Question about Onkyo TX-SV727 Receiver
Onkyo TXSV 727 receiver. Are ther fuses on the speaker outputs .
    Scholar:
  • 155 Answers
There are always fuses for the amplifier/ac power.unplug the unit from the wall and remove the outer rear shell. the fuses will be visible on the main board.( round glass cylinder looking type) I also attach a link for the user manual look at the trouble shooting portion. http://filedepot.onkyousa.com/Files/own_manuals/TXSV727om.pdf?CFID=1362117&CFTOKEN=34377102&jsessionid=f03011be29a0d4b5104c3fd4860483011321 hope this helps please rate.
Posted on Dec 31, 2010
Onkyo dr s2.0 DVD receiver has subwoofer output but no other speakers have sound. I have experience with electronics. Is there fuses for the preamps and power outputs separate from the main in ?
Hello Todd, I would not suggest trying to repair this unit yourself. I suggest an authorized service but it might be difficult getting parts. Thank you, Onkyo USA
Oct 03, 2016 | Onkyo Audio Players & Recorders
Onkyo tx-sr500. No output to surround speakers.
Need to be diagnosed my serv tech. This could be many thing. Most Onkyo receivers have 3 year warranty.
Mar 25, 2010 | Onkyo Audio Players & Recorders
I have 1 center channel pre-out on back of my kenwood receiver. how do i hook it to the inputs on onkyo m-282 amp and then to center channel speaker?
Unfortunately can't connect it that way. The pre out is only meant to go directly into an amplifier that has all of the same inputs (front/rear, center and surround), not a standard receiver. (Pre amp to amp only, not pre amp to receiver) If your Onkyo doesn't have all the same inputs as your Kenwood preamp has outputs you will just use your standard left/right outputs from the Kenwood to your Onkyo input (CD, Tape, Phono,DVD etc) then use the outputs (front/rear, center and surround) from your Onkyo receiver and connect directly to your speakers..
Jan 01, 2010 | Onkyo M-282 2-Channel Amplifier
How do I connect my Acoustimass® 5 Series III Stereo Speaker System to my Onkyo SR506 av receiver?
Well, first of all this speaker system is designed to give you a subwoofer where you do not have a sub-woofer output on your receiver/amp. However, that is not the case with the Onkyo. The way I would set it up (only because of the speakers you have) according to the Acoustimass Manual. You take the left and Right "Speaker" outputs to the Left and Right input on the Acoustimass and the speakers crossover does the rest. The Onkyo is designed to have a powered subwoofer so in this format you would just tell the receiver to turn off the sub channel which would tell the Onkyo to send the low end to LR. That should do it.
Oct 28, 2009 | Bose Acoustimass 5 III System
I own a TXSR 727 and the unit does not play and the message PROTECT appears on the face??
This means that the unit detected a problem in the output section and has shutdown to prevent further damage. Check for crossed speaker wires. If the unit continues to show the message with the speakers completely disconnected, then the problem is internal and is likely to be shorted output transistors. The repair cost for this will be in the $20-$50 range for parts.
Dan
Aug 04, 2009 | Onkyo Audio Players & Recorders
Onkyo TX-SV 727 PROTECT mode
Generally, this happens when there's a loose connection somewhere, either internally, or with the connections. It usually happens when the volume's too loud, and it tries to protect itself.
I'd suggest you unplug everything from it, check all the speaker wires, and then try turning it on, without any devices connected to it.
If it works, turn it off, and reconnect devices, one by one. That should fix it.
If not, it's likely that there's a loose solder inside, and it needs to be sent out for service.
Mar 19, 2009 | Audio Players & Recorders
Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Very low ouput from subwoofer preout
The problem was that some subwoofers (inluding my velodyne model) cannot process the LFE signals through the line level inputs on its amps, so the other way to run your subwoofer is to run the front left and right speaker outputs from your receiver to the speaker-level inputs on your sub, and then plug your front and left speakers into the soeaker level outputs on the sub. you have to set the onkyo receiver to "Subwoofer: No". that way the LFE signals are sent through the front speaker channels and you will get the same BASS output as if using the line-level input. O So yes it does require a bit more speaker cable, but it works fine now.
Mar 18, 2008 | Onkyo TX-SR304 Receiver
Onkyo 605 HDMI Sound
Change the setup in the Hardware control/HDMI/ HDMI Audio...
Jan 17, 2008 | Onkyo TX-SR605 Receiver
265 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
