Question about Garden
Burned a hole thru pressure washer hose when it touched the engine, again, can it be repaired?
  • 252 Answers
Likley if the pressure hose is is a hi quality hose and is in good condition
you can get a hose doctor to cut it in two where the hole is and swage / crimp male and female water blaster hose connectors back on to make an pressure tight coupling
if it is a cheaper hose i would recommend replacement
cheers pauly46
Posted on Jan 01, 2011
No pressure...new pump
Gun could be the problem if you hear the engine pick up speed and you can feel the pressure on the hose.if engine speed doesn't increase than there is a governor issue with the engine.
Oct 03, 2014 | Karcher G 2600 VH 2,600 PSI Gas Pressure...
Tip
Upon removing the top cover from the DUET washer, I found the pressure switch...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “FH” error code.
"F/H" indicates that either you have no water coming into the washer, or very little water.
If you have NO water coming into the wash tub after 30 seconds the error code is displayed. Check the following:
- Inlet water valve may be clogged. Clean inlet screens if necessary.
- Make sure water taps are on.
- Check inlet hoses for kinks or clogs.
If you HAVE water filling the wash tub, and after 8 minutes, 10.5 gallons of water has been detected by the flowmeter, but there has not been a detected a Pressure Switch trip, the inlet valves are turned off and the error code is displayed. Check the following:
- Make sure you don't have a siphoning problem. Click the following link for instructions: http://www.fixya.com/support/r587481-prevent_washer_siphoning
- Verify Drain Pump operation.
- Verify Flowmeter operation.
- Verify the Pressure Switch hoses are intact and connected properly.
To access the Drain Pump - UNPLUG the washer and take the lower panel under the door off by removing the three screws under the bottom edge. HINT: Propping the front feet of the washer up can make access much easier. I use a couple small blocks of wood. With the screws removed, the panel should drop down then come off. If it sticks, tap either side and it should come free. The pump is located directly under the wash tub in the front of the washer. Verify the electrical connections are good and that the pump is running. If not, click on the following link to check the pump for obstructions:
http://www.fixya.com/support/r385845-checking_drain_pump_in_whirlpool_duet
To access the Flowmeter and Pressure Switch – remove the three screws in the top panel along the back of the washer. With the screws removed, the panel should slide back, then, lift off. The flowmeter will be located on the left-hand side of the washer (facing from the front) between the inlet valve and dispenser. It’s a small white plastic device with hoses attached. The pressure switch is located on the right-hand side of the washer in the rear. It is a round plastic device with electrical connections and a hose attached.
There should be a tech sheet directly behind the panel or attached to one of the interior cabinet walls. Please refer to this sheet to learn how to perform diagnostics, how to locate the components mentioned, and the specific measurements required determining if the components are good or bad.
I hope this helpful. Please post back if you can't find the tech sheet and/or need further assistance.
on Jul 03, 2009 | Kenmore Elite 45986 Front Load Washer
The hose blows off when attached and no water goes into the machine but the engine seems to be running
It sounds like the quick- connect fitting is faulty. That's the fitting on the washer that connects the water hose to the washer. They are readily available at any hardware store or Home Depot / Lowes . Don't run the washer without water going thru it. It could burn out the motor/pump.
Jun 01, 2014 | Karcher Garden
Burned through the hose, repairs?
With the high pressure that these units produce, I would recommend replacing the hose instead of repair just for a simple matter of safety.
Feb 12, 2013 | Craftsman 2700 PSI Briggs Stratton...
Pull Stirng rope snapped on my Homelite 2400PSI Pressure washer
Installed improperly or the rope is not the proper size.
Most recoil assemblies are easy to fix...but not in an obvious way. Remove the recoil asembly from the small engine housing/flywheel cover. Usually three bolts hold it on. 10mm on Honda's. Pull the remaining rope thru the exit hole if possible. Otherwise, fish remaining rope thru the hole by turning rope winding pulley as if pulling handle was still attached, lining up any remaining rope end and pushing thru the exit hole in outer recoil housing or backing it out the inside pulley. Continue to wind rope winding pulley in a counterclockwise ( facing pulley...not outer metal) untill it will not tighten any further. Remove any more old rope. Line up pulley hole and exit hole. Melt end of new rope into a tapered shape..if not supplied that way. the pulley can be held in place by inserting a screwdriver thru the both the pulley and the metal housing spokes. Thread the new rope thru the exit and pulley hole. Tie the rope end sticking thru and draw tight. Cut 6 feet of rope...if not using a presized pull. Release screwdriver from spokes and rope should draw up onto the pulley. Tie off opposite end of the rope to keep from losing that end into the exit hole. put the handle on the rope and tie a knot in the end to retain the handle. Untie the tie-off and allow the handle to fully retract. If handle does not fully retract you may shorten the rope so that it does...as long as you have plenty of pull lenght.
Oct 21, 2012 | Mi T M Jp-2403-0Mhb - 2400 Psi 2.4 Gpm,...
Water goes thru. have hydrulic oil to level. gun semas to stick on. NOT GETTING ANY PRESSURE AT NOSSEL.
Hydraulic oil?
Is this a pressure washer?
Pump should be half full of SAE20 or SAE30 non-detergent motor oil.
Engine should have 10W30 motor oil.
If you have a pressure washer ... and not water is coming out end of gun:
Take all hoses off machine.
Look at incoming water hose connection.
The should be a filter washer.
Clean or replace filter washer.
Hook up water and turn on water.
Water should come out other side of pump.
Turn on power washer and see if water coming out of pump is pressurized.
Now hook up pressure hose without gun.
Turn on pressure washer and see if water comes out of hose and is pressurized.
Finally, the gun may be bad.
We used to replace guns when they went bad.
Oct 24, 2010 | Dewalt 3800 PSI Pressure Washer
Engine runs. No water thru hose. Pressure valve(???) underneath has water coming out of it
Sounds like bad seals. But first take the hose off and see if water comes out the outlet without the hose there.
Nov 15, 2009 | Honda Pressure Washer PSI 3000
I have a Karcher pressure washer that leaks from the pump when operating.
could be little plastic pressure hose outlet,they can be porous and let pin holes of water through,pull plastic casing apart and remove high pressure hose outlet (black 'L' shaped pipe gun pressure hose outlet,ive repaired a couple,and machine works fine after
Oct 18, 2009 | Garden
Gas driven portable pressure washer no longer draws chemicals up
Picks up under low pressure conditions by adjusting wand or changing tip.
Mar 18, 2009 | Honda Garden
Garden Logo
65 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
