Question about Xerox DOCUMATE 510 Flatbed Scanner
My problem is the feeder does not feed right with multiple pages, only when I feed one at a time. It keeps stopping when the previous page is not all the way through and the next page is started. It just stops without continuing. I thought I had to replace the ADF pad; but, it still keeps doing it; so, I put the first ADF pad back in. Now, I am stumped. I have not even used this that much until recently. Nothing lasts these days. Can you help me diagnose the issue? I appreciate your time and support.
3 Suggested Answers
  • 2072 Answers
SOURCE: ADF Won't Feed the Paper
If those rollers are turning, and not feeding even after cleaning they simply need replaced. they can get so slick that no ammount of cleaning will help.
Thats what is sounds like.
Like trying to drive a car on ice. No traction.
Posted on Jan 25, 2008
SOURCE: I want to find replacement parts for the ADF
Hi, I don't know if it's permissible to advertise but we currently sell the assembly for the Xerox Documate scanners. As far as I know the scanner's discontinued, and the pads are getting pricey so consider how much longer you want to wait before replacing the scanner.
sales at sprucecomputer dot co dot uk if anyone is desperate
Posted on Feb 16, 2010
What is adf
Hello!
An automatic document feeder or ADF is a feature which takes several pages and feeds the paper one page at a time into a scanner or copier, allowing the user to scan, and thereby copy, print, or fax, multiple-page documents without having to manually replace each page.
Aug 15, 2017 | Office Equipment & Supplies
Auto Document Feeder
Make sure the paper is not damp, make sure the paper is not sticking together around the edges. Adjust the paper guides.
Dec 14, 2015 | Canon PIXMA Office Equipment & Supplies
The document feeder keeps feeding multiple pages. How can this be resolved?
This is a common problem with most feeders. The pick up is by two rollers trying to judge the thickness of paper to collect each time, and with differing thicknesses and gloss covering it often cannot get it right. If it happens with new paper direct from a package try turning the paper over as all paper has a direction to feed but it is not marked on the pack!!!! To completely cure the problem you will have to buy an air lift feeder that suctions each sheet individually. A bit dearer though.
Apr 11, 2012 | Samsung SCX4828FN AllInOne Laser Printer
HP 3050 All-in-One printer feeder problem - followup ?
under scanning tools / settings check for double feed detection (enabled / disabled ) if not found, for feeder side replace pad assembly the one that hold paper to double feed.
Mar 23, 2010 | HP LaserJet 3050 All-In-One Printer
Laserjet 3015 will not fax more than one page a time
Open up the document feeder and clean the roller and pad with alcohol.
Jun 08, 2009 | HP LaserJet 3015 All-In-One Printer
MULTIPLE FEED PROBLEM
There is a little with pad that is called the seperation pad. You can see this under the pick up rollers. Clean this off with some alchohol. It may fix the problem. If not a new pad is needed.
Speration pad needs cleaned or replaced. Its a $10.00 part.
Jan 09, 2009 | Canon PC1061 Copier
Document feeder
Am not sure but,it looks like problem with static charge building creating the problem.See that the document path grounding is ok
Oct 25, 2008 | Office Equipment & Supplies
Faxing multiple pages
reinstall the printer software. deleted the existing printer software first.
Sep 13, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Jan 04, 2008 | HP OfficeJet 6210 All-In-One InkJet...
The document feeder keeps trying to feed
You have a bad Document transfer sensor. Sensor is located under the doc. transfer roller.
Nov 15, 2006 | Sharp FO 6600 Plain Paper Laser Fax
Xerox DOCUMATE 510 Flatbed Scanner Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
