Question about Nintendo Wii Console
Our wiimotes will not syc with the console; how do we fix this?
  • 112 Answers
You must sync the remote. To do this first take off Battery cover of remote.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. Look at the back of the remote. In the battery compartment there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Posted on Dec 31, 2010
Remote not working
more info required.. do the lights come on at all, if so - synch the wiimote with the wii console while on the WARNING screen(press the red button on the wiimote & the red button near the SD card slot on the console.
If no lights come on the wiimote - you either need new batteries or you may have damaged the wiimote by dropping liquid on it or somethiing similar...sometimes cleaning the wiimote PC board with alcohol swaps may fix that, but it is not a task for a novice (you sound like a novice, so I advise against it).. Opening the wiimote and putting it back together again is not easy for a novice to get right without proper instruction.. My advice - search for videos of how to achieve this.
If none of the above work - you probably only have 2 options left..
1. send it for repair (costs almost the same as the price of a new wiimote)
2. buy a new wiimote
~Good luck
Oct 24, 2013 | Televison & Video
Wii remote four lights solid
Sounds like it needs to be re synced with the system, Easy place batteries in Wiimote and turn on console press the red sync button in the back of the Wiimote and press the red sync button on the console it is now synced. If this fails it could be that the Wiimote has failed, if Wiimote had failed within warranty period of 90days from date of purchase return for repair or replacement if it is after warranty period discard and replace with a new Wiimote.
Jan 12, 2013 | Nintendo Wii Console
We tried to reset the sync buttons and the blue lights on the remote blink repeatedly but it still does not communicate with the game
Try removing and reinstalling the batteries from the wiimote and the unplug the wii power cord at the outlet end for a couple minutes. I had that problem once and this seemed to fix it.
Mar 07, 2011 | Nintendo Wii Console
Wii console is not responding
If there is no LED on, then the most likely reason is, that your wii isn't getting power. So the problem, is with the plugs, and the power adapter. If you have a friend who has a wii, try testing his power adapter on your wii. Make sure your cords are completely plugged in, on both sides, (the outlet and the wii) then press the power button on the wii. If that do-sent work, try turning it on with one of your wiimotes. If that dosent work, that means your wiimote is not synchronized with your wii. To sync. it, open the sd card cover on the front of the wii, press the red button above the sd card slot. Then open the bottom of your wiimote, (where the batteries are) and press the small red button that should be beside the batteries. Then hold the wiimote close to the wii,then after its done flashing, press the power button on the wiimote and also, try plugging your power cord into another outlet. If it still won't work, you've got a broken wii, so you better send it to get replaced or fixed, again as suggested. DON'T OPEN IT! You could loose your warranty if you open it, so it's safest not to. Hope you get it to work
Thank you !!
Jun 18, 2010 | Nintendo Wii Console
Now reparing
This is an April fools joke as preloader has been installed on your wii, just press A on your wiimote to boot as normal
Apr 02, 2010 | Nintendo Wii Console
Wii remote dosent work all lights flash but no signal to cosole atteries ok
Sounds like the console and wiimote are not synced.
1. Take the battery cover off of the wiimote, and open the small cover on the front of the console.
2. Press the red button under the cover and on the back of the wiimote.
In my experience this can take a few tries so be patient.
Feb 26, 2010 | Nintendo Wii Console
I was playing wii kart,one of my wii remote would
  • Make sure you have it so the Back of the Wiimote is facing the screen.
  • Check the left side of the Wiimote is facing the ground.
  • Make sure you have full battery power.
Nov 11, 2009 | Nintendo Wii Console
Wii Remote doesn't work
1. Make sure that your batteries are in correctly. See working Wiimote for reference.
2. When you sync the Wiimote, press the red button in the battery compartment and immediately there after, press red sync button in the Wii Console front panel (where the SD card goes between the Eject and Reset buttons).
3. Power off Wii console completely and restart.
4. Press any button on the Wiimote to activate.
5. If the above steps don't work, you may want to return it to the store for a replacement.
Apr 12, 2009 | Nintendo Wii Remote Controller
Wii remote
Hello.
You need to make sure the Wii knows where the sensor bar is. (Above or below TV) Another cause is low batteries. Also waving the Wiimote out of range. Make sure the sensor bar is on the very edge of your TV stand, or enterrtainment center. I have noticed on mine that if I'm going crazy with the wiimote and go to low, it will not register. Those are the most common problems and solutions. But you may even have a bad wiimote. There is also a calibration setting for the wiimote. So try all that. I hope this helps!
Good luck and happy gaming!!
Aug 20, 2008 | Nintendo Wii Console
Nintendo Wii Console Logo
18 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
