Question about Ford Garden
Hi, my ford 2000 gas wont run without choke. Was fine this morning, now wont run, any ideas? It seems to be getting fuel to carb, but it has some weird fuel pump beside a sediment bowl, could this be a problem?
  • 24 Answers
If it won't run without choke, then it's not getting enough fuel. You probably either have a clogged jet in the carb, or you have an air leak somewhere that's allowing air to dilute the air/fuel mixture.
Unless a gasket suddenly died, fell apart, and left a gaping hole, a sudden failure like that is probably a clogged jet.
I'd clean out the bowl on the carb and hose the jets out really good with carb cleaner. If you have it, hit the jets up with some compressed air, too. While you're in there, make sure the float isn't sticking and the fuel flow is good.
Posted on Dec 31, 2010
Hi, I have a 13.5hp Briggs & Stratton motor which starts and will only run on choke slow rpms and mild smoke.
check the point where the fuel hose goes to the fuel tank
there is very fine filter in the hose that could be blocked preventing full fuel flow
only running on choke indicates insufficient fuel flow
Apr 02, 2017 | Briggs & Stratton Garden
I have a 1995 Suzuki King Quad (LT-F4WDX). Wont accelerate when warmed up.
did you adjust the valves? check and make sure the fuel pump is putting out enough fuel, way past time to replace it. check your voltage too, the regulators in those are famous for dieing.
Dec 22, 2016 | ATVs
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
The throttle needs to be held in order to get it running, seems to be flooded when choke is used on a cold start. Once it is running it runs fine for the day. Just the morning start up is the problem....
SOUNDS LIKE TUNNING PROBLEM..TRY RUNNING IT ON A LONG TRIP WITH THE HIGHEST OCTAIN YOU CAN FIND PREMUM FOR SURE AND SEE IF THAT CLEANS IT OUT IF NOT YOUR GOING TO HAVE THEN CLEANED BY SOMEONE WHO KNOWS WHAT THEY ARE DOING..YOU ONLY NEED TO CHOKE IN COLD CLIMATES..TRY ONLY HALF A CHOKE INSTEAD OF FULL CHOKE..THE CHOKE DUMPS RAW FUEL INTO THE ENGINE FOR COLD START UP ONLY..MAYBE CHOKE NEEDS ADJUSTMENT..
Mar 12, 2015 | Motorcycles
My 1988 2.3 liter mustang will not start after sitting overnight
Being that this vehicle is a 1988 it is most likely still using an electric choke. When your vehicle is cold (even just not warm enough) it needs a richer fuel/air mixture to start which is what the choke is there for. When you turn the key the choke will automatically shut so the suction from the engine will pull fuel from all circuits of the carb. Anyways.. long story short for some reason it would seem your choke isnt closing as it should. This is generally just a hot wire thats connected to your carb.... maybe a short maybe its stuck open for some reason.. idk but that is where you should focus your attention. Hope this helps.
Dec 27, 2013 | 1988 Ford Mustang
I have cleaned the gas tank, fuel lines and rebuilt the carb. It now runs but just at idle almost in the choke position. I have played with the throttle and it wants to die when I move it to normal ru
if it runs only in choke it sounds like its lean (choke reduces airflow and gets back to a mixture it will run on.....just). It could just be a small bit of crud in the carby jet. You cleaned the fuel system.....did you install or replace a fuel filter? sometimes cleaning the tank and lines stirs up stuff that needs to be filtered.....even though you may had cleaned and rinsed out a lot.
Nov 22, 2013 | Electrical Supplies
I have just aquired a Moto Guzzi 1100 sport 1997 (carb model).The bike has been standing for a couple of years. I am trying to get it to fire up, having changed plugs and caps, but the choke lever seems to...
If old gas sat in the carb. for more than a month it starts to dry up. As it drys up it leaves behind a varnish like film that stops up some very small ports and pin holes inside a motorcycle carburetor. It is also very hard to get out. You can try this before you pull the carb. for a full cleaning. Use a product called Seafoam, get as much gas out of the carb.s as you can. use a turkey baster and force the seafoam into your carb. fuel line that you take loose from the fuel tank. Let that set for say 1 or 2 days. then hook up the fueltank with a mix of good gas and seafoam, (not a lot but enough to start it up. Move the cycle outside as the seafoam will make a lot of smoke if it does start up. If that does not clear up the problem you may have to pull the carb. and remove the blows to clean the inside. If you have to do that do not DO NOT MESS with any adjustment screws. Just take the carb. bowl off. Do not mix up any internal parts. It is best to work on a large sheet so if you drop a small part you can find it, you do not want to be missing some tiny spring or screw. Hope this Helps Fix Ya Up..
Sep 04, 2011 | 2000 Moto Guzzi Sport 1100 i
Engin wont stay running
was there trash in the old filter? If so let it be your guide on what to expect.Clean the carbs out, get the trash out of the needle and jet and the needle seat. Also make sure the tank is clean too.You do not have to remove the carb to clean it,just the airfilter housing and fuel bowl.Then you can remove the float the float-needle and jet. Remember no fuel will run out of the tank unless fuel cut off has a vacuum on the small vacuum line going to it.
Apr 20, 2010 | 2000 Harley Davidson XL 1200 C Sportster...
Yr 2000 thundercat, won't idle unless choke fully on
When you cleaned and balanced what did you do and how? Did you clean out tank? Tank filter? Any petcock debree. If this does not work please get back at me for further info.
Jul 07, 2009 | 1999 Yamaha YZF 600 R thunder cat
Engine runs, but it will not rev up past 2000-3000 rpms,
are you turning the choke off after its warmed up? most will not run with the choke on and warmed up.
also try running it with the gas cap open to see if you have a vent issue in your tank. if air can't get in, then gas can't flow.
if not a choke or vent issue, then try this. turn the petcock off and then disconnect the fuel lines one at a time going into the carb. start with carb fuel line #1 disconnected (and the rest connected) and in a coffee can, turn petcock on and ignition too. fuel pump should come on momentarily and inject some fuel. see how the quantity looks. reconnect the line to carb #1 and repeat for carbs #2 - #4. your looking for a decrease in fuel to a couple of cylinders.
if all looks fine, i would then focus on the carb floats & jets. have the carbs been off for a good cleaning lately? modern fuel breaks down quickly and could cause a gumming condition in the carbs. spraying the sea foam or carb cleaner into the carbs is bypassing the everything in the carb bowl (but it means the spark plugs are ok) so there could be an obstruction. i would look there first.
if uncomfortable removing the bank of carbs, you can try a quick fix first. with the petcock closed, open the drain screws of each carb and let the gas drain out. go and buy some yamaha carb cleaner (liquid in a black bottle) at a yamaha motorcycle dealer. mix it in a separate container with gas as recommended. close the drain screws on each carb. pour the mixture into each fuel line feeding the carb and let it sit overnight. DO NOT POUR THIS MIXTURE INTO YOUR TANK. its not a fuel additive, but a cleaner that will not harm orings or gaskets, but it will not ignite with a spark plug. open the drain screws the next morning and let the mixture pour out. reconnect the fuel lines to the carbs and test drive it.
if that didn't work, then removing the carbs for a good cleaning is my next step. good luck.
Jan 25, 2009 | 2002 kawasaki ZX-6R
Garden Logo
247 people viewed this question
Top Ford Garden Experts
Dennis Key
Dennis Key
fordexpert
donald boissonneault
Are you a Ford Garden Expert? Answer questions, earn points and help others
