Question about Sony FV120 Microphone
I can't connect my sony f-v120 microphone to laptop
Power jack has become disconnected from computer
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Aug 25, 2012 | Acer Aspire AS5251-1513 AMD V120 Notebook
I have a Motorola V120, and I can hear people, but they can't hear me
The microphone of your phone is faulty and needs to be replaced.
May 26, 2011 | Motorola Mobility V120 Cellular Phone
After cutting on the laptop a error came up stating a error with the hard dirve.
1.You may need to replace the hard drive if you have an error that renders no access to the hard drive.
Your PC/ LAPTOP will require service by a techncian.
Mar 16, 2011 | Acer Aspire AS5251-1513 AMD V120 Notebook
How can we connect to laptop? I have bought one and connected directly to laptop microphone slot and it is not working. why?
Hi, you have to go into your audio configuration program and select the proper set up, also double-click on your speaker in your system tray and this should open your audio program, then click on option and make sure your microphone is selected and that the mute button is not selected then close your volume window and it should work. Mike
Oct 19, 2010 | Sony FV120 Microphone
Reset LOM password on V120
Hi I am Vortash ... try this Remove the memory back up battery a small round penny sized battery in a holder on the circuit leave out for 1/2 hour and then replace this should have wiped the cmos and the bios and enable you to access to bios... hope this helps regards Vortash
May 15, 2009 | Acer Aspire 4520-5141 Notebook
Sony microphone urx p1 stopped working
there was a loose connection in the microphone wire that needed to be resodered.
thanks Paula
Mar 30, 2009 | Sony (UWP-S1) Professional Microphone
Sony vaio vgn-n250e laptop microphone problem
You can download what ever Vista driver required for your VGN-N250E Sony Vaio at Sony Vaio Support.
Good Luck.
Oct 24, 2008 | Sony VAIO VGN-N250E/B Notebook
Sony MHC-RV888D - TAPE Recording to Laptop as mp3
on laptop, ensure the following: 1. go to Volume control (look for icon on system tray). 2. under Options tab select Properties. 3. under Adjust volume for recording option, ensure that microphone is is check-boxed if no luck, borrow a second amp and connect your L/R jacks (red and white colour) to the borrowed amps line in jacks and test whether you hear anything to confirm your line out capability.
May 27, 2007 | Sony MHC-RV888D Shelf System
Sony FV120 Microphone Logo
125 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
