On my Kitchen Aid Front load washer it fills up then stops and gives me a F H error code.
  • 472 Answers
If you take the bottom kick plate off usually 2 or 3 1/4 inch hex head screws you will find a clean out ..remove the cap and check for obstructions... be warned there will be water in here so have three or four large towels ready for the mess..if you do it slowly usually you can catch the water as it comes out... also make sure during this process you unplug unit as a safety precaution water and electricity just don't go good together... check for any debri in this area also while you have it opened pit your finger in and sweep around loose change in the hose etc. will cause this code... if all is clear you may have a bad drain pump assembly... the unit goes into a drain process right after initial fill to get all the old water out and sounds like that may be your probelm...
good luck to you
Posted on Dec 31, 2010
Maytag maxima front load washer will not fill with water when started and is not giving any error code
water level sensor not reading empty problem in the house supply tap ( washer blocking outlet--not turned on--inlet solenoid faulty and not opening to allow water in)
Jun 16, 2016 | Maytag MHW6000XG Maxima High-Efficiency...
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Code F11 appears about 10 minutes into cycle or at the end when the door should open. Kitchen aid front load washer six years old
Hi
F11 is a motor control unit error which means that the motor control unit has repeating under or over voltage or over current conditions due to internal failure. You can check the wire harness connections between the motor and the MCU (motor control unit) and also between the central control unit & MCU. If the motor is working then replace the motor control unit. Hope this helps...please post back for further assistance.
Daniel
Aug 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have error E48 on my GE front load washer
you can down load a file to show you how to put your washer into a srevice test mode
at appliance aid .com in the washer repair aid section line 7 you will see "GE LITTEL SWAN FRONT LOAD WASHER" click on that and you will see two down loads one of them will give you
directions and a list of the codes.
Mar 30, 2011 | GE WSXH208A Front Load Washer
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Washer fills up with way too much water.
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. However I can refer you to www.applianceaid.com where they have very good and complete trouble shooting and repair information on front loaders. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Samsung WF337AA Front Load Washer
Frigidaire washer starts to fill with water then stops
That is not the solution.
Start the machine and immediatly press the "Start" and "Pause/cancel" button at the same time. Then you will get and ERROR code. Look on the cheat sheet packed with the machine to find out what is really wrong. That will give you the real answer.
Appliancepartssuppliers.com
Sep 20, 2009 | Frigidaire GLTF2940ES Front Load Washer
I am searching for a front load kitchen aid washer and cant seem to find any... did they stop making them?
Whirlpool is now making their own Duet models and the Maytag front load machines and the Kenmore He2 2t and 3t and 3t steam and the 5 with steam washers.
KitchenAid is high end Whirlpool. Haven't seen them around lately but they just might be harder to find.
Sep 10, 2009 | KitchenAid KHWS01PWH Global Horizontal...
Kenmore He3Washer Fills then gives error code
remove lower panel right side underneath tech manual with codes
Jul 04, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
