Question about Panasonic Lumix DMC-FS3 Digital Camera
This problem occurred for the first time yesterday. Whenever I try to take more than three pictures in a row without turning the camera off it gives this message, "Please turn camera off and then on again." Why is this happening, and how can it be fixed? I've had the camera for a year and a half now and this is the first time that has happened.
  • 6,831 Answers
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Mar 16, 2011
Testimonial: "I tried these but they didn't work. Thanks though! My camera still works, I just have to turn it off and on again all the time."
I have a canon rebel xti, when I take several pictures a get a busy signal and have to wait before I take another picture (flash?) how do i take pictures, many in a row without getting a busy signal..as if...
Not sure, a couple things to check are the memory card you are using. If you have different card give it a try. Also, if you are trying to do burst mode there is a limit for your camera depending upon your settings. When you reach that limit the camera has to wait while all the data is written to the memory card.
Dec 06, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Won't take pictures when zoom
Most common problem in al the digital camera's. Slide motor start malfunction and the massage appears"Turn off the power and on again". In this situation you have to replace slide motor or lens block assembly, And your camera work fine again.
Thanks for using fixya.
Jun 27, 2009 | Sony Cyber-shot DSC-W80 Digital Camera
Importing Error
The problem is probably the same one i had. After successfully importing videos and pictures from my SD card, Windows 7 started giving me that error. I discovered that it was caused by the fact that I had imported some directly to an external USB hard drive (E:) and had set the default import directory to it (I can't remember if I had done this dileberately, or if W7 remembered it).
Fix: Just before you start the import, click the more options link at the bottom, and change your default folder to the local drive or to an attached external drive, something that exists at the time.
Worked like a charm after that!
Bill
Singer/Songwriter
www.billandkateisles.com
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
My casio Exilim will not take pictures or delete pictures.
The lock sensor is faulty. Try clicking the card in and out about 20 times in a row. I am guessing you will need a whole new system board.
Nov 12, 2008 | Cameras
When the lcd is turned away from camera, everything backwards/upsidedown?
It's designed to stick to the surface of glass tube CRT monitors via three suckers. This does present problems for LCD monitors as the pressure required to make the suckers adhere could damage the flexible sandwich that makes up an LCD panel and more damage could be caused when attempting to remove the calibrator. Of course, ColorVision has designed the Spyder hardware to be LCD-friendly. Instead of using the suckers, an LCD adapter is attached to the calibrator, which prevents the suckers from gaining purchase and a special filter for use with LCD displays is also incorporated. The calibrator is simply left to hang in front of the monitor, without any danger of damaging it. IB
Jun 17, 2008 | Canon PowerShot A80 Digital Camera
Canon sd900
Try a higher ISO speed (suggest 400). Look in your camera's instruction book to find out how to do this.
May 27, 2008 | Cameras
Camera lens error
i need help. i have the same problem. i had my kodak easyshare 853 for about 4 days and it turns on saying kodak easyshare and then it just has a blank screen and turns off by itself. please help. and yes my screen is tilted sorta. but im havin a hard time getting it to go back in place.
Mar 29, 2008 | Kodak EasyShare C513 Digital Camera
Fuji s2pro (2 units)
Your shutter mechanism reached its life expectancy, (5000 shots).
Aug 23, 2007 | Fuji FinePix S2 Pro Digital Camera
Panasonic Lumix DMC-FS3 Digital Camera Logo
110 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
