Question about Nintendo Wii Console
All four reote lights blink but the ghame doesnt respond
  • 112 Answers
You must sync the remote. To do this first take off Battery cover of remote.(leave batteries in) Then press the tiny red button on the front of the wii console next to the sd card slot for 2 seconds. Look at the back of the remote. In the battery compartment there is a tiny red button that looks like the one one the wii. Press it and they should sync. Now your remote should work.
Please rate.
Posted on Dec 31, 2010
Clean light blinking
If the clean light blinks four times and then pauses and then blinks four times again and repeats, the problem is your pump motor. If there is water under the DW the pump clamp has probably failed and sprayed water onto and inside the motor. Call a certified Kitchen Aid repair service.
Aug 13, 2014 | KitchenAid Dishwashers
Sony trinitron 32 inch television model no. KV-32FS13 doesnt have any video nor audio and standby light just blinks about 4 times
Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check for any loose sodering points at the vertical output section.
Mar 27, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
97 Legacy Left key on. battery dead. charge battery and all four turn signal light blink, 4 ways not on. lights blink for while then stop. Engine will not even turn.
try disconnecting battery termainals for five seconds and try again if thats doesnt work check all fuse in car and under hood.
Oct 15, 2009 | 1997 Subaru Legacy
Blackberry strom and H710 pairing problem 0000 does not work? HELP
it is universal procedure to pair up all devices like this
first if ur hedset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth phone now go to ur phone switch the bluetooth ON and select search u will find ur headset with its model like H715 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
now u can try to talk thru headset make a test call any number for voulume control there are two buttons on headset on upper sie with arrows u can select them to increase headset sound
pls rate me well for help ! Fixya rating is encouraging !
Apr 28, 2009 | Motorola Mobility H710 Bluetooth Headset
Lost headset manual & code
Apr 25, 2009 | Motorola Mobility H710 Bluetooth Headset
Lost my instuctions...
first if ur headset is switched on switch it OFF by long pressing the main button in the centre it will blink blue light twice or thrice and will switch OFF after that u can touch any button it will not respond with blinking lights
Now press again that centre main button long press for like 10 sec until that blue light comes on and become STABLE when it is stable it means it is ready to pair up with any bluetooth device now go to ur PS sony switch the bluetooth ON and select search u will find ur headset with its model like H710 just select and when asked for pairing code enter 0000 Zero four times or try 8888 if it doesnt work , now u will see that ur headset light will start blinking and u will see a headset sign on the screen of ur mobile phone it means now it is paired up
Apr 10, 2009 | Motorola Mobility H710 Bluetooth Headset
Lights on the reote key pad flash but the door will not open.
You will need to call our technical support line on 0845 20 20 118
Dec 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Wd 52525 during power up the lamp red light comes on even after replacing lamp with new and good lamp?
press the menu and input/device on the set both in together and hold for 5 seconds to see if the led will blink a two didgit blink code such as 3 blinks a pause then four blinks for a 34 code. Then let me know. respond to this same post when replying.
Aug 12, 2008 | Televison & Video
Its happening to me...
Four blinking lights means one of your fans are dead. You need to find which one isnt working and replace it. It cost me $19 to order the fan and is an easy fix.
You have to take off the back cover and turn the tv on and see which one doesnt spin and replace it.
Jul 01, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
My sony tv doesnt turn on.
Hi, The blinking lights is an indicator of an internal fault. On some Sony sets, 4 blinks indicate a problem where the video is muted due to a component fault. Since this involve opening the set and doing electronics diagnosis and possibly component/board replacement, you may be better off seeking the services of a qualified TV repair professional. Hope this be of assistance/idea. Post back should you need further information. Good luck and kind regards.
Aug 26, 2007 | Sony KP-53S65 53" Rear Projection...
Nintendo Wii Console Logo
24 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
