Question about RCA Televison & Video
I HAVE A HDTV THAT IS ONLY 7 MOTHS OLD IT WILL NOT TURN ON, IT COMES ON FOR ABOUT 3 OR 4 SECONDS THEN SHUTS BACK OFF. I HAVE TRIED ALL THE TROUBLE SHOOTING TIPS IN THE MANUAL NO LUCK! I BOUGHT THIS UNIT AT WAL-MART (TURNING INTO A MISTAKE! BECAUSE NO ONE WILL SERVICE IT.)RCA HDTV R52WH74 IS HE MODEL NUMBER.PLEASE HELP I WANT MY TV BACK!
Slinteriors
  • 8617 Answers
SOURCE: we won a Sanyo hdtv
www.replacementremotes.com will have your remote. Just enter the model number of your set in the search box.
Posted on Apr 05, 2008
  • 399 Answers
SOURCE: Problem with convergence on the
its due to the faulty convergence. the stk convergence ic on the main board which controls the picture alignment is faulty and needs to be replaced to solve this problem.any tv technician will do it for you at a very negligible cost. nothing to worry.thanks.
Posted on Sep 16, 2008
SOURCE: HDTV R52WH74 TV WILL NO TURN ON
Okay, so maybe I can't solve it, but mine was doing the same thing and I called the TV repair man. After $500 (a new power supply board was installed) all is fixed.
Posted on Dec 30, 2008
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
pcHelperDesk
  • 9 Answers
SOURCE: When I push the power button on my RCA HDTV
Sounds like the bulb went out.
Go to http://www.purelandsupply.com/RCA-Projection-TV-Lamp.html and order a new bulb for under $200.
They are easy to intall; a screwdriver and 10 minutes.
Posted on Jun 24, 2009
RCA D52W20 HDTV TRIES TO TURN ON 3 TIMES BUT WONT POWER UP
remove all the electrical wire connections from the back of the tv .remove the power plug from the electrical outlet and wait for two minutes and replug the wire and then ckeck.it should work.
reply.
Oct 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Shut off tv on its own
Look into getting a new Power Supply Board. There is a good chance that you have 1 or more faulty capacitors on the PSB.
Apr 03, 2009 | Samsung HLN5065W 50" Rear Projection...
Sony Grand Wega KDF-60XS955 Picture comes on and then goes off.
You have a bad lamp. Sometimes when the lamp gets old, it doesn't fail and open like they usually do. Instead, the reflector gets cloudy, and instead of reflecting the light, it converts it into heat. As the lamp heats up, it draws more power, eventually to the point where the TV senses it drawing too much power and shuts down, going into a reset cycle. replace the lamp and use an original Sony lamp, as the aftermarket lamps are known trouble makers. Be sure to rate this solution. Thanks!
Dec 13, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Shuts self off
Press input and menu on the tv panel and hold both buttons in together for 8 seconds and let me know if the led blinks a two digit code
May 04, 2008 | Mitsubishi WS-65315 65" Rear Projection...
My Sony comes on then both sound and picture goes black.
After being on a little while, the screen goes black (no audio as well) for 20 to 30 seconds. Green light stays on. Then, picture comes back on and takes a couple of seconds to get up to full brightness. About 5 seconds or so after the video comes back, the audio returns.
Until this morning, has only happened a couple of times a day, now happening more often. About 3 times in last 20 minutes.
KDF-E55A20 is about 3 years old.
May 03, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV comes on predominantly red for 20 seconds then shuts off!
You most likely have a bad Red CRT, knowing the age of the set, I suspect all 3 are bad, thats talking $1200 to repair, I would call sony and see if they will do anything with it. (maybe pay for parts or labor?)
May 16, 2007 | Sony KP-51WS510 51" Rear Projection...
Televison & Video Logo
80 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
