Question about Epson TM-U220 Matrix Printer
We have a error message on our epson model M188B. We have gone through all the possible solutions. We even checked to make sure the switches below are on the correct setting. It has a new ribbon, it's completely free of all dust. What could our problem be? We've even changed out printers and are still receiving the same error message.
punker0204
  • 54 Answers
SOURCE: Epson C66 won't print without color cartidges
epson printers won't really print if one cartridge is not detected or detected as empty. the only option that i can suggest to you is that, buy a continous ink kit at any ink refilling station in your place. i highly recommend that dont leave a cartridge empty with ink cause it might clog your printhead. using a continous ink system's cartridge is auto reset, whenever the printer says that the cartridge is empty, it will automatically resets itself. ink refill kit comes with 100+ml of ink per color i think. and it is much cheaper using original epson ink.
Posted on Sep 26, 2007
  • 110 Answers
SOURCE: Printer won't respond
1. Open START, SETTINGS, CONTROL PANEL, PRINTERS
2. Right click on your Epson printer name, and click CANCEL ALL DOCUMENTS.
3. Confirm cancelling all documents.
4. Right click on the Printer again, and select DELETE.
1) Click on START, SETTINGS and CONTROL PANEL.
2) Double click on the SYSTEM folder and select the Device Manager tab.
3) Click on the "+" for "Universal Serial Bus Controller"
4) Right click on "USB Printing Support" and select "Uninstall" and confirm it
5) Disconnect the USB cable and reconnect it.
Try Printing
Posted on Aug 22, 2008
SOURCE: Epson stylus photo R300 cd/dvd tray not set correctly
I had the same problem. Restarted the printer. Reinstalled the drivers. Scratched my head ... nothing! then I moved the printer away from the wall - problem solved! I can't say that this will work for you but if everything else is working, as it was and still is on mine then it's worth a try.
What I didn't realsie was that the cd tray comes out of the back of the printer when it's checking the alignment. I had inadvertantly pushed the printer back, too close to the wall. Moved it forward slightly and it's fixed.
Hope that solves it for everyone.
Posted on Feb 27, 2009
  • 28 Answers
SOURCE: Installed new OEM Epson ink cartridges, get error message 2. Cartridges are installed correctly and tested ok. Chip problem? Print head problem? Cartridge problem?
Go to printers and faxes, and uninstall the printer.
reboot, this should solve the problem
Posted on Apr 14, 2009
venexcsd
  • 1185 Answers
SOURCE: i have deleted my software for my epson printer
go to www.epsom.com/support and download it
Posted on Jan 02, 2010
0x95 error
Epson Printer Error 0x95 occurs when the printer head is saturated,i.e; cleaned. Error may be due to installation or uninstallation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Steps to Fix Error 0x97 in Epson Printer:
Solution 1: - Check Epson Printer Ink Head
Check Epson Printer Ink head. Generally, Printer ink is dirty meanwhile it is inked up properly because the ink pad is full. Often due to unbalance ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
If this step is not working to fix Error Code 0x95, then go to next step.
Solution 2: - Manually Perform Steps with Epson Printer
  • Try to switch on your Epson printer.
  • Then "press+hold" together to stop ink power buttons.
  • Wait for sometimes while the printer switches self OFF.
  • Next switch back ON and your error should have gone.
Solution 3: - Run the System Under Safe Mode
You should try to run the computer under safe mode, and then you may receive a message from the system about whether your error existence effectively solved.
Solution 4: - Uninstall Current Installed Software From System
  • On your Windows "Start" button, go to "Programs and Features".
  • In the "Control Panel", tap "Programs", and then tap "Programs and Features".
  • Choose that software program that you have just installed, and then tap on "Uninstall" button.
You can visit Epson Printer Support Number if you are still unable to resolve the Error.
Apr 01, 2014 | Epson B510DN InkJet Printer
Epson B- 510 DN printer error printer restart 0x95 error
Epson Printer Error 0x95 occurs when the printer head has gone empty or you can say that it has become completely saturated. The reason for this Error may be issues in installation of windows, update of application of Windows, etc. Follow these steps to resolve the Error.
Printer ink becomes dirty because the ink pad is full. Due to unbalanced ink it generates the problem or displays a message of Error Code 0x95. Unplug the printer completely and leave it for a while. Then users must need to remove and replace the sponge and clean the eye.
  • Switch on your Epson printer.
  • "press+hold" together to stop ink power buttons.
  • Wait for sometime while the printer switches self OFF.
  • Switch ON again and your error should have gone.
You should try to run the computer under safe mode, and then you may receive a message from the system about your error existence is effectively solved or not.
Jan 24, 2014 | Office Equipment & Supplies
I need driver for Epson TM-U220PB (Windows xp..) user port USB
You can download the Epson printer drivers from theirsupport WEB site. Please click on this link and select your model printer todownload :-http://www.epson.com/cgi-bin/Store/jsp/index.do?BV_UseBVCookie=yes
May 28, 2011 | Epson TM-U220PB Matrix Printer
Epson m188b paper
the choice is yours
http://search-manual-online.com/epson-u220-printer-manual-manual.html
http://www.pdfone.com/related/tm-u220-thermal.html
if this is good for then its good for me, please vote me
Mar 25, 2010 | Epson TM-U220PB Matrix Printer
M188B Model will only print when turned off then back on.
you should check all connection
change IF Board
or main board
Oct 27, 2009 | Epson Office Equipment & Supplies
Epson Stylus CX7400 won't print
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Epson Stylus CX9400 Photo Printer
Epson stylus CX3200
We know that having a printer serviced/fixed costs more than buying a new one, check out this link http://www.epson.com/loyalty .
Jan 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson r300 printer
step1..............switch on
step2............press+hold stop,ink,power buttons untill printer switches self of
step3............switch back on and problems should have gone
Aug 21, 2007 | Epson Stylus Photo R300 InkJet Printer
Epson TM-U220 Matrix Printer Logo
269 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
