Question about Sony Playstation 3 (PS3) Console
Turn on console,it starts to run then yellow light comes on and it turns back off.
    President:
  • 1,139 Answers
Hi there, unfortunately this sounds very much like the Yellow Light Of Death (YLOD). When the PS3 was originally made Sony used lead free solder in their consoles. Lead free solder is not as flexible as normal leaded solder and over time due to expansion and contraction because of heat given off by the console's components hairline cracks formed in the solder and lots of PS3's failed. You have got a couple of options, you can either have the console professionally repaired which is going to cost around £50. If the console is out of warranty Sony will only replace it for a cost of around £130. As a last resort if you are good with electrical items you might want to have a go at repairing it yourself. If you google YLOD you will find plenty of guides that will instruct you on how you can repair it yourself.
Please bear in mind that once a console has the YLOD there is NO guarantee as to how long a repair will last, it could be a couple of hours to a couple of years.
Thank you for using FixYa
Posted on Jan 01, 2011
My ps3 turns off a couple of seconds after it is turned on then the red power light blinks
If your PS3 console attempts to turn on, then beeps and a yellow light comes on and then your Sony PlayStation 3 shuts down or does not power on at all or shows no video means YLOD or Yellow Light Of death has occurred! A guy had same problem with His console 6 months back, He was able to fix it for 15 bucks ! without sending it to Sony for costly repair.
Jun 07, 2012 | Sony Playstation 3 (PS3) Console
My ps3 will not stay turned on when i do try to turn it on its light turns to a yellowish color and then starts flashing red like it's off but it stays flashing unless you turn off the switch
The PS3 Yellow Light is the 360's cousin for the Red Ring of Death. My assumption is that you may have unintentionally blocked any sort of cooling the PS3 has. Here are some steps in correcting that yellow light. This information comes from HowtoFixyourPS3.com:
In order to fix your PS3 yellow light error, there are 3 things that you can do.
1 - Restart your Playstation 3.
2 - Check for loose cables.
3 - Unplug all cables, and plug them back in.
4 - Take out your hard-drive, and place it back in your console.
If these 4 tips didn't fix the PS3 yellow light problem, then it's high likely that there's something wrong with your hardware. In order to repair that problem, you can do 2 things. You either send your console over to Sony. Or, you simply fix the problem yourself while using a PS3 repair guide.
Jan 01, 2011 | Video Game Consoles & Games
When i was playin it automatically turned off, and then i tried to turn it back on the light turns yellow,then it turns back to red and starts blinking.
Yes this is the yellow light of death caused by overheating on the console you can send it in to the factory to get it fixed or you can use a good PS3 repair guide to fix it yourself
Aug 18, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my PS3 it as it starts up a yellow light comes on
The yellow light is also know as the yellow light of death casued by a hardware failure. It can be casued ny over heating a bluray drive failure, a hard drive failure or even a powersupply failure. You know you have it when you power up the yellow light flashes then you hear some beeps then the red llight flashes. I would suggest returning it if you have that option or getting it fixed somewhere else as a last option.
Apr 16, 2010 | Sony PlayStation 3 40GB System
WONT START UP
This is known as the yellow light of death(ironic i know). This is caused when the unit overheats causing solder on the board to melt and bridge(connect). Once this happens it shorts out the board giving you the error you have now. Contact Sony and see if the unit is still under warranty.
If the unit is not under warranty go to www.wiredextreme.com. We are a console repair company based in Texas, and we can get your console up and running again. All of our repairs come with a 90 day warranty that covers the whole console, not just what we repaired. We also offer extended warranties up to 4 years at additional cost. If you have any other questions/concerns feel free to email support@wiredextreme.com or call toll free 1-888-389-3038.
Apr 12, 2010 | Sony Playstation 3 (PS3) Console
When i turn on my ps3 it starts up fin and the frezzes then a yellow light flashes and then turns of
have you tried this?
Turn the console off at the back switch for a few minutes. Then switch it on from the back, then hold the Power button until you hear a second beep. If your PS3 is completely stuffed it probably won't do this, but there's a chance it might let you into the recovery menu which will let you do a format or System Restore and hopefully get your machine running again.
Is there any green or red flashing lights?
Hope you don't have the yellow light of death.
Apr 08, 2010 | Sony PS3 40GB Best Sellers Bundle Console
It comes on and a yellow light flashes and then it goes back off
Take the hard drive out of the system and then put it back in. Sometimes the yellow light comes on because the hard drive becomes unseated.
Try turning on the system and if the yellow light comes on, try another hard drive in the PS3.
If the yellow light still comes on then you know that the main board in the ps3 is bad.
Dec 02, 2009 | Sony Playstation 3 (PS3) Console
Yellow lights
Yellow lights and blinking red lights indicates general hardware failure on ps3. If your ps3 is still under warranty call Sony and they will send you a new or refurbshed one. North America: 1-800-345-SONY (7669) United Kingdom: 08705 998877
Now you could try doing a few things (hey it's worth a try!)
1. Turn off the switch in the back and wait a few minutes. Turn it back on and try it again. If that doesn't work it may be dead.
Nov 21, 2009 | Sony Playstation 3 (PS3) Console
My ps3 won't release game out of console get yellow light
If you turn your ps3 off in the back, then hold down the eject button while you turn it back on it should come out, your welcome. j/k but it did work on mine.
Aug 30, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
19 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
