Question about Samsung Washing Machines
Code "nd" on washer. just
    Top Expert:
  • Samsung Master
  • 9,472 Answers
If you got a "no drain" error yesterday, and cleaned the filter, did you check the drain lines? Also, make sure the waste pipe is correctly.
Posted on Dec 31, 2010
Samsung vrt nd or nb error code
ND is not draining, the washer probably has water in it and won't open. In which case you need to open the little tiny panel on the front of the washer and pull out the little hose and drain the washer and then clean our the filter next to the hose. NB means not balanced and the clothes have become unbalanced, move the clothes around and start it back up. If it happens a lot the washer is not on even ground and needs to be leveled.
Feb 18, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
A "nd" code displayed,
How to fix a Samsung Washer nd washer error code. You can make this repair your self and in most cases without parts.
Let me explain what the nd on a Samsung washer control panel means exactly. The nd error code stands for No Drain.
When this washer error code comes up the washer will not spin either.
To fix this issue you will need to slide the unit forward to access the pump if there is no access panel on the lower front.
If the clean out access panel is on the lower front bail the water from the washer and twist the filter head counter-clockwise.
If the front panel does not have the access panel the washer will need to be slide forward.
With the washer pulled out the back access panel can be removed. With the panel removed, the drain pump will be visible.
Remove the two hoses on the pump followed by the two 7/16 bolts that mount the pump down. With the pump off, you can now remove the debris inside.
Put the washer back together and test for proper operation.
If the error code comes back this means that the pump is clogged again or the pump has failed and would need to be replaced
Feb 27, 2013 | Samsung WF206ANS Front Load Washer
My washing machine is displaying the letters "nd",
ND is no drain error code for the FAV6800A and most Maytag machines.
Is there water in the Wash Basket. If not this could be a stuck Pressure Switch. If there is water in the Wash Basket then there could be a Drain Pump issue/Drain Line clog.
If you want to DIY I can help you.
Feb 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
I have an error code of nd on my washer
If your washer is beeping, and the display is flashing "Nd", your debris filter may be clogged. To check for a clogged debris filter, goto back of machine, look for little door at bottom remove cover and remove filter and clean
Dec 19, 2010 | Samsung WF306BHW High Efficiency Front...
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Someone put some heavy things in it and it stopped mid-cycle. We removed the heavy objects, and then attempted to drain the leftover water by putting it on "rinse and spin." It never really...
The ND error code on a digital Neptune front load washer. The ND code means 'No Drain' and it is probably just something caught in the pump. Sometimes this is a early sign of the pump going out or a control board issue.
Nov 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
My amana front load washer wont spin and is showing an "nd" error message. what does this mean and how do i fix it?
Hi
Thanks for using FixYa. From what I understand the error code ND means “No Drain issue”. You’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 28, 2010 | Maytag NFW7200TW Front Load Washer
Nd on washer
Hi Zandra,
Thanks for using FixYa. Error code ND means “No Drain issue”. To start with you’ll need to check for any restriction in pump assembly. It can also be due to a restricted drain hose or loose wire at pump. If after cleaning the drain hose the issue is not resolved then it means the pump has gone bad and unfortunately needs to be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have an error code "oe". in the past we have installed a new rotor, stator, wiring harness and control board. it was a load of towel, so i unloaded half and tried again. no luck. "oe"
Hi
Thanks for using FixYa. OE is a drain error, it flashes when the washer won’t drain within 10 minutes. TO resolve this issue you’ll have to check the drain pump filter for any clogs, also check the drain hose for any kinks and clean the drain pump filter. If still the issue is not resolved then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 03, 2010 | LG WM-2277HW Front Load Washer
Fav6800aww top load
Your drain filter is clogged with debris. Usually small items like dirt, paper, money, and much more. Clean the filter and you should be set to go.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 27, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
174 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
