Question about KitchenAid Refrigerators
Ice machine no longer makes ice consistently.
  • 472 Answers
Is this a ice machine or on a refrigerator ... either way you want to make sure your getting water to unit... make sure nothing is obstructing fill line and you are actually getting good pressure and fill time is correct... make sure you have a clean filter on unit and there is no scale build up in ice components... make sure temp. on unit is cool enough alot of the units out there have to maintain a certain temperature in order for ice production to stay up.... need a little more detail on what we are actually working on... hope this help out a little...
Posted on Dec 31, 2010
Why is the ice from under counter ice machines so much better than refrigerator ice?
Refrigerator ice forms in a mold (think ice tray) made up of not only water, but whatever impurities it may contain. Even safe, municipal water supplies have some sediments and a range of chemicals from treatment. Ice machines create ice from water moving across a freezing surface and the result consists almost totally of water without impurities. So it is much more clear than ice from a mold in the refrigerator. Both systems work well, but the results have marked differences.
Oct 27, 2016 | Refrigerators
Ice maker makes ice really slow. drops ice every 45minutes or so
i think that is a good time to make some ice.
and depends what temp. you have the freezer setup to.
the colder the ice the longer it takes to make ice.
if you have to or need more information try this
www.ask.com/mfg.name/make/model/
/average-time-to make-ice/
/how-long-should-it-take-to-make-ice-cubes/
Oct 02, 2015 | Washing Machines
Fim200a does not make the cubes large enough
If you just started having this problem now and it was making the right size ice before then i would first look at cleaning the ice machine including the condenser coil. second thing make sure that the water inlet valve is not seeping water by when it is in freeze mode just a little warmer water will cause it to not make good ice and a longer freeze time. last thing would be to adjust the I.S.Adjust: Ice size adjustment on the control board. Turn screw clockwise, and the size of individual ice cubes will be larger in the next cycle; the cycle time will be longer. Turn the screw counter-clockwise, and the ice will be smaller in the next cycle. only do this if every thing ealse checks out good.
Dec 05, 2013 | Franklin Industries Franklin Chef FIM200...
Our Marvel icemaker was working great then it starting making ice at a much slower pace. It is not make ice no where near as fast as it was. What could be the problem?
Could be a dirty condenser coil, blocked return air, if the ice machine is in a warm environment it takes longer to make ice, water temperature if it is warmer it will take longer to make ice. if water inlet valve is letting water seep buy during freeze cycle it will take longer to freeze.
Dec 17, 2012 | Marvel Appliance Ice Maker
Don't have instruction manual. How do you make basic ice cream in this machine? How long do you freeze container in freezer? How long do you plug in?
Freeze the the container for at least 48 hours before using it. You can use whatever ice cream recipe you like in the unit. Basic vanilla - 3 cups whole milk - 1 teas vanilla - 1 cup heavy whipping cream - 1/2 cup sugar. Mix everything together in a pitcher and make sure the sugar is disolved. Taste it and make sure it is sweet enough for you. If not, add more sugar. If you use 2% your ice cream will not be very thick and it will take longer to set up and freeze.
Put the container in the ice cream maker. Turn it on (insert the plastic mixing blade if it has one) Pour the mixture into the ice cream maker if it has an open space to add mix through the top. If not - put the mix in before turning it on (my model is a little different than yours - sorry!)
when the ice cream is thick enough for you - then its done. It usually takes approx 15 - 20 for soft serve/milk shake consistency - and 30 - 45 for stiffer - ice cream. The ice cream does not get hard - at best its soft serve quality. There are other recipes that you cook which I hear will set up harder but I have not tried any yet.
You can make chocolate by using the same recipe above - and adding any liquid chocolate - or fudge. If you add strawberry preserves - it makes strawberry ice cream. sugar free drink mix added to the vanilla recipe above makes great flavors (crystal light drink power mixes ect)
Jul 13, 2011 | Cuisinart (ICE-20) 1.5 Quart Ice Cream...
The ice machine is no longer taking in water to make ice
Sometimes the valve on the water line becomes plugged and can no longer supply water to the refrigerator. The other options are that the ice maker could possibly not be supplying voltage to the solenoid valve on the rear of the fridge, or the solenoid valve could be bad itself.
Mar 13, 2009 | Refrigerators
Rival 8550-X motordrive
if the motor goes, it would probably be cheaper to buy a new maker... but try www.jardencs.com and call the 800 number under the Rivel Logo.
Jul 06, 2008 | Rival 8550-X 5 Quart Ice Cream Maker
Water/Ice Dispenser Does Not Consistently Work
Sammy, I am having the same problem with my 695. I have a call into subzero service and will let you know what I find out.
Thanks for your help as it fixed my problem as well, albeit temporarily.
Alan
Jan 12, 2008 | Sub-Zero 695/O Side by Side Refrigerator
Refrigerators Logo
365 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
