Question about Sharp Actius GP20 (PC-GP20) PC Notebook
Screen has gone out, have one that works, how much trouble to switch the screens??
  • Anonymous Dec 31, 2010
    Thanks, but the one with good screen has a bad on/off button.
    Genius:
  • 1,288 Answers
Normally, this is just a matter of unplugging the battery, removing any small rubber covers on the screen bezel to reveal the screws beneath, unscrewing them and unsnapping the bezel off the lid (carefully). You need to have a good look to see if there are any other screws as sometimes it is necessary to remove the switch panel to get to the bezel bottom.
After this, release the screen retaining screws and let the screen hinge forward, undo the very small screen bracket screws at the side of the screen (4-5 each side), then unplug the multipin cable from the screen and the pink/ white or bluw / white inverter lead. Re-assemmble and test
Posted on Dec 31, 2010
    Sergeant:
    Novelist:
  • 179 Answers
Quite a lot of work, actually...and tedious.
If you have a similar machine with a screen that works, you may be better off just switching the hard drive to that machine.
Hope that's helpful.
  • graeme ian hunter Dec 31, 2010
    Depends on whether they have a spare whole laptop. Even for a beginner, with care the whole thing should take no more than 30 minutes
  • Elaine Albertson
    Elaine Albertson Dec 31, 2010
    Maybe 30 minutes...
    Considering his reply about the bad on/off button, though, switching screens (assuming they are identical) is practical, Graeme_Ian_H gave a good overview.
Konica minolta bizhub c350 c-0500 display
Fuser warm up failure. Most likely this will require a service person to repair but here is the reset procedure you can try yourself. If it does not reset then you will need a service technician.
Turn off the main power switch located on the right side of the copier, NOT the one on the edge of the operation panel. Press and HOLD the utility/counter button on the control panel. While holding this button down continuosly turn on the main power switch. Continue holding the utility counter button until the screen changes to a blank screen with just a box that says "trouble reset". Now release the utility/counter button and touch the trouble reset box. Now turn off the main power switch for a few seconds then turn the machine back on. The code should be gone but if a problem remians then the code will come back within 30 seconds.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Konica Minolta DiALTA Di200 Copier
Blank LCD screen on Compaq n800c laptop
First instinct would tell me that your LCD has gone bad. A refurbished replacement LCD should run around $300-$325 give or take.
Keep us posted, good luck
God Bless
-Carlos:
Jul 09, 2009 | Compaq Evo N800c Notebook
When i turn the lap top on it powers fine but no screen
Connect an external monitor to the laptop. You'll need to use your function keys to switch to the external monitor. If this works, your screen, inverter or screen fuse(if it has one) have gone bad. If this is the case, take it to a reputable repair person.
Mar 29, 2009 | HP Pavilion dv8000t Notebook
Display screen not working.
Either the display itself (electro-luminescent) is defective, or the cables/connectors hooked to the display may have come loose. It should not be too much trouble to open up the case and have a look inside. Go for it.
Feb 28, 2009 | Panasonic SC-HT17 System
Compaq V2000 Display blacks out
sounds like the backlight has gone....test with an external monitor....if the external monitor works without any problems...the backlight has gone...better to get a professional to do this as its kind of fiddly and involves taking the screen apart
Dec 22, 2008 | HP Compaq Presario V2000 Notebook
Motorola W220 Grey screen
its connecting cable is gone replace the cable and its going 2 eork fine. reply me
Apr 19, 2008 | Motorola Mobility W220 Cellular Phone
Dell E196FP TCo99 Monitor screen problems
The screen colour changing is apparently an auto test procedure on the monitor and was prompted by a fault with the monitor not automatically shutting down when the computer is shut down. The settings on the monitor have been adjusted to rectify this and the problem is now gone.
Apr 06, 2008 | Dell E196FP 19" LCD Monitor
Always trouble shooting when im opening my msn
choose last known good configuaration that worked
Mar 06, 2008 | Computers & Internet
Trouble Loading & Not Registering To TV
I can't say 100% but it sounds similar to the problem I had with the same model . The sleep mode in the on/off switch had gone bad and a new switch fixed the problem. It was about $42 to rtepair at my local electronics repair shop. Hope this helps.
Jan 30, 2008 | Yamakawa DVD-218 DVD Player
Blank screen
Sounds like all of you are having trouble with your LCD either going out or already gone out. U will have to send it into Casio to have them fix it.
Oct 30, 2007 | Casio Exilim EX-S600 Digital Camera
Sharp Actius GP20 (PC-GP20) PC Notebook Logo
50 people viewed this question
Top Sharp Computers & Internet Experts
Tony
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
