Question about OMNI Conversion Kit; Converts To A 5140 Watch
I need a manual for a watch SV F-IAFGI 377 - OMNI Conversion Kit; Converts To A 5140 Watch
What button Battery is used for GapKids digital watch ?
generally a 364 or a 377 would work. The 377 is a slightly higher but will work as well.
hope this helps, gabe.
Oct 20, 2014 | Watches
Elgin watch battery
The 377 battery is located behind the CR2016 battery. You will have to completely remove the motherboard to change out this battery that runs the analog portion of the watch.
Apr 12, 2014 | Elgin Watches
Watch battery
Hi Jason,
About 70 percent of watches take 377 batteries but there is no way to know until you pop the back off. If you take a picture of the back i can instruct you how to get it off. thank you ! Lisa
Nov 07, 2013 | Fossil JR9990 Wrist Watch for Men
What size battery do I need for an Anne Klein 10/4838-9 watch? There is also 753H printed on the back of the watch.
You most likely will need a 364 or a 377.
You may even need a 379. The only way to tell is to either open it up or search online if someone is selling the watch with the "Specs" (specifications)
Aug 11, 2013 | Anne Klein Watches
What is the correct battery for replacement?
you need to take a pocketknife and look for a lifting spot around the outside edge of watch and carefully pry the back up. Most likely it is a 377 or 364, but you will not know until you look.
Aug 29, 2011 | Anne Klein AK Gold Tone Bangle Watch...
What battery is needed for this watch wen it goes out
mcdevito75 here, Possibly a 377 or 364, look for a small watch repair shop, they can tell for sure as I would need the watch here with me in Florida to tell for sure.
Jun 20, 2010 | Kenneth Cole Black Face with Stainless...
Size 377 battery wont go in - need to unscew something?
I presume that a 377 battery is the same number as what came out. Sometimes there is a small piece of metal that is a strap that helps hold the batter in. Usually, then there is a very small screw that you have to loosen to remove the plate or just move it a bit to get the battery in. Be sure that the battery is not upside down from the way that the original was placed in. Also when putting in a new battery be sure that you don't use metal tweezers to hold the battery as it will short the battery and discharge it. Use your fingers or plastic tweezers.
Oct 30, 2009 | Kenneth Cole KC1104 Wrist Watch
OMNI Conversion Kit; Converts  To A 5140  Watch Logo
87 people viewed this question
Top OMNI Watches Experts
Ansel Alberto
Ansel Alberto
Are you an OMNI Watch Expert? Answer questions, earn points and help others
