Question about LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive
My LaCie 500 GB external HD is not recognized by my (or any other) computer when connected, attempts to instal driver software fail and the device does not appear in the list of devices with removable storage on the computer menu. Is there any way to fix this, or any way I could access the data on the disk so I could copy it to my internal HD?
  • 44 Answers
Your problem could be any one of these issues:
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Posted on Jan 01, 2011
Hard drive is not recognized on my computer now and just has a flickering blue light .The system is vista and when it was removed and another lacie hd i have it works on the power lead and usb lead that...
The flickering light signals that the internal controller board has failed. Unfortunately this is terminal, the external case is dead. If you're really lucky the hard drive inside it still has enough life left in it to allow you , when connected directly to a desktop, to copy all your files from it.
After that just junk it and get a new one.
Apr 13, 2011 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hi I have a macbook and the 500 gb lacie hd when I connect the usb to the port, the macbook does not recognize the source. I have used it previously and it has worked and I can't seem to get it working...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
Dec 12, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
XP doesn't recognize 500GB external Lacie after almost 2 years
try it on different usb ports on your system
try replacing the cable which connects the hard drive with the usb port
if this does not works the problem lies in the portable hard drive and i think it would be under warranty period so get it checked
Jul 09, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Hard appears to be dead
Microsoft has several methods to fix USB devices not recognized by PC. Click on the link below and scroll down to the Resolution section. Hope it all works out for you.
Greg
http://support.microsoft.com/kb/871233
Jun 06, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
LACIE 500 GB HARD DRIVE
i use my external hard disk many times but now when i connect my lacie external H.D to PC it dose not recognized
Jan 30, 2009 | LaCie (300951U) 500 GB Hard Drive
Computer doesn't recognize my Lacie HD
From your description it sounds like you power adapter did indeed fail at first, but if the HDD spins now the adapter seems to be working fine at the moment. If the hdd is in device manager, than at least you can use carving tools like photorec to pull your files out, even if the filesystem is corrupt. If you want somebody else to do it for you you can check Data Recovery NYC. Otherwise http://hddguru.com/ is a great source for tools and knowledge on how to do it yoruself.
Dec 18, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Recognized - but no mount
Don't know about the MAC part, but an I/O error implies that the either the source file cannot be read or the destination drive will not write. This is usually an indicator of a bad HDD. To check, I would attempt to connect the external drive to another computer. If it still gives the same indication, contact the drive manufacturer about data recovery recommendations
May 29, 2008 | LaCie (300728U) 250 GB Hard Drive
LaCie 500GB P3 got the clicking sickness
There are companies that can recover the date from the disk of a failed hard drive, check online, It is expensive.
Apr 20, 2017 | LaCie 500GB P3 HD USB 2.0 7200RPM 8M 500...
Lacie external HD problems
I would suspect your USB drivers. Go into device manager and remove (uninstall) any device under the USB heading. Reboot and see if it works better. Also I would try the drive on another computer to make sure it is working find and try a different USB cable just in case.
Jan 17, 2008 | LaCie (300770) 250 GB Hard Drive
LaCie 500GB USB 2.0 7200 RPM 8MB 500 GB Hard Drive Logo
135 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
