Question about Bulova Watch
Remove links from metal band - Bulova Watch
  • 6,771 Answers
Take your item to a watch repair facility where they will remove the links and have you sized up on the spot, maybe at no charge.
Posted on Dec 31, 2010
Where can i get links to add to band or replace band?
Parts Archives - Citizen Watch - English (US)
www.citizenwatch.com/en-us/faq-category/parts/
Citizen HoldingsQ: Why can't my jeweler or I order parts for my watch that is marked 'factory ... We domake some components such as bands and band parts available directly. ....Determine how many links of this size are needed to make the watch band the ... Q:Can you use substitute parts if the replacement part I need is discontinued? A:.Missing: timberland
How To Easily Remove a Watch Link - YouTube
? 3:10
https://www.youtube.com/watch?v=8uxpDXKOPqA
Dec 29, 2011 - Uploaded by TheBiggerKid
I got a watch for Christmas but the watch band needed a little adjusting. I thought ... Real Men Real Style 310,589 views ... How To Resize A Citizen Watch Band - Add & Remove Links At Home ... Get video URL at current time.Missing: timberland
Your Guide to Adding and Removing Links in a Bulova Watch
www.ebay.com > ... > Jewelry & Watches > Watches > Wristwatches
If the current watch does not fit properly, find another watch, a bracelet, ... When a metal watch band is too small, add links to make thewatch band ... How to Choose the Right Strap Replacement for... ... Bulova Men's 98E112 Diamond Set Stainless...... Bulova Men's 96A28 Black Leather Band Quartz Watch NIB Image ...
Jan 31, 2016 | Timberland Mens Quartz Watch Qt7117302
How to take up slack on a metal watch band without removing links
either wear it tight or loose . they do not make 1/2 links
Jan 25, 2016 | Watches
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Dec 25, 2015 | Watches
U17505g1
I need more information. If it's a segmented metal band, each segment is removed using a small pointed tool to depress the holding pins, similar to replacing the watch strap. If it's different, describe the band.
Jun 25, 2014 | Watches
Can you please tell me how to remove links on my le cheatau ceramic watch?
Hi, sizing the bracelet on your ceramic watch may void its warranty, making it ineligible to receive service from the manufacturer. If you want to keep your watch covered under warranty, contact your watch manufacturer for information on their customer repair service.
If you want to remove it yourself, you need a watch pin removal tool. You can use a watch pin removal tool to remove the link pins that secure the clasp pieces to your ceramic watch band.
But if you don't have a watch pin removal, follow the instruction below........
  • Find a clean, flat, well-lit work surface where you can size the bracelet of your ceramic watch. For best results, spread a soft optical cloth over your work surface and perform your repair on top of the cloth. The cloth will help prevent you from losing any small watch components, like link pins, that may be freed during repair.
  • Wrap the ceramic watch band around your wrist and count how many links overlap. Use this as a guideline for how many links should be removed. Note that the actual number of links to be removed may differ slightly from the original estimate. Remove excess links from your watch band one at a time to make sure that you don't end up accidentally making the band too short.
  • Remove the excess watch links from the ends of the band with the attached clasp pieces. Look between the removable ceramic watch links to locate the silicone connector pieces that join the links. Use a pair of small, pointed scissors to make a cut between the link and the silicone connector, this will free the excess links. Cut on the side of the link that faces the watch clasp. Repeat the process on the other side of the ceramic watch band.
  • Remove the clasp pieces from the ends of the removed watch links. Examine the clasp pieces to look for the metal pins that hold them in place. Push out the metal pins with a push pin to free the clasp pieces. You can now reattach them to the ends of your ceramic watch band.
  • Examine the newly-shortened ends of your ceramic watch band. Without the clasp in place the silicone connector pieces will be exposed. Note the two small puncture holes that go straight through the silicone connector. Insert the teeth of one of the clasp pieces through the holes in the silicone connector from the bottom. Fold over the other side of the clasp piece, reinsert the metal link pin and push the clasp to click it into place. Attach the second clasp piece to the other side of the watch band using the same procedure.
Jan 06, 2011 | Watches
I need to shorten the metal link watch band of my Casio Model 2747 watch.
I just looked at the watch band link more closely and figured out how to remove the links. Pretty engenious link attachment arrangement!
I thought there would be something in the watch manual about band adjustment, but there wasn't. I guess it is not something a "normal" person would be able to do.
Thanks,
Steve Zansler
Dec 31, 2009 | Casio Watches
How do i shorten a metal watch band i have a casio 708
Look for removable pins in the band to allow removing one link at a time until it fits ok.
Dec 06, 2009 | Invicta Pro Diver 9321 Wrist Watch
Remove links on this watch
Most bands have removable links on the end of the band. You can tell because they have small holes on the side to remove the pins that hold them together. The links that don't have holes are not removable. This is standard on most metal bands.
May 09, 2009 | Timex Atlantis 100 77517 Wrist Watch
Adjust ladies citizen watch metal link band
If it is a metal link band, you can remove a few segments. Segments are connected by split pens. You should see a thinner end and a bigger end; or an arrow on the inside shows where the thinner end should be. Push the thinner end firmly with a pin or something until the big end pops out the opposite side.Use pliers to remove the pin.
Apr 12, 2009 | Citizen Eco-Drive BL006056H Wrist Watch
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Bulova Watch Logo
77 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
