Question about Franke Plumbing
Hot water faucet sticks. It does not turn on or off smoothly anymore.
    Problem Solver:
  • 5 Answers
Sounds like it needs a new washer/valve
Posted on Jan 01, 2011
Drain hot water heater
turn off gas
turn off cold water to heater
connect hose to spickot
place hose end outside
turn on spickot
open hot water faucets in house
wait.
when water stops, turn on cold water for 30-60 sec or so to try to stir up any sentiment in tank
turn off cold water and let drain.
close spickot
turn on cold water
let fill till water start coming out hot water faucets then turn off hot water faucets.
turn on gas and relight pilot.
finish bleeding air from hot water faucets.
set water heater thermostat
Jun 14, 2014 | Rheem 43VP50E2 50 Gallon FVR Natural Gas...
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
The cold water handle is frozen in place. When I swap out the hot handle with it, it turns fine. How can I, or can I, unfreeze this frozen faucet handle? Model is 048nk00
Can you soak it in a type of penetrating oil to maybe free it up. Once freed up they make a grease for stem's maybe apply some to stem for smooth operation.
Aug 09, 2010 | Price Pfister 048NK00 Contempra...
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
Hi there, my hot water tap in the bath tub was working b4 but it's not anymore, but the cold water tap works in the bath tub. can you help me out please?
Was the tap shut-off very tight and the tap is turning but the main shaft may not be turning. Check the hot tap mechanism and compare it to the cold tap.
Oct 09, 2009 | Porcher 5535-254.___ Reprise Pillar Taps...
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Stream doesn't stop when I'm trying to use my sprayer
Ok, A moen thing, huh? Well lets look at it as a differential valve sticking. Turn your hot water on and keep hitting the trigger on the hand spray. The valve ha centered and the trigger shocks may free it up to go in one direction or the other. It should default to the spicket when you release the trigger.. Keep doing it and you will see if it's moving by the flow out the spicket. Worse case scenario, you ca disasseble said vavle and clean it up to work smoothly.. Good luck and stay dry.
Jun 09, 2009 | Moen 7437 Chateau Single Hole Kitchen...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Plumbing Logo
141 people viewed this question
Top Franke Plumbing Experts
Jim Parker
Jim Parker
richie46
ray gallant
Are you a Franke Plumbing Expert? Answer questions, earn points and help others
