Question about Vacuums
Foodsaver v2460 would sometimes not completely vacuum out all the air. Now it vacuums nothing. Machine is fairly new but not in warranty. Can it be fixed
5 Suggested Answers
Agent Don
  • 310 Answers
SOURCE: agitator brush wont spin once vacuum is placed on floor
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=618889&thid=573865
Agitator brush wont spin once vacuum is placed on...
Posted by coral7980 on May 05, 2008
This vacuum has given me nothing but problems!!! The newest problem is the brush. I have changed the belt several times, it is a new one now. The brush spins, but as soon as you set the machine in place to start cleaning, it stops and burns up the belt. I need help. I don't want to buy another vacuum!!!
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
The problem that I can see id that you may have a bad brushroll that doesn’t spin freely, and has either bushings or bearings, a simple test is that take the brushroll out of the vacuum, set in on end and spin the brush, does it spin freely or does it stop, the next thing is to turn the motor pulley on the motor, it should spin freely as well, if either one is not spinning freely or easy then there is your problem, or make sure you have the correct belt size and that is a genuine eureka belt instead of a replacement belt for that model, those are the 3 things that should work for you, if the vacuum is less than a year old – take it to a factory authorized vac dealer and if it is the motor and pulley, it is covered, usually the belt and the brushroll are wear items and are NOT covered, some places however might cover the brushroll as a courtesy to the customer. So feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Don – The Vac Man
Go Ahead. Use Us.
Posted on May 06, 2008
  • 55 Answers
SOURCE: Eureka Altima Bagless Upright Brush is not spinning
You probably just have a broken belt. The belt needs to be changed about every 6 months regardless. I believe yours takes a style EXT U(Extended life upright), or a regular Eureka "U" belt works fine too.
Posted on Nov 24, 2008
  • 8 Answers
SOURCE: over heats and shuts off, wont start again untill
This unit need disassembly and internal cleansing. Yep, it's dirty inside. The motor probably is dirty also and should be blown out with an air compressor.
Posted on Nov 10, 2009
Coleman37
  • 337 Answers
SOURCE: Vacuum cleaner not picking up and sometimes spits ouit dirt
Check to see if bag (or if not bag then chamber is full).
Check to see if filter is clean.
If your vacuum has a bag, check to see that it is properly mounted.
Sorry I couldn't be more specific but it would help if you would specify what type of vacuum you have, whether you are using the hose or just the floor part, and where it is spitting the dirt from.
Hope this helps. If not, let me know the answer to the above questions and we'll go from there. Good luck!
Posted on Mar 13, 2010
Cannot get it to vacuum.
Does it try to vacuum but never flattens the bag? Make sure the bag you are using is completely sealed on the opposite end. Otherwise, the seal on the sealer is probably allowing air to leak into the sealer. If it has a foam sealer, I've found it sometimes helps to run the foam sealer under water, squeeze out the excess water, reinsert the foam sealer (make sure it is seated all the way) and then try again to seal the bag.
Mar 07, 2016 | FoodSaver Food Saver Vacuum Sealer...
Seals but won't draw all the air out. Seals fine
That could be a bad foam seal not completing suction, A piece of debris that got sucked into vacuum line and or in pump, or in some cases a crack in a elbow or pump housing.
Jan 22, 2016 | FoodSaver Vacuum Sealer Kit V3460
MY FOOD SAVER HAS BEGUN NOT VACUUMING. IT SEALS BUT DOES NOT GET THE AIR OUT LIKE IT USE TO
Does it hum as though it's vacuuming? If not, it's probably broken - the vacuum pump is out. It's cheaper to get a new one than attempt to get the old one fixed. If it hums, then replace any hoses you find or the foam around the drip tray.
Dec 06, 2014 | FoodSaver V3230
Foodsaver V3840 Won't vacuum air out and wont go to seal. A label states the seals are not removable. Do you know how to fix?
you are not using a "good" bag. Make sure there are no holes and that the bottom and sides of the bag are properly sealed. It will run all day and not pull the air out if the seal is broken anywhere.
Sep 11, 2014 | FoodSaver V3840 Vacuum Packaging System
Foodsaver vacuum sealer tray full light
Clean the two little contacts on the tray. Make absolutely sure there isn't anything across the two wires that run the length of the tray. It doesn't take much to trigger the light.
Jun 03, 2014 | FoodSaver V3880 Vacuum Sealer - The Master...
It won't seal it doesn't get hot it vacuums ok
There is a heating element in your unit that seals the bags. Most of the units you cannot replace the heating element. The company is pretty good about warrantying the units. They go by the number on the plug to tell if the unit is still in warranty. Give them a call. 877-777-8042
Jan 19, 2014 | FoodSaver V2222 Vacuum Food Sealer
Why there say tray full red light
The tape trick didn't work for me. Had to cut the wires. Works for now.
Sep 27, 2012 | FoodSaver Smart Seal Vacuum Sealer V3825
Vacuums Logo
182 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
