Question about Sony PlayStation 2 (PS2) Console
Playing Madden11 and cannot control the pkayers. Seems like in auto mode. How do I correct?
  • 943 Answers
You have to make sure that you set your controller in the right mode either as player one or player two. It is possible that you have been making the mistake of not setting your controller as a player on either side and as a result, the game is detecting your controller as an inactive controller so it prepares a game between two sides of the CPU.
You can also make sure that your controller buttons(analog or digital) is working properly so it does not become a case of stuck controller buttons.
Another thing you might wan to watch out for is for the settings that are set to control the players to be in the right mode and selection that would suite your kind of play. For example, the game might have been set to move the players with the digital controls while you are trying to use the analog controls to move the player. This is because for almost all 2011 sport games that have been produced by EA have currently undergone controller review and changes.
Posted on Dec 31, 2010
Tape In light flashes every ~0.8 seconds even though no tape in there.
You have got yourself into a tricky mess there. The mechanism was set up in a certain way. When you extracted the tape, it sent the mechanism into the wrong position. There is also a switch called a mode switch that is linked to the mechanism and the electronics of the video. This switch tells the electronics what mode the video is in - IE: fast forward etc. This is now out of position and the whole mechanism needs to be set up in the correct position, assuming there is no faults, and so does the mode switch.
However the bad news is that unless you have the service manual you have little chance of setting it up right. Most video's for example are NOT set up in the eject position for a start, so unless you have the instructions, you will never get it to work right.
Jul 11, 2015 | Emerson EWV601B VCR
Orbit 57004 sprinkler controller does not turn on valves in Auto mode. Works OK in manual mode. All settings were checked carefully and repeatedly and verified by Orbit tech assistant by walk through
I am experiencing the same problem with my Orbit 57004. Did you ever figure out what was causing it not to start in "Auto" mode? he solutions above are not panning out for me.
May 12, 2012 | Hardware & Accessories
When I shoot in arperture priority my photos come out blue. All ok in auto come. Canon d40x
The priority modes often give you more control over more features than auto mode does. In auto mode, the camera is deciding your white-balance, and may not let you select a white balance setting even if you wanted to. In aperture priority, your camera will give you control over white balance. Switch to aperture priority, then check your white-balance (wb) mode. You should still be able to select "auto" within these settings if you'd like, but feel free to play with the various settings to get your ideal photo. Good luck!
Aug 15, 2011 | Cameras
Had madden11 since nov,still cant play my friends online
Sounds silly but have you all got the same xbox live updates and Madden '11 updates?
If not this is the solution
Jul 05, 2011 | Video Game Consoles & Games
I video remote control planes and I am finding that the video is blurry. I have altered a few things but it still seems to be bad quality when I play back. I took auto focus off but that just made it...
Well you may be on digital zoom mode, this simply will not be clear with fast moving takes, keep to the Opt zoom mode and with on tripod this will put focus better, keep camera still, move and it will blur.
Jun 14, 2010 | Sony Handycam DCR-SR40 Camcorder
My VCR does not play properley
Hi
Please cheek that the input that you are using ie scart (av1 or av2) are set to vcr this should be able to be corrected with the remote control in the set up mode. regards windyhouse
Mar 31, 2010 | Sharp LC-26D43U Television
Plug and play controller usb does not recogninize
Pls check that the USB controller and Plug and Play mode are enable or not in your system BIOS.If not pls enable it.and select Legacy USB support in Auto mode.If still issue coming then connect the USB device in another port.
Nov 18, 2009 | Video Game Consoles & Games
Uverse remote connection
This process should be used if the code for the device is not listed in the Manufacturer Code List.
  1. Turn on the device you wish to program.
  2. Point the remote control at the device.
  3. Press and hold the Mode key (TV, DVD or AUX) you want to program. Without releasing the selected Mode key, press and hold the OK key simultaneously
  4. Release both the Mode key and the OK key at the same time.
    All the Mode keys will flash twice indicating programming mode.
  5. Enter code 922 by pressing the number keys on the remote control. The selected Mode key will flash twice indicating correct entry.
    Note: This next step is For AUX Searching only, press and release the PLAY key then press:
    • 1 for VCR
    • 2 for Receiver/Tuner
    • 3 for Amplifier
    • 4 for Home Theater In The Box (HTIB)
    All the Mode keys will flash twice indicating correct entry.
  6. For AUX only, press and hold the PLAY key and wait until the device turns off, then release the PLAY key.
    • The REW key can be utilized to go back through the codes one at a time.
    • The FF key can be utilized to move forward through to codes one at a time.
    • Press the PLAY key to resume auto search of device codes.
  7. To save the code, press the ENTER key on the remote control (bottom right) or press the EXIT key to return to normal operation.
    The selected Mode key will flash three times and return to normal operation.
  8. If no valid code is found, the red light will flash two times and the remote control will return to normal operation.
  9. Turn the device back on using the remote control. If this doesn’t work start over or try Manual
  10. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the AT&T U-verse TV Receiver, press the AT&T Mode key.
May 24, 2009 | Durabrand DWT1905 TV
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Remote
    connect via usb to recharge it.
    Nov 28, 2007 | Sony Playstation 3 (PS3) Console
    Sony PlayStation 2 (PS2) Console Logo
    48 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Zhenya Ogorodnikov
    shaun taylor
    marley mcelhinney
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
