Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No Suction I have very little or no suction on the cleaner. It suctions o.k. with the hand tool, but not the upright cleaner.
    President:
  • 1,673 Answers
Between the top edge of the clear noozle and the lip of the tank that sits on it, there should be a black oblong gasket, if missing, you will have no suction there. The other is the filter on the tank lid, is it clean?
Posted on Sep 18, 2008
Dirt Devil upright has too much suction.
In a world where most people wish their cleaners had more suction, yours is a rare complaint indeed. Upright cleaners in particular are complaint-worthy as they soon tend to lose suction. It would be good to read more about the reason for your complaint?
Ideally an upright will have enough suction to lift the carpet from the floor a few mm and trap it against the mouth of the brush housing so air can be drawn through the carpet helping to lift out dirt so the brush can work more efficiently. An upright that is working correctly is much harder to push along and as they age they tend to be easier to push as they lose efficiency.
Most cleaners are fitted with at least one filter and they do rob them of suction. Some people remove the filters to improve the suction. Perhaps your cleaner has one or more filters missing.
May 06, 2017 | Dirt Devil Vacuums
Doesn't seem to have much suction when I put my hand under the head. Have cleaned both the filter and the mesh screen
Check the suction from the hose for rge tools see if there is suction
also check to see if there is a obstruction on the short hose to the nozzle
May 16, 2016 | Hoover U5140-900 Widepath Bagged Upright...
Hand held vacum suction stopped after 1st use. Was working fine, suction does work if onfloor but won't once turned to tool
go to the web page and see instructional video and maintenance help
http://www.bissell.com/how-to-videos/
God bless you
Jul 19, 2012 | Bissell 2X Proheat 9200 rug cleaner
My attachments tool has no suction. I made sure I have selected tools and I cleaned the lint filter. There is definitely suction in the machine, but it does not come through the attachments hose.
Check the attachment hose for any hindrances like clogged with dirt or object. Also a big hole cracks in hoses will cause suction to divert it outside. Clean the machine to make sure it will provide suction powerfully. Regularly clean it and you will assure it's will perform better.
Thanks for asking.
Jul 17, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
Can't get my bissel steam cleaner to sucktion
Check on board switch for tools only or vacuum, is switched to vacuum, as majority of vacuum suction power is diverted to hose/ hand held devices. See if vacuum hose has suction as well? The unit may be clogged with carpet fibresas well and the unit may have to be taken apart and cleaned thoroughly.
Apr 16, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell ProHeat can't get my cleaner to **** any water back up.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
iup
Jan 06, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a Kenmore Progressive Inteleclean Upright vacuum cleaner (with Bag) . It has good suction only through the hose now and none through the bottom for cleaning carpets. and, there is a noise like it...
Theres a little bendable neck that hose with suction plugs into. Thats the one thats clogged. You will have to fish it out by taking off the roller and clearing the clog.
Sep 22, 2009 | Kenmore Progressive Bagless Upright with...
Bissell 9500 2x deep clean (NO SUCTION)
Like everyone else (!) your lint filter is probably clogged. It is located on the top clear palstic section (the one with the dial to switch from tool to floor use) and is on the underside. It is a small (1 inch square) red plastic filter with a little door on it. Flip the door open and you will probably find it is clogged with hair, carpet fibre., etc.. Clean it out and you should have suction again.
Feb 27, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
MY BISSELL PROHEAT WONT SUCTION
heatman101
ffuutr
Jan 28, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
202 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
