SCHEMATIC DIAGRAM FOR JBL ENCOUNTER 2.1 - Computers & Internet
Diagram
http://www.schematicsforfree.com/archive/
schematics
http://www.schematicsforfree.com/archive/dir/
patent directory
i was unable to locate the specific diagram for jbl speakers or any speakers
you might be able to find it
hope it helps
May 07, 2012 | JBL CREATURE II Computer Speakers
I have JBL encounter speakers and i want use them with my Mac, when i plug nothing comes out (sound)
Wanted to clarify , if the you plug in a headphone are you are able to get the sound from them . If yes than , you might need to check the connection on the speakers. If the headphones are also not working through the audio jack . You would have to check the following
1. Check if there is any external damage to the audio jacks both on the MAC and the JBL connector
2. Check if the sound properties on the MAC are configured correctly
3. Check if the sound card drivers are installed correctly.
Thanks for using fixya
Proton
Mar 13, 2012 | JBL Encounter Speakers Computer Speakers
I can not increase or decrease volume on my JBL encounter speaker system
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
hope this helps
Apr 11, 2011 | JBL Encounter 2.1 Computer Speakers
Have a JBL Encounter 2.1 Multi Media Speaker System need to find a power lead and speaker jack for it im resident in uk and need voltage requirements regards
you shouldnt have to worry about a speaker jack for it. it should work anywhere and a simple usa to uk power adapter will work for you it just changes the plug type and up or downs the voltage (i cant recall if uk is higher or lower then the u.s)
Mar 23, 2011 | JBL Encounter 2.1 Computer Speakers
This thing isn't build with jbl speakers! cuz i repire this sub 2 weeks a ago this sub was build by some kind of unbrand chines speakers..so any one know about that..otherwise i heard jbl use onl JBL brand...
JBL is obviously just putting their name on your product. Just the way it is. They put their name on it, but use inferior parts. It is cheaper for JBL to have other folks make the stuff.
Oct 07, 2009 | JBL Encounter 2.1 Computer Speakers
I couldnt adjust the volume with the JBL encounter speakers when i plug it in my laptop, but when i plug it in my iPod, i works perfectly... Can anyone help?
If you are using windows then go to
  • control panel
  • open-> sound and audio devices
  • a window will open showing your sound configuration
  • towards the bottom of that window, you would find speaker volume-click it
  • on the next window, click the button saying restore deafults
Now check the sound.
Hope, this helps.
Otherwise tell me.
Mar 29, 2009 | JBL Encounter 2.1 Computer Speakers
Bloon Fuses!
You don't need schematics to replace the fuses.
Open the speaker unit by unscrewing the back. The fuses are located near the on/off switch assembly. Replace them and screw the the unit back together.
To avoid blown fuses, try lowering the volume.
Aug 18, 2008 | JBL EON 15-G2 Powered DJ Speaker With EQ...
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Computers & Internet Logo
David Payne
David Payne
