Question about Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver
Saeco Talea Ring Plus Espresso Maker about 18 months old. "Fill Container with Coffee" Get this message about 9 out of 10 cycles ... the machine grinds the coffee and just dumps it in the grounds drawer. Doesn't matter whether espresso or long or short. Hopper is always full of beans, and have tried different types of beans without any luck. Have tried adjusting the coarseness setting in the hopper without luck. Acccck! Any ideas?
espressodoc
  • 29 Answers
SOURCE: Grind is too coarse and "pucks" are wet and fall apart.
You say " I am getting a weak brew because of not being able to adust the grind to more coarse with the adjustment knob in the bean hopper" By making it more coarse you are making it weaker. Unless you just wrote it wrong. To make it stronger you should lower the grinder number to a smaller number. Usually about 4-6. Be sure you have the grinder grinding when you move it to a lower number. The pump noise could be that in shipping your pump came loose from it's mount. Nothing you can do without sending it to a Authorized Saeco Repair shop.
Posted on Jul 29, 2007
  • 833 Answers
SOURCE: Beans stick in hopper
The problem is that beans have particles and oil on/in them, jamming the switch which is giving you this message. Invert the unit on a hard surface covered with newspaper and give it a couple of strong taps against that surface. The junk should fall out and get you going again. Clearly, you're missing something when disassembling the unit.
Posted on May 09, 2008
  • 1089 Answers
SOURCE: saeco royal cappuccino coffee machine beans container empty fault
Hi
More than likely your grind is to fine. Push the lever back 1 # larger(Higher #). If you want stronger coffee, push the doser lever on the door to the back then pull forward 1 click.
Posted on Jun 01, 2009
EsWorld
  • 1618 Answers
SOURCE: Dispensing Failed- Saeco Talea Ring Plus
Try adjusting the grind four numbers coarser and brew a coffee, if you are getting the same result then the brew unit is clogged and the screen needs to be cleaned.
Posted on Jun 24, 2009
SOURCE: Saeco Royal=,beans do not appear to be grinding,
Coffee Beans were roasted by local business,believe they were either not roasted enough or over roasted causing the problem, I have since tried Supermarket(Vittoria Roasted Beans) and machine is working perfectly.
Thankyou
Keviroy
Posted on Oct 03, 2009
Saeco talea grinder is starting when you start the machine
this sounds like the machine simply needs a good cleaning due to grounds jamming the switch in place
Sep 05, 2014 | Saeco Talea Ring Plus Espresso Maker with...
On my talea ring plus i get an error code 5. anybody knows what that is?
Error 5 is the water circuit is block, or airlock in the system that means you have to purge the air out.
Feb 11, 2010 | Saeco Talea Ring Plus Espresso Maker with...
Seaco talea ring plus Q: what i have to do when
Press hot water button and open valve to run the pump.
Aug 22, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
Jun 20, 2009 | Saeco Talea Touch 14-Cup Coffee Maker
HOW DO I GET THE INSTRUCTION MANUEL FOR A SAECO TALEA RING PLUS COFFE MACHINE?????
The French Saeco website has manuals (in English as well as French).
Try this url…
http://www.saeco.fr/en/manuali/manuali.html
HTH
Mar 16, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus not frothing milk
per il milk island asciugare bene la valvolina e tutti i fori del blocco di plastica che fa da montalatte devono essere perfettamente asciutti dare dei colpetti alla valvola per fare uscire eventuale acqua all interno.
MORENO
Feb 20, 2009 | Saeco Talea Ring Plus Espresso Maker with...
What Descale sign means
Start the descaling and follow the instruction the machine give you.
Best regards
/Mirran
Sep 06, 2008 | Saeco Talea Ring Plus Espresso Maker with...
Saeco Talea Ring Plus Espresso Maker with Milk Island - Titanium/Silver Logo
52 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
