Question about Garden
I have a Husky 26 gal. vertical air compressor (Model 660900AJ) The internal gauge will not read more than 60 PSI and out put gauge reads 5 PSI. What is the possible problem and how do I fix it.
  • 4234 Answers
SOURCE: air stapler leaks air through ''nose''
This sounds like one of the O-rings has failed. Yes it can be fixed. Check to see if HD has an O-ring kit for these guns. That kit will contain all of the O-rings as well as the lubricants for a total rebuild. That should resolve your problem.
Dan
Posted on Nov 13, 2008
  • 4088 Answers
SOURCE: HUSKY 26 Gallon Shuts Down After <75PSI!?
Possibly the pressure switch needs to be adjusted to reach a higher pressure. Trace the power cord into a box that also is piped into the pressure line from the compressor. If the pressure works itself back down again, use thread-locker fluid on the adjustment screw to hold it's setting.
Posted on Sep 08, 2009
  • 12 Answers
SOURCE: compressor shuts off at 60 psi will not come back on until opsi
If the pressure switch has been changed you will need to reset it if not ,then is the compressor trying to come back on but will not start untill it reaches 0 psi?
Posted on Apr 29, 2010
  • 36 Answers
SOURCE: vertical 33 gal compressor wont build pressure
could be a gaskit or the inlet reed
Posted on Jul 30, 2010
  • 28 Answers
SOURCE: 26 gal 1.7hp Supose to pump
Is there a pressure gauge setting knob to turn the pressure up and/or a release valve on the tank needing to be closed to maintain the pressure.
Posted on Sep 24, 2010
I just installed my husky 60 psi compressor. IT HAD NOT QUIT RUNNING AT 120PSI . WHATS THE FACTORY SETTING ?
The factory setting are at the 120 -110 psi. I personally set mine at 110 psi. No since in running it harder. read the instructions and turn the setting screw down..
Sep 15, 2017 | Psi Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    I have a husky model 947265. And it won't shut off when I turn it off manually I have to wait till all the air is out before it turns back on
    Free Husky Air Compressor User Manuals ' ManualsOnline ...
    powertool.manualsonline.com > ... > Husky > Power Tools Husky
    Husky Air Compressor Operator's Manual ... Plumbing Quincy Single-Stage Air Compressor - 3.5 HP, 220 Volt, 60-Gallon Vertical Tank, Model Q13160VQ.
    Sep 04, 2015 | Air Tools & Compressors
    Lost manual for Craftsman professional 60 gal vertical air compressor model no. 919.727280 & require it to determine how much oil the compressor takes Thnaks
    The manual for this can be found at managemyhome.com. Look under manuals. It requires Adobe to read it. If you do not have it there is a plug in there. Thanks BB
    Sep 19, 2010 | Craftsman Air Tools & Compressors
    Compressor shuts off at 60 psi will not come back on until opsi
    Apr 25, 2010 | Campbell Hausfeld 26 Gallon Low Rider...
    I have a 5hp 26 gal upright cast iron.Moved lying on side
    clean fuel tank, and lines. just do a standard tune up. check every componet for wear or rust.
    Oct 26, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Sep 08, 2009 | Campbell Hausfeld 5 Peak / 1.7 Running HP,...
    Craftsman compressor
    They put this under vacuums, relist it in the right place.
    Dec 16, 2007 | Porter Cable 7812 Wet/Dry Vacuum
    Garden Logo
    37 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
