Question about Poulan 1630 16" Chain Saw
Poulan pro 221 leaks oil after sitting oil in case
  • 154 Answers
SOURCE: i got a poulan pro classic gas chainsaw 38cc/16
may need coil, plug
Posted on Aug 03, 2009
SOURCE: Poulan-Pro 295 leaks excessive bar-chain oil
Most saws have a tendacy to leak after they are used. After use, just "burb" the oil fill cap to relieve any pressure. The closed oil system will siphon out all of the oil.
Posted on Aug 06, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro 380 that is leaking bar oil.I
I have 7 chainsaws. 6 of them if I forget to drain the oil reservoir will oil the surface of what they are sitting on. What you are seeing is normal.
IMO; use of the oiler creates a siphon. Any oil left in the tank will continue to siphon until the reservoir is empty. I could be wrong, I have been before.
Draining the tank works, nothing else I've tried does. HTH
Lou
Posted on Nov 06, 2009
dontbother10
  • 2220 Answers
SOURCE: poulan 221 pro 40cc chainsaw that needs a fuel
A typical fuel system and a couple of tips can be found here:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
Poulan PP221 Gas Chain Saw Type 4 IPL link (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP221-Gas-Chain-Saw-Type-4/75.PP221-Gas-Chain-Saw-Type-4.1.59.1.html
All fuel components are listed.
If not your saw yours can be found here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you need additional help or have questions please reply below and I will get back to you. HTH
Lou
Posted on Feb 19, 2010
  • 4088 Answers
SOURCE: Bar oil leaks into storage case when chainsaw not
The easy fix is to drain the oil tank when not in use. Many saws will leak some oil initially, but should not continue to do so. If it is making a large puddle, oil is getting past the oil pump which may be worn from long use. Make sure the tank vent is not plugged as heat from the engine can increase pressure in the tank thus forcing oil out. Hope this helps!
Posted on Mar 28, 2010
What is the spark gap for 221 pro 40cc
The gap for all Poulan chainsaws, regardless of the spark plug used, is .025.
Jun 12, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
My poulan pro chainsaw dies when I give it gas and I think the bar and chain oil is leaking out during storage.
try and run it with the muffler off the build up with carbon and restricted the exhaust flow as for the oil leak mine the screws became loose behind the clutch for the oil pump
Sep 17, 2012 | Poulan Pro 20-inch 2-cycle 50cc Gas...
Puddle of oil in case when not in use. If using it then shut off and sit it down leaves puddle of oil where it was sitting.
There will always be an amount of oil on the bottom of the saw, the oiling system is a constant loss system ie onto the chain and away, there are many places for the oil spray to sit in covers, which when sat will drip out, they rely on saw dust to dry the oil up, however if there is not a great deal of saw dust about the oil will not get dryed up and will drip under the saw.Unless the oil leak is excessive i would leave well alone.
Aug 01, 2011 | Poulan Pro Chain Saw 46cc 20"
Bar oil leaks into storage case when chainsaw not in use???? Poulan Prow, PP4620 AVX 46 cc
Mar 27, 2010 | Poulan Pro Chain Saw 46cc 20"
Bar oil leaking constantly. How do I fix it?
These saws are of the self oiling type there is no tip or bottle it consists of a tank and a channel the oil flows thru and on to the bar by gravity. There is a type of bar oil system on some saws that come with a button you push which In turn pumps oil onto the bar. But the poulan is not one of them. I have a 15 year old farm hand 20" bar and a two year old poulan wild thing 18" and both leave there oil in the case when sitting I beleive the fix would be drain it after use and clean up.
Mar 21, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
I have a Poulan Pro 380 that is leaking bar oil.I can fill it with oil and it will leak out during the night.
Lou
Nov 06, 2009 | Poulan Pro Chain Saw 46cc 20"
It's a seal somewhere either on the reservoir, or the 'feed' to the bar.
But in the short term, if you must use it, the simplest way of stopping the leak, is to not store it with any oil in it, until you locate the source of the leak.
That should help, but I'll wish you good luck never the less ;)
& plz don't forget to rate, thankyou :)
Jul 18, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Craftsman 2.3 14" / Poulan 1800 auto oiler leaking
Loosten the oil filler cap before putting it away. The tank is pressurized to force oil to the chain. Relieve the pressure before storing. Lou
Jun 05, 2009 | Poulan 1630 16" Chain Saw
Poulan 1630 16" Chain Saw Logo
184 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
