Question about HP Deskjet F335 All-In-One InkJet Printer
I checked everything, the printer is connected, there's ink, everything is good, but it says it's offline. I clicked "Use printer online", but it's still offline. I tried Refresh, and it's still offline, but all lights go on when I turn it on, and I have tried restarting my computer, and the turn the printer on and off thing. It keeps saying it's offline
    Sergeant:
    Novelist:
  • 179 Answers
The first thing I would check is the cable. If you're using a USB connection, try a different (and known to be good) USB cable. If that doesn't do it, you may have a damaged USB connection socket at the printer, which is not cost effective to repair.
Hope that's helpful.
Posted on Dec 31, 2010
Printer says offline and cartrige light is flashing
Check whether the ink cartridges are properly installed.If installed incorrectly they can cause the printer to go offline.Install them correctly.
Also check whether you're running low on cartridges ink and replace if need be.
Sep 27, 2011 | HP Deskjet 6940 InkJet Printer
To change print status "offline" to "online
Go into printers and faxes in Xp or Printers and devices in Windows 7. Double click on the printer icon and click on file and then Offline and it will change to online. That should do it.
Jul 27, 2011 | Canon imageCLASS MF3240 All-In-One Laser...
"The printer is offline. Check
Go to start; printers and faxes right click on your printer and you should see use printer offline and a check next to it, click there and you should be ok. If not they may be a button on the machine that will allow you to go online.
Hope this helps.
Apr 12, 2011 | Canon PIXMA MP160 All-In-One InkJet...
How to I correct "printer
Hello
Printer Offline cause if your printer isnot available like if your printer is installed in your computer oflaptop and the printer is not plug in or printer is off. that cause printer offline. right click and look for online and click thats it your printer is online now. if the printer is connected on the network and it is offline it means your printer or your pc is not connected on the network.
Thanks and rate
Apr 11, 2011 | Canon PIXMA MX310 All-In-One Printer
Hp deskje d2360 printer showing offline error
On Printer and faxes, right click on your printer and unselect "Use printer Offline". If "Use printer Offline" is not select, then verify you USB cable.
If I could be of further assistance, let me know. If thishelps or solves the issue, please rate it and give a testimonialfor my response.
Mar 08, 2011 | HP Deskjet D2360 InkJet Printer
My HP deskjet D4260 is offline. I have tried everything to resolve this but cannot find a way of etting it back online. Please help
Once you have added either a USB or networked printer to your PC or Mac computer, you can begin sending documents to print. However, on occasion, a print command will create an error on the printer and take it offline, which will prevent all future jobs from printing. To resolve this issue, you will need to change your printer settings from offline to online.
    PC Instructions - Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer. - Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open. - Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
    Mac Instructions - Open System Preferences by clicking on the icon in the Dock. - Go to the Print & Fax control panel under the Hardware category. - Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button. - Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Mar 02, 2011 | HP Deskjet D4260 Printer
Printer says "printer is currently
The printer is connected to the rest of your computer with connecting hardware. If the connecting hardware such as connecting cords or connecting pins are damaged or not secure, then printer would be offline. Users facing the printer offline issue are recommended to check the connecting hardware and if the connecting hardware is found damaged, they would have to be repaired to solve the issues.
Jan 24, 2011 | Brother HL-2170W Laser Printer
Not able to print. Says that the printer is offline. Have checked the line connection everything is connected.
please perform the steps below if you are using Windows XP Operating System:
1. Click Start --> Printers and Fax.
2. Right click the printer icon and check the following:
a. Check whether the All-in-One is set as default printer.
b. Ensure that the there is a check mark on the "Use printer online". If you have the Use printer offline, make it online by selecting the option.
c. Ensure that there is no check mark on the Pause printing.
Oct 02, 2009 | HP Office Equipment & Supplies
Hp deskjet 6980 will not change to online. Working wirelessly. It says Offline and can't be changed to Online. I have to reinstall everytime.
Right click printer properties and select online. Start /settings /printers. Offline can also indicate a connection is not available - this occurs with demo versions of printer software. When the demo expires, the printer goes offline. The fix is to just use windows networking and shared printer.
Aug 29, 2009 | HP Deskjet 6980 InkJet Photo Printer
Offline printer
unplug the USB lead and plug it back in...if no response try another USB port, if still no response use a different lead or put a gentle bend in the one you have to make the connection tighter....make sure the printer is on of course
Aug 02, 2009 | HP DeskJet F380 All-In-One Printer
HP Deskjet F335 All-In-One InkJet Printer Logo
599 people viewed this question
Ben Johnson
