Dishwashers
Problem for Dishwashers
Generic problem for all Dishwashers
The water does not drain
By spaycritter on Jul 08, 2008
the water does not drain out.it's clogged
Same Problem
Sep 02, 2008
-   Hi
I appreciate the work you are doing. Have above DW for approx. 8 years. I had the melted soldering on the heating relay and fixed it in 2003. The machine was running just fine all the time. Now suddenly the DW doesn't drain. The pump's impeller runs free and I miss the relay click from the control board. Any idea? Another soldering problem? Or bad chip? Or relay driving semiconductor/transistor? Or any other signal detector that prevents the drain pump to run at the beginning of a cycle?
Thank you in advance -   oldironman64
Aug 06, 2008
-   Bosch dishwasher is clogged and i dont know how to solve this problem wiht out plumber s help as it will cost me alot .-   Guest
Solution #1
posted on Sep 02, 2008
Not Rated)
oldironman64
Rank: Apprentice
Rating: 0%, 0 votes
I checked the control panel, it turned out to work correctly, the drain pump has got the juice. Then I opened up the coverabove the drain pump (1 screw, below the drain filter) and God forbids, I found a chicken bone blocking the impeller of the pump. How it could get beyond two filter levels? Somebody must have opened the filter without looking if there was anything on the top of it!
So when the drain doesn't work next time, look for the most obvious: some garbage beyond the filters.
This was a BOSCH SHU5305UC/U12 type DW and until now it is fine.
When I checked the panel, I found that the power connector (the only triple one on the left side) had some burn trace on the black wire connector. It must be an erosion due to high amperage for the heating. I'll have to get soon replacement because erosion will continue until the whole DW will stop.
Was this helpful?
Yes
No
Popular Solutions for Dishwashers
Questions and Unsolved Problems for Dishwashers
Answer
kitchen aid model number kudco31vbs is it good
Answer
who makes the best trouble free dishwasher today that is 18" wide
Answer
after my Jenn-Air JDB1100AWS fills with water, wash proceeds with loud grinding sound. thoughts?
Answer
Main cup doesn't close- any suggestions??
Answer
i HAVE A ZANUSSI AQUA PLUS DE6755 AND IT HAS STOPPED HEATING UP THE THE WATER
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dishwasher Experts
Top Dishwasher Repairmen
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
