Question about Peg Perego John Deere Gator HPX Ride on Toy
Reverse and 1st gear work but 2nd gear does not
    Scholar:
  • 110 Answers
Might be a dumb ? but is the limiting screw still in the shifter? if not youve got a switch issue, here is a link to get a high/low switch for $11. to install, remove the shifter...1 screw in the back side and slide it forward. the high low is the one toward the rear.
good luck!
Posted on Jan 29, 2011
07 Tahoe only has 1st and 3rd gears.
2nd and 4th gear band is not applying. Possibly worn out. It comes on in 2nd and Overdrive. If this is the case, transmission will have to be overhauled.
Mar 12, 2014 | 2007 Chevrolet Tahoe
How do you engage 2nd gear. only works in reverse and 1st gear.
is the limiting screw still in the gearbox? just remove it and it should shift right into 2nd gear.
good luck!
Jan 01, 2011 | Peg Perego John Deere Gator HPX Ride on...
Only reverse works. No foward gears.
No forward movement in OD or D, but L2, L1 and R work: Forward sprag is broken. R&R. Try not to run or drive the car or further damage could result.
Do you have manual 1st? If so, can you shift through the gears...i.e. manual 1st to manual 2nd then 'D' then 'OD'??? Only 1st and 2nd gears use the forward sprag unless the LO/Rev clutch is engaged...i.e. 1st and 2nd if in "drive". If you can shift threw the gears manually then, yes, your forward sprag broke.
If no manual 1st then your sprag is not what broke. Sounds like you blew up the rear planet. If you pull the pan and find chunks of iron and steel, then that is probably what happened. If you have reverse then it is not the pump. If the pump was bad you would have no line pressure and it would slip in rev. or no rev. Not the beef sun shell either because you have rev., a broken sun shell would cause no 2nd, 4th and rev. gears. Either way the trans needs to come out and torn down and it will be easily found what went. Good luck and thank you for using Fixya.
Mar 06, 2010 | 1991 GMC C1500
No reverse and 1st gear only on a 98 chevy work truck 1500
sound like its time for a new tranny, reverse goes first and the 2nd gear
Sep 21, 2009 | 1999 Chevrolet Silverado 1500
Will only drive forward in 1st gear, 2nd gear and
It is propably the gear box. Take the seat off and you will see the gears inside. Mine works only in 2nd and not the 1st or reverse. But I know it is the gear box since my husband replaced the 1st one a while agao. Just need to find the web site for the repacement part. Only cost us about $30 to fix last time. Hope this helps.
Jun 28, 2009 | National Little Tikes Hummer Yellow
Goes in 1st and Reverse but not 2nd
Something you may want to check is to see if there is a "governor" for the 2nd gear. My 4 year old has a 4x4 similiar to this and the only two gears that worked were 1st & reverse until my husband had to unscrew a piece from the 2nd gear setting..check the manual or if you don't have one, look online through the manufacturers website. I hope this helps!
Feb 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego John Deere Gator HPX Ride on Toy Logo
114 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
