Question about Refrigerators
The Refridgerator compartment won't keep cool , but the freezer works fine. Would it be the thermerstat or compartment dial
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Jan 01, 2011
Freezer works fine but top refridgerator won't cool
HI.TRY DEFROSTING IT ALL FIRST.IT MIGHT WORK.GOOD LUCK.ALI
Jun 25, 2012 | Maytag Refrigerators
The refridgerator compartment does not seem to be getting cold, the freezer compartment is fine.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 01, 2011 | Amana Refrigerators
The refridgerator compartment is not working while the freezer compartment is working fine
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Oct 24, 2010 | Whirlpool Refrigerators
Freezer seems to be working fine, but the refridgerator is cool at best with the thermostat all the way down. I tried to defrost, but with no help. I think the fan in the freezer might be bad.
The only place that cools in a refrigerator is the freezer. The refridgerator side stills cold from the freezer via an air duct that runs from the freezer to the refridgerator. If your fan in the freezer compartment is not working your refridgerator side will not work. To replace the fan you will need to clean out the freezer including the shelving. Then remove the back panel all you need is a phillips screw driver. When the back is replaced the fan is at the top. It is held in by two screws that go threw rubber mounts on the fan braces. You will need to remove one ground wire and two electric wires on the motor its self. Make sure to unplug the refrigerator before starting the repair. good luck
Aug 28, 2010 | Kenmore Refrigerators
Freezer is working fine but the Fridge part is not
i take it the unit is frost free you need to replace the defrost element in the freezer whats happening is your freezer sends cold air through small holes to the fridge compartment but when the freezer cant self defrost those holes freeze over thus no cold air into the fridge compartment get a tech in to check the element shoulnt cost more than $ 80.00
Apr 21, 2010 | Refrigerators
Freezer compartment working fine but refridgerator compartment not cooling . DFF8803W
with most fridges that have this problem.there is a problem with the evaporator motor not spinng this needs to be checked for proper air circulation.
Sep 17, 2009 | Danby DFF8803W 8.8 Cu Ft Frost Free...
The freezer is working fine but the refridgerator is not cool enough
Sounds like your frig is not defrosting. Locate defrost timer and start manually. If that solves the problem, replace defrost timer. Another possibility is that the evaporater fan in the freezer compartment is not working. Both items easy to replace.
May 10, 2009 | Refrigerators
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Our Magic Chef fridge model # MCBR1000W does not seem to be keeping the fridge part cool enough, but still keeps the items in the freezer section frozen. The compressor is working, so not sure why this is...
yes the freezer door not closing properly will effect the refrigerator. also check in the freezer back wall and bottom for any frost buildup. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Jul 16, 2008 | Magic Chef Refrigerators
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
