Question about Microwave Ovens
Tappan microwave over the range tmv151f
Key pad reads 8888. I don't know how to reprogram.I removed plug from outlet then pluged in and tried again. I guess I need help in resetting the
oven
  • tfjohnson Nov 04, 2008
    my microwave has completely stopped. is this mocrowave poorly designed?
  • Anonymous Dec 06, 2008
    my microwave completely stopped too....
  • Microwave Ovens Master
  • 9,086 Answers
You can download your owner's manual free here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jul 08, 2008
GE Microwave (Over the Range: Model HVM1540DPBB) was stopping operation. It would beep, and the display would show garbage. I would unplug it, then plug it into the outlet, then it would display "keypad...
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 02, 2013 | GE Microwave Ovens
Tappan microwave has se or 5e on diplay wont push buttons
this a problem a dust in the control board keypads, You must open the keypad, and clean any connector with contact cleaner specially the ribbon cable or plastic and use pencil eraser for to fix the corrosion, dust, and try again.
Jul 08, 2013 | Microwave Ovens
Need help, trying to repair my Tappan Model TMV151F microwave.
That really sounds strange... It may be a door switch or a relay on the controller. (Internal contacts, not solder joints).
The service manual is here.
Did you take apart the bottom door switch to check it? Blurry but useful video here.
Under the circumstances, I would be most concerned with the bottom switch, but it wouldn't hurt to check the top one. It will not be the middle switch.
Jan 07, 2013 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    I have a Whirlpool Velos Microwave/convection over the range microwave. It is 2.5 years old. Tonight, after putting the fan on the unit is now indicating an Error message "F2H1-Hood Keys Stuck- the...
    Sounds like the pads that you push on the touch panel are stuck, will probably have to replace the whole touch panel. On units installed over the oven, they typically plug into an outlet in the cabinet above the microwave. if not, try flipping your circuit breakers until you find the one that shuts off the Microwave.
    Aug 24, 2017 | Microwave Ovens
    Tappan TMV151FS over range microwave starts to work and then dies
    Never run the microwave without a load (something to heat)!!! That kills the microwave generating parts.
    Sounds like a 'thermal' protect switch is activating after running. Make sure that (if the unit is mounted in a cabinet) that there is sufficient space around the unit for proper air flow and that nothing is blocking the vents. Try setting it on a counter top and heat something. If it works properly and doesn't shut off, the venting space is the problem. You may have to have the cabinet that it sits in redesigned for more clearance.
    Aug 19, 2009 | Tappan TMT104E1 Microwave Oven
    Triping breaker as soon as it is plugged in. can anyone tell me what usually is the cause of this problem when as soon as i plug the power cable in to the outlet, it would trip the breaker? no power to the...
    try pluging it in on another outlet with an extension cord must be a diffent cerciut breaker if it happens again the microwave has a short. if not its that breaker or outlet.
    Mar 31, 2009 | KitchenAid KCMC155J Convection/Microwave...
    Nothing on my touch pad works
    My microwave way manafacture May 2008. Nothing on the touch pad works.???. It just abrubtly stopped
    after a few seconds.
    We brought it in July or August
    Debbie
    Mar 27, 2009 | Maytag MMV1153A Microwave Oven
    Tappan microwave TMV151F will lose power during operation. I think around 3 or 4 minutes.
    The magnetron is overheating and causing the magnetron thermostat to open.
    Then when it cools, it closes the circuit and allows power through again.
    This is usually caused when the internal cooling fan is not running or by a magnetron that is failing.
    When I say internal cooling fan, I do not mean the hood vent exhaust fan which you can turn on and off manually.
    I'm instead talking about the internal fan which comes on automatically whenever you microwave.
    It is vital that the cooling fan runs, or the magnetron will be
    destroyed.
    It may also be a clogged exhaust duct or filter. Grease filters should be cleaned regularly and charcoal filters should be replaced (not cleaned) every 6-12 months.
    You can refer to your owner;s manual for that info.
    You can download most Maytag / Whirlpool / Tappan owner's manuals and installation instructions here.
    If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
    You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
    There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
    Dec 08, 2008 | Microwave Ovens
    Microwave Ovens Logo
    875 people viewed this question
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
