Question about Thomson Thompson Center Omega Z5 Rifle - Blue/Black
Would it be possible to get a parts list with sketches of where they are on the rifle,for a thompson center omega z5 muzzleloader rifle.
  • Anonymous Mar 17, 2014
    What year was this rifle produced and what is the model
  • 297 Answers
I get my parts from www.gunparts.com , They have schematics for many diferent guns.
Hope this helps, Matt
Posted on Jan 01, 2011
Savage smokless powder muzzleloading rifle broken vent liner in breech plug is this a common problem also is there any upgrades for this are parts still available for this rifle any info would help
Check out these links and the bottom link
Precision Rifle Savage Vent Liners - Precision Rifle Home
https://www.prbullet.com/vl.htm
  1. Cached
  2. Similar
Savage 10 ML II Single Hole Vent Liners. The hole in the factory Savage vent liner measures .0305". By experimenting with a variety of breech plugs utilizing ...
Precision Rifle Home - the world's most innovative Muzzleloader Bullets
  1. Cached
  2. Similar
Precision Rifle - Manufacturer of the world's most accurate muzzleloader ... Savage Smokeless Muzzleloader - could it be the Ultimate? ... Savage Vent Liners
Cleaning frequency recommendation for a Savage muzzleloader
https://www.savagearms.com/firearms/cleaningmuzzleloader/
  1. Cached
  2. Similar
If you have fired either black powder or Pyrodex® through your rifle, use any good ... Thoroughly clean the breech plug and removable vent liner of fouling with ...
Vent Liner for Savage MLII and all Lehigh Breech Plugs - Lehigh Bullets
https://www.lehighbullets.com/.../vent-liner-for-savage-mlii-and-all-lehigh-breech-plu...
  1. Cached
  2. Similar
US$27.00 - ‎In stock Direct replacement vent liner for the Savage MLII muzzleloader and all Lehigh breech plugs. The domed head and computer modeled internal design improve ...
muzzleloading rifle broken vent liner in breech plug Google Search
Dec 19, 2016 | Optics
My thompson center rifle firing pin hits primer but only shoots about half the time
strip the bolt and clean it as dirt inside could be causing light strikes some of the time or the casings you use are getting pushed up the chamber by the pin some times
Oct 29, 2013 | Thomson Thompson Center Muzzleloader Rifle...
I have the thompson center muzzleloader trumiph.Having trouble sighting it in,shooting thompson tc bullets 250grain shockwave. with 2 triple 7 pellets and triple 7 209 primer. shoot and hit bulleye...
One thing about muzzle loaders, you should wipe or clean the bore after each shot. You need to find a method that works for you. I have an old CVA and I have to wipe the bore after each shot to keep it accurate, if shooting for fun I do not. But I would use my rod and with one patch in and out just to keep the fowling down.
Lets think of it this way. Even with the new powers they tend to build up. Now this build up causes each shot to have a different pressure and then each shot will run down the bore different. Hence one shot here another there.
Then there is the primer itself, The 209 primer has a very hot flame and can cause a bit of fouling.
See this link. Primers cause accuracy problems. It may help you understand what is going on. But the easy fix is to learn; wipe the bore after each shot. Use the same method to load powder, press the bullet in the bore, seat the bullet on the powder pellets, fire the gun, wipe the bore, start over doing the same steps, same motion, same pressure each time.
Jan 09, 2011 | Thomson Thompson Center Muzzleloader Rifle...
Does the TC Omega have a problem using 150 grains of blackpowder or its' eqivalent?
Hello jps.... No problem at all with 150 grains. In fact, that is the spec. max. amount. The Thompson Center Omega Z5 was designed with simplicity in mind. It is easy to shoot and easy to clean. The breech seals the 209 primer from rain and snow and is easy to open with a simple forward motion of the lever on the trigger guard. The sealed breech plug design also prevents the crushing of Pyrodex pellets. The Z5 can handle a powder load of up to 150 grains for more power or longer range shooting.
Technical Information
Notes:
  • Exposed hammer
  • Sling swivel studs
  • Rubber recoil pad
  • Fiber optic sights
  • Blue chrome-moly steel with a silver weatherguard finish
  • Joe
    Thanks for choosing Fixya!
    document.getElementById("divReviewInfo").className = "reviewInfo";
    Jan 02, 2011 | Thomson Thompson Center Omega Z5 Rifle -...
    I broke a pick off in my breech plug. I had to
    DO NOT fire it until you've replaced the breach plug!
    The breach plug hole size is critical, opening it up even a few thousandths of an inch can cause a dangerous situation whereby chamber gasses can push the primer or musket cap back against the hammer and allow blow by gasses to exhaust directly into the shooter's face.
    Mark the Gunsmith
    Dec 20, 2009 | Thomson Thompson Center Muzzleloader Rifle...
    I want to find out what my guns year and type it is buy the serial number can i do that?????
    Try taking it to a dealer/smith. I have seen gun smiths pull the most amazing info out of there head on even the rarest items. Also, try google or call the manufacturer. Another was is check out a book store or library. There are weapon encyclopedias that may help.
    Hope that helps.
    Apr 27, 2009 | Thomson Thompson Center Muzzleloader Rifle...
    Muzzeloader won't fire ,new nipple,caps fire,nothing is pluggedl.
    its not a bullet problem you can shoot that out of your hawken muzzeloader your problim is getting the pan powder to ignight your powder in the barrel you need to make shure powder never got damp now on your hawken you have a removable torch hole were the pan powder lays take that out and just drill the hole out bigger not much just a little bigger in the part you took out this will make your hawken fire without any problem i have done this to many hawken rifles and its like night and day how it fires hope this helped ya out and good luck
    Dec 11, 2008 | Thomson Thompson Center Muzzleloader Rifle...
    Elevation knob is topped out i still need to go up about 5"
    Remove the top of the rear scope ring and place a plastic shim UNDER the scope.I use plastic because it is impervious to weather.I usually use clear plastic from a blister pak but even a shim cut from a plastic milk jug will work.I just cut it to size with a pair of scissors.I have done this many times to correct for the mismatch in the height of the rings.
    Dec 08, 2008 | Nikon ?? 3 - 9x40 mm APG Omega...
    Non-muzzleloader use
    I never thought about it but I don't see why it would not work.The only issue would be recoil, and recoil is recoil.I am considering putting a scope on my Sharps replica and only wish it to look authentic.Good Luck
    Nov 29, 2008 | Omega Nikon Muzzle Loader Rifle Scope...
    Thomson Thompson Center Omega Z5 Rifle - Blue/Black Logo
    414 people viewed this question
    Top Thomson Sport & Outdoor - Others Experts
    Are you a Thomson Sport and Outdoor - Other Expert? Answer questions, earn points and help others
