Question about Homedics Ss4500 Sound Machine Alarm Clock Radio
I took it out of the box set the time and turned the projector on, and the time doesnt come across the projector only zeros does, is there something I'm suppose to do with the projector?
  • 91 Answers
You have to set your time and those zeros will be gone
Posted on Dec 31, 2010
Need to reset the lamp timer on a Sonya POA-LMP24 projector
Attach the power cord to the projector and plug it into an electrical outlet. Turn the projector on and allow it to initialize.
Press the "Menu" button on the top of the projector. Use the left and right arrow buttons to move the red box pointer to the "Settings" icon.
Use the up and down arrow buttons to move the red box pointer to the "Lamp Counter" icon. Press the "Select" button.
A pop-up window will appear displaying the number of hours accumulated on the lamp. Below where the hours are displayed is the option to reset the counter. Select the "Reset" option and then select "Yes" to confirm. This will reset the lamp hours counter to zero and reset the indicator light.
Feb 24, 2011 | Boxlight POALMP24 PART 9901 Projector...
When we turn on our PT-AE3000U it will power up until the blue screen with "PANASONIC" written across it appears and then it will just shut off. WHy is this?? We have changed to lamp in it...
if it abruptly turns off the thermal sensor could be worn out and triggering to shutdown, other than this it may be software related.
be sure that the projector is receiving a signal in the correct input form a DVD player or something to ensure that its not just on the standby screen.
Feb 10, 2011 | Panasonic PT-AE3000U LCD Projector
How do I find out the embroidery time on my Viking Designer 1 sewing machine?
Hi there, If your trying to find out how long it took you to embroider something, You need to go to your touch screen menu- touch Set- then down at the bottom left of this screen and touch More- three (3) times you'll get to where it says Running time:(It's the 3rd Selection) There it will actually show you the total running time (Sewing and Embroidery If you haven't zeroed it out by hitting the zero (0) next to that selection.) You can do this on the touch screen with the embroidery unit on or off. You need to touch the zero (0) to zero out your time before you start an embroidery project. Once you've done this and you've finished an embroidery you can check how long it took by the touch screen menu- Set- touch More 3 times and there you will see how long on the Running time it took to embroider your design. I hope that helped. The total time your machine has ran (Embroidery and Sewing) is kept in Memory on the Service Screen that your Technician gets into when he services your machine. So your not actually wiping out that. The Set menu is just for you to keep track of how long your machine sews or embroiders something pretty much. I hope that helped you out with your question. Happy Sewing!! Kathy
Nov 19, 2010 | Husqvarna Designer I
Removed carousel midway by lifting release as a slide fell down,
With the tray removed, cycle the projector in Reverse button 5-6 times. If it is just a mechanism jam from removing the tray mid-cycle, this will cure it. To set the tray back to Zero, FIRST make sure the locking ring is in place and tight on the top of the tray. Then turn the tray upside down & release the latch and rotate the bottom plate back to it's home (Zero) location.
Apr 26, 2010 | Kodak Carousel 4600 Slide Projector
I am trying to set up an InFocus LP400 projector with my computer. I followed the instructions using the CableWizard Lite cable for my laptop pc and get no projected image. I used the suggested port...
start the connecting all over again, by following the steps below:
1. Turn your computer off.
2. Connect the cable from the computer to the projector. If you want to have your monitor to be hooked up as well, connect a splitter to the video out port (DVI or VGA). You can also just hook the projector up to the second port on your video card (If you have one) or if you have a laptop, you can connect to the video out port on the back.
3. Turn the computer on and boot into your desktop.
4. Turn on the projector. Most projectors have an auto detect function, that will detect a video signal and auto configure the projector to display that signal. If you have a laptop, you have to hit a function key to activate the second display. Usually this is FN Key + F5 or one of the F Keys across the top of the laptop keyboard. It looks like two squares, one empty and one with something in it.
5. Adjust the focus, brightness, contrast, and color on the projector.
6. Aim the projector at something white. Try not to aim it at something highly reflective.
7. Step back ... Load up your favorite game or video ... and enjoy.
Your project should work, after following the above instruction.
Good luck.
Apr 07, 2010 | InFocus LP 400 Multimedia Projector
Honeywell HCM-646 -Motor not running
There is normally a capacitor to prevent surges across the motor it might the short circuit.# and preventing the motor from starting.
Jan 13, 2018 | Honeywell HCM-646 4 Gallon Humidifier
Sanyo PLV 70 - Power Won't Turn On
it could that the plastic stem on the inside of the lamp cover on the underside of the projector may have snapped off. if it has you'll have to wedge something onto the cross shaped hole, to keep button inside the hole pressed in, in order for the projector to turn on
Sep 20, 2008 | Sanyo PLV 70 Multimedia Projector
Can't watch footbal
NOTE: ----DO NOT TOUCH THE CONVERGENCE BOARD " -------
1. Bring Up 1 Projector Light 2. Bring Your Color Convergence + Sign and Should Be Center In Your TV 3. If Not Adjust Center with The 2 Tabs Just Above That Projector Tube You Have Lighted 1 Tab Will Move + Sign Horizontal Then Roll The Other Vertical Then Roll..U Will See--" 4. Once Your + Sign Is Center Turn Up Your 2 Other Projectors Make Sure They Are Able To Adjust Across The + Sign You used 1st Make Sure the 2 Other + Signs Move Left And Right And Up And Below The Vertical and Horizontal Lines. If Not Adjust There Tab to Make This Possible. 5. Using Your REMOTE Converge The + Signs Together. ---------------- IF YOU MESSED WITH THE CONVERGENCE BOARD ------------------- 6. Now Lower The 2 Lights So Your 1st Projector Is Lighted 7. Bring Up A Menue On Your TV -- Look At It ...Are The Lettering Center and Square ..?? 8. If They are Lower That Projector and Light Your Projectors 1 At A Time To Verify Letters are Center and Square. ---------------If You Have To Adjust The Menue To Bring Center And Square -------- 9.Looking At The Convergence Board You Will See 3 Rows Of Adjustment Dials Each Row Is For 1 Projector. ---TAKE NOTE TURN THE ADJUSTMENT Slowly--- 10. Locate The Row that will adjust The Projector You Have LITGHTED".... 11. Label On A Paper What Each Knob Will Do To The Screen Very Help-Full 12.Adjust Your Letters Dead Center and Square then Lower That Projector Light And Bring Each Projector Lighted At 1 Time To Verify Menue Is Center And Square. 13.Leave On Your 3rd Projector and Bring Up Your Light On The 1st Projector 14. Adjust the Letters Of Your 1st Projector Over The Letter Of Your 3rd Projector 15. Switch To Your Convergence + Sign To Help --Turn Knobs Slowly --- 16. Make Your Letters Merge Together And Your Lines Square. 17. I Use The Top Letters and Lower Letters And Keep The box Square 18. Hey If Your Projector Colors When Looking Through The Rear Of The TV Are Not Equal With Take And loosen The Wing Nuts And Turn The Lens To Focus the Color and Make Narrow Or Wide....All 3 - Equal DO NOT GET UPSET THIS WILL TAKE TIME MAYBE ALL DAY SO RELAX HAVE FUN" Do Not go Sticking Your Hand Into The TV While TV Is Plugged into The Wall" ---
Dec 16, 2007 | Philips Televison & Video
Color bleeding - blue colors always on the screen
just came across this same prob on my projector. Any ideas?
Dec 11, 2007 | Canon LV X2 Multimedia Projector
Homedics Ss4500 Sound Machine Alarm Clock Radio Logo
201 people viewed this question
Top Homedics Audio Players & Recorders Experts
Gyula Lacz
ray gallant
Tom Chichester
Are you a Homedics Audio Player and Recorder Expert? Answer questions, earn points and help others
