Question about Polaris Pb4 - 60 Booster Pump
Ran my pb4-60 dry. now it is noisey and leaks. I am aware that I burn't it up, my question is should I replace the whole thing or can I just purchace the pump (wet end) or try to rebuild the pump? I cannot seem to find the complete wet end without buying the entire pump.
    Scholar:
  • 78 Answers
If the leak is around the shaft by the pump housing you might try changing the seal. I belive they make a seal/impellar kit..
Posted on Jan 01, 2011
Propane smell with pilot on and burner ring/thermostat off. Pilot off no smell. Pilot light is good, burner ring burns cleanly. Logs correctly placed. No line leaks. Failed shutoff valve how to fix?
This is a major hazard, you need to take pictures of the whole thing and then disassemble the whole thing and use ptfe sealant and reassemble the whole thing. Unless you want to get a sniffer to locate the issue, If could also be the pilot pressure is too high and the pilot is not burning all the gas. You may want to call a pro due to explosion risk.
Jan 10, 2016 | Heating & Cooling
It's a j460 model that leaks.
sounds like it ran dry and burned up the seals between the pump and the motor
Sep 02, 2014 | Jacuzzi MAGNUM FORCE POOL PUMP 2 HP...
Can't get spark from coil to engine. Ran thru
You can use auto diagnostic tool to check the engine system first.
Jul 22, 2013 | Cars & Trucks
I ran my flotec sump/effuent pump dry, model 001D05S. Now it buzzes and doesn't pump. Can I fix it, if so how do I take it apart.
Unfortunatly if you ran it dry for very long it most likly burned out and will require replacement. Sorry. Thank you.
May 29, 2011 | Garden
If the head has a slight leak which is getting into the motor, should I take out the motor or replace the head gasket?
If your head has a slight leak you're probably burning coolant and/or oil. With coolant burning the exhaust is a visible white color and smells 'sweet' too. Exhaust when oil is burning sometimes looks bluish. Smells like burning oil too.
Take out the motor? You mean fully replace the whole thing? No.
Why is the head gasket leaking? Did it overheat at some point? If so, then your problem is bigger than just a bad gasket. Milling (flattening) of the head is required and there might be other issues caused by the exhaust (oxygen sensors now might be fouled). Costs for milling and replacement might run around $1500, but this is just a guesstimate.
Jul 27, 2010 | 1998 Toyota Corolla
Leaking fuel tank at seam under tank
That is the easiest leak to fix. You have to get a can of POR brand, tank repair. Remove the tank, drain it, dry it, I think you have to wash it with soap and water, dry it again, they give you instructions, mix up the paint, pour into the tank, let it cover the whole bottom, sides, and seam, and top too, and make sure you don't clog up any lines or vents, wait for it to dry, you will have the nicest looking finish inside your tank, hard as a rock, and will never leak again. I did my rust bucket Harley, the whole tank, came out beautiful. Then my Ducati sprung a leak right where yours is, and I did the same thing. It works great. Try POR.com.
Mar 14, 2010 | 2004 Yamaha FJR 1300
Stearing
if the rack is leaking then the only option to repair it is to replace it with a remanufactured rack.the noise is probably the power steering pump because it is low on fluid.
Jul 30, 2009 | 2007 Buick Lucerne CXS Sedan
Ran out of gas......
Sounds like fuel pump burned out when you ran out of gas. probably ran dry for about 20 sec till engine quit. Check for power to fuel pump in tank.Most likely fuel pump will need replacement . Hope this helps
May 06, 2009 | 2000 Cadillac Eldorado
Serpentine belt burned off
Do you know which pulley froze up? Depending on the pulley will depend on what you need to replace.
Nov 13, 2008 | 1997 Buick Riviera
Hi. I spilled coffee on keyboard ACER 9410 laptop. Now a couple of the keys do not work and screen jumps when I hit some keys on right side of keyboard. Can I replace the keyboard to fix the problem and...
I did the same thing. Here's what I did:
Took whole thing apart. Cleaned any coffee with q-tips dipped in water / paper towels. Removed the keyboard. Ran it through the dishwasher with no soap in it and heated dryer off of course.
I let it dry for a day and was bummed that now the whole keyboard stopped working. Well then 4 days later to my surprise / delight.. the whole thing started working again. New keyboards on ebay were also very reasonable. But mine still works perfectly after the dishwasher cleaning.
Sep 11, 2008 | Acer Computers & Internet
Polaris Pb4 - 60 Booster Pump Logo
255 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
