp turned ON and plug lamp into timer.
Move slide switch one direction.
Plug timer into outlet.
Manually rotate timer dial clockwise and see if lamp turns on-off
Move slide switch other direction, and rotate dial clockwise again to see if lamp turns on-off.
Now you know which way switch has to be moved.
Push down trippers and rotate around dial until they line up with 1:00 on dark part of dial and 5:00 on dark part of dial. Dark is for pm hours.
Last step: Set current time: rotate dial clockwise until current time lines up with arrowhead located on inner dial
Dial rotates at time passes, trippers push lever that turns circuit on-off.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 29, 2011 | Hampton Technologies Brinks Timer
Please assist me in setting this light timer. brinks-42-1020
Instructions for Brinks 42-1020
1) There are plastic segments located around outer edge of timer dial.
These segments divide each hour into 15 minute periods.
Push segments down like a piano key for all hours you want timer ON-or-OFF
2) Push switch to Auto ON -or- Timer
3) Turn lamp ON, make sure bulb is working, plug lamp into timer.
4) Plug timer into wall.
Manually rotate timer dial clockwise to observe light turning on-off.
This action will say if light is ON when segments are up or down.
5) Unplug timer, and set segments for times you want lamp to turn on-off.
6) Rotate timer dial clockwise until current time lines up with arrowhead located on inner dial
7) Plug timer back into outlet. Dial rotates as time passes, segments click a switch that turns lamp on-and-off.
Add a comment for more free help, or to further clarify this free answer.
For a price, fixya expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 11, 2011 | Hampton Technologies Brinks Timer
How do i set the Brinks 44-1040 timer?
Brinks 44-1040 is a 24-hour plug-in timer, with 1 on tripper and 1 off tripper.
Dial has 24 hours with each hour marked for am and pm times.
Push tripper down and rotate until tripper aligns with time you want for ON and OFF.
Rotate dial until current time lines up with arrowhead located on inner dial.
Plug lamp into timer. and plug timer into wall.
Move slide switch one direction or the other to control mode.
When switch is one direction, lamp in ON all the time.
Move switch other direction, and timer programs work.
Dial rotates as time passes, and trippers move on-off lever that turns lamp ON-and-OFF.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 24, 2010 | Hampton Technologies Brinks Timer
The coffee maker is not making a full pot of coffee
hi..
the model may have a digital timer that is accessed using the panel swithes get the number for wilbur curtis from thier web site they will talk you through it {simple} the other style timer is a potentiometer type... To adjust first unplug brewer, look behind either the front panel or top cover for a dial with numbers around it. turn the dial down slightly brew a pot of water see where the water level comes keep turning down till desired level is reached...
thank u
rate me!!
Aug 14, 2009 | Wilbur Curtis Alpha G3 Concourse...
Hampton Technologies Brinks Timer Logo
1,385 people viewed this question
Top Hampton Technologies Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hampton Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
