Question about Samsung SHS222L DVD+R Burner
Drawer opens halfway and has to be pulled open far enough to insert disk. Sometimes opens all the way --- baffling.
  • Samsung Master
  • 27,725 Answers
Make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Posted on Jan 01, 2011
How to manually open eject Crosley CR248 CD drawer
Look at the front of the tray for a small pin hole. Open up a paperclip with pliers so that it is nice and straight. Insert it into the pin hole and push firmly. The tray will pop open enough to be able to pull the drawer manually.
Nov 10, 2015 | Crosley Audio Players & Recorders
My drive wont open.i just get a flashing greenlight when i plug in the unit.
With the unit unplugged, there is a small hole on the front plate. Take a straightened out paperclip and insert it into the hole. push FIRMLY but not too far, and the drawer should pop open about a half inch or so. You will be able to pull it open far enough to remove any disc that may be inside. The disc could be the problem, as drives will hang when trying to read a corrupt disc. I hope this helps.
Oct 08, 2013 | QPS Que! USB 2.0 Drive CD-RW Burner
Disk drawer will not open
Did you tried with a crowbar? It's a joke.
You can use a paperclip. Normally you have a litlle hole below the drawer, when you unfold your paperclip, you can then insert them in the hole and open your drawer.
Aug 07, 2012 | Computers & Internet
Can't open the second cd rom drawer
Does the light flash when you press the button? If so, was there a disk in the drive previously? There is a small hole on the front of the unit. With power off, get a paper clip and open it up halfway. Push the open end into this hole and the drawer should pop open by about half an inch. This will be enough for you to gently pull the drive open and remove anything stuck inside. Ian.
Sep 27, 2009 | E-Machines T3256 PC Desktop
The eject button on my VRDMC5 DVD recorder does not work at all.
When idsk is not recognized it is because the laser mechanism can no longer focus on the disk. If this happens with all disks then the unit is fubar and it is time to go shopping since repair is not cost effective.
Apr 24, 2017 | Sony VRD-MC5 DVD Recorder
Sony DVD RW DRU-820A
HI,
Double check the Ribbon Cable Connector is installed Correctly ( 40-80 Strand IDE ) sometimes if these are not fitted squarely Or pushed in hard enough. Can cause a Problem.
Also try the emergency eject procedure on The Drive. Small jewellers screwdriver Or Needle, insert into the drives faceplate ( pinhole in drives faceplate drawer ) push to open dvd drawer. pull out drawer Gently. And push back in. This ocassionally works for a stcking Drawer/eject mechanism.
Finally try the drive without a disk in ( open/eject Or Close )
Mike @ Compurepair.
Jul 01, 2008 | Sony DRU-820A DVD RW Dual Layer Burner
Hello, Bosch Classixx fridge freezer warms up in fridge compartment, freezer seems OK. Is it just icing up, & I could switch it off for 48 hours? Or what to do? Thanks.
A defrost is more than likely necessary. Shut it off at the control and open the door. Also the little drawer or pan under the freezer compartment sometimes will have a baffle that can be raised or lowered to provide more or less air circulation. For a cooler refrigerator you would open the baffle, and for a warmer refrigerator temperature you would close the baffle for less air and warmer temperature.
May 05, 2008 | Refrigerators
Samsung SHS222L DVD+R Burner Logo
46 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
