Question about Philips 50PFP5332D 50 in. Plasma Television
Turned TV on. The TV has sound but no picture. Tried re-setting TV by unplugging and plugging it in again; still same problem.
    Master:
  • 691 Answers
Use a flashlight 2 in from screen see if theres a picture, if not then it could be your t-conn board this board is center top and most times behind a metal plate, if bad you should not see menu either. If you have menu then it could be inverter.
Posted on Jan 01, 2011
Toshiba HD ready TV ct 90158 makes high pitched sound
A high pitch sound can be a capacitor losing power it would sound a bit like a fire work. most have back up on the board but it put more pressure on them the more times you use the tv. would check them and replace. all of them can be 5 in a row in some models.
Oct 23, 2013 | Toshiba Televison & Video
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
Aug 23, 2013 | Televison & Video
My Avis flat screen HD TV has sound but no picture.
First thing to try is if using a box for signal unplug both that and the set from power for several minutes and then plug back, it is possible the issue will be gone and the set working normal again.
Dec 05, 2012 | Televison & Video
Sony rear proj tv, no picture, menu appears, but in three seperated colors pin cushioned.
Best to first if you have not done so---UNPLUG the set for several minutes and plug back to power to see if that fixes it (it does a lot of the time especially if you had a power outage).
Nov 30, 2012 | Sony Televison & Video
Only get please wait after turning on tv
Unplug the set and a box if used--wait for several minutes and plug both back to see if they will reboot.
Apr 08, 2012 | Televison & Video
Same Thing Here
if your within 1yr, you can get a lamp replacement from mitsuparts.com or calling mitsu... make sure that you can get a redlight under the lamp and you already reset the TV.
Sep 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
I have a Philips Plasma tv 42pf5321d/37 with sound but no picture
Thats the great sound of Exploding capacitors on either the power supply board. or another one in there. Now the set is in fault protection. It tried to warn you with the RED blinking LED that there was something amiss by shutting itself down. When you unplugged you reset the error and allowed it to do it again.
Best Regards and Smper Fi
Jun 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
Television has sound but no picture
Check the cables first that connect to your video device, are they in tightly?  Test the cables on another TV to make sure they haven't gone bad, which is common.  Also check the input selection on the TV to make sure it matches with the video input the cable is connected to.
Dec 06, 2008 | Philips 50PFP5332D 50 in. Plasma...
TV Turned itself off, and won't turn on...makes a chirping noise
try to check the menu your the timer is on.if not resolder the main board of your tv.
Oct 18, 2007 | LG 30FZ4D TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Philips 50PFP5332D 50 in. Plasma Television Logo
26 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
