Printer feeds multiple sheets and james sometimes will not feed.
    Sergeant:
    Novelist:
  • 179 Answers
This is a very general question, for which I will give very general responses.
There are two (again general) reasons why these problems come up. The most common is that the feed rollers have become worn and/or impacted with paper dust, and will not pick up the paper correctly. If your printer has a "clean feed rollers" utility (some do) then use it. If not, and if you can reach the rollers, you can try using a slightly moistened piece of t-shirt material (DO NOT USE PAPER TOWEL or anything else that can leave lint) to lightly swab the rollers to remove the paper dust, etc. Be very careful. It's easy to break plastic parts.
Another reason may be the paper itself. If you live in a humid climate (I live in the tropics...this is an issue here) then the paper can absorb moisture as it sits, which will cause it to stick together in the feed tray. If this is an issue, keep your paper in plastic bags to keep the moisture out until you're actually ready to print, and don't leave paper in the feed tray for extended periods.
Another reason can be static cling. Always flex and fan the paper stack, then re-square it, as you place it into the tray. This separates the sheets and causes the "cut edges" (which can stick together from the packaging process) to let go of each other.
Hope that's helpful.
Posted on Dec 31, 2010
Hi Canon LBP 1120 paper feed and paper jam problem: My Printer mostly take in multiple paper sheets instead of taking just one sheet. Sometimes the extra sheets are taken in while the printing sheet...
You need new pickup rollers
google search "LPB1120 pickup rollers" and find your nearest dealer. usualy quite easy to replace as long as your a "can do" person
Mar 18, 2011 | Canon LBP 1120 Laser Printer
Why is my LBP 1120 feeding multiple papers?
It is feeding multiple sheets because the seperation pad is worn and needs to be replaced.
Feb 14, 2011 | Canon LBP 1120 Laser Printer
Hello can you assist I can not figure out why the CX8310 Epson printer won't allow me to feed paper into it.
  • If paper doesn't feed, remove it from the sheet feeder. Reload it against the right edge, behind the tabs, then slide the left edge guide against the paper. Make sure the paper is not in front of the feeder guard.
  • If multiple pages feed at once, remove the paper from the sheet feeder, fan the edges to separate the sheets, then reload it.
  • Don't load too many sheets at once (up to 20 sheets of photo paper, 80 sheets of Premium Bright White paper, or 100 sheets of plain paper).
    Sep 11, 2010 | Epson Stylus CX3810 All-In-One InkJet...
    The paper jams coming out of the tray in the first set of feed dogs. Sometimes if i am printing more that one page the first sheet jame in the final set of feed dogs. I have to open back and pull sheet...
    clean all the paths of the paper. maybe there are some paths are causing the jam. check also all gears on the path. check also the separator pad if it is worn out.
    Jul 02, 2010 | Office Equipment & Supplies
    Miss feeds when print multilpe pages
    The paper feed solenoid is sticking, it can be seen thru a hole in the back with the door opened. Not easy to get to, but I have been able to bend the stop tab slightly and run just fine.
    Sep 02, 2009 | Konica Minolta magicolor 2300DL Laser...
    Sheet feed won't work
    When you reinstall the blue plastic piece underneath, the white plastic sheet that closes over the glass must hang over the blue plastic piece, not tuck under it.
    Mar 29, 2009 | HP Officejet Pro L7680 All-In-One Printer
    Paper is jamed
    I have a HP697c and sometimes it grabs more than one sheet and gets jammed. I take hold of the trailing edge and pull hard and slowly till it comes back out. Then I remove and straighten the feed pile and try again.
    Nov 07, 2008 | HP DeskJet 920c InkJet Printer
    HP paper jam
    That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
    Please remember to rate all users who assist you for free :)
    Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
    Wrong adjustment using epson LQ-2180
    Check to see if the pinch roller is set for standard sheet feeding the printer must feed by the tractor feed only.Does the paper get damaged when you try to feed or reset the page beginning, What we are looking for is a piece of one of the sheets loged in the pinch roller.Also check the pressure adjuster on the right side if you are not using multiple copie printing it should be set to medium . Let me know what you found... Be mucho blessed... Mark
    Jun 27, 2008 | Epson LQ-2180 Matrix Printer
    67 people viewed this question
    jasbo
    jasbo
