Question about Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5)
Only can use one accesory plugged into router at a time
  • 536 Answers
This is expected functionality for an Ethernet Switch.
This is not a router -- it is a switch.
A router is designed to share one IP address with many devices and provides its own DHCP server for your private IP LAN. When you try to use a switch in this situation, one of the devices will grab the one IP address that is allowed to be assigned by your modem and the rest will go without and not work on the network (as you have seen)
Take the switch back and exchange it for a router.
Make sure that the device is labelled as "router" or 'DSL/Cable router".
Sorry to be the bearer of bad news.
Thanks for using FixYa and Happy New Year!
Posted on Dec 31, 2010
  • af1mc36948u Mar 21, 2011
    On the face of DYNEX 5-Port 10/100Mb Ethernet Switch box... It avers: Allows multiple devices to link to a 100 Mbps Network. It would be in the BEST INTEREST of the consumer if DYNEX printed what devices, i.e. printers, scanners, etc. on the face of the box! NO PC listed as a device would clearify this switch is NOT for use with two or more PCs to operate from one ip address. Maybe, just maybe the box could clearify a router is needed when using two or more PCs on the same ip address. DUH... is that impossible for them to do?
I'm trying to locate the fuse for the accesory socket
It may be the one identified as CIG - for cigarette lighter, if you are talking about the accessory socket where you plug in phone charger.
Aug 29, 2012 | 2002 Mitsubishi Montero Sport
Serpentine belt diagram for 1994 Chevrolet G30
Model VANS G SERIES Engine V8 5.7L 350ci GAS FI N K
Multiple Accesory w A.C. - Routing
Multiple Accesory w/o A.C. - Routing
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 06, 2011 | Cars & Trucks
When i connect my battery pack outlet for my xbox it goes to red light and my xbox 360 won't turn on
Hello
1 unlpug power to x box,remove hard drive.
Plug x box back in and reinstall hard drive. Try x box.
2 remove memory cards.Try x box.if it works the memory card was bad.
3 Remove any accesories. Try x box.plug one acc back in at a time.
Sep 19, 2011 | Microsoft Xbox 360 Console
I reset my router and now the internet will not work.
You will need to connect to your router via a cable, then open your internet browser and type in the ip address of the router. You can find this by openeing a command prompt (programs->accesories) and type in ipconfig /all making sure there is a space between the g and the /, then press enter, you are looking for the internet gateway address, it may also be the same as the dns server address. (it will most likely look like 192.168.*.* obviously the stars need to be replaced by numbers relevent to your router, routers are all different so I cant supply those)
when you type this address into your internet browser window it should take you to your routers login page, username and password should have been supplied with the router. Once you have gained entry into the routers setup pages, you will need to put your login details for your internet account. (you should have recieved these from your internet provider when you initially setup the account. This should then allow you to connect to the internet
May 05, 2011 | Computers & Internet
I am trying to set up security on my wireless router, NETGEAR instructions say to go to HTTP://192.186.0.1 but I get an error message and cannot go further. Do you have a FAQ on this?
You need to make sure it is connected by Ethernet cable and go to address http://192.168.0.1
Username: admin
Password: password
If that fails try doing
Start > All Programs > Accesories > Comand Prompt (Right click and run as administrator for Windows 7 & Vista) > Type Ping 192.168.0.1
You are looking for it to say Ping Statistics
Send 4
Recived 4
Lost 0
That will tell us if your computer is communicating with your router correctly.
Apr 25, 2011 | NetGear WGR614 Wireless Router
I cant access to my router
maybe you router reseted to factory default.. then you will have to set up everything again.
Connect your PC with a ethernet cable to the router
1. Go to the commnad line (MS-DOS) Programs ==> Accesories
2. Type "ipconfig"
3. Take note on the numbers in Default-Gateway (something like : 192.168.0.1)
4. Open a web-browser
5. In the address bar type the number that you took note before.
6. Type in username and password the factory default one (sometimes is "admin" and in the password field leave it blank)
7. Configure it again.
If you need more help. . please give me more info and I will be glad to help you..
Mar 08, 2011 | Belkin F5D8236-4 Router
When the ignition is turned off, accesories remain on,
sounds like you may have a short. i would replace all the relays that control those items first to eliminate that.
Robert
Jan 03, 2009 | 2004 Pontiac Grand Am
Changed from broadband to wireless router and cannot get live to connect.
make sure that the setting on your router allows other hardware to connect to it. it may be blocked. (for example so ur neighbour cant run off your internet) also check that ur (xbox im assuming?) has the correct accesories to connect aswell.
Sep 13, 2008 | Video Game Consoles & Games
Conection inalambric
The XBOX 360 can only be connected via an RJ-45 ethernet wire to the router unless you purchase the wireless adapter. The adapter can be bought at any accessory store such as walmart, Target, Gamestop, etc.
Jul 27, 2008 | Microsoft Xbox 360 Console
Need to reset or set up my router
well...model numbers on computer and router would accelerate this issue.
Apr 29, 2008 | Computers & Internet
Dynex 5 Port 10/100 Ethernet Switch (DX-ESW5) Logo
488 people viewed this question
Top Dynex Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Dynex Computer and Internet Expert? Answer questions, earn points and help others
