Question about Yamaha Boating
No cooling water shooting from the visual indicator port - less than 6 month old 115 short shaft motor purchased new from dealer
  • 784 Answers
If you do not see water shooting out, there are a couple of things to check, open the case and remove the hose and check for debris --- the fitting itself could also be blocked, clear hose and fitting and re-install -- test --
if no water is flowing after that, then there could be a chance that the water pump impeller is bad, ( note: if water impeller is bad the motor will get hot and the over heat light will come on ' red ' ), turn off and replace the impeller.
c...
Posted on Dec 31, 2010
My Motorola WX416 quit want to get a new phone?
6 months old? WARRANTY? Take it back to the dealer and ask for a new one. That's what I'd do.
Dec 04, 2014 | Motorola Cell Phones
Hayward pool pump leaking from underneath motor
The leak is an indicator the shaft seal has failed. It leaks by design to let you know to replace the seal before water gets into the motor and ruins it. Replace the seal right away.
Aug 17, 2014 | Hayward 3/4hp Super Pump Inground Pool...
New leeson 3 hp motor for my tablesaw has very little torque, and is less powerful than my old 1hp craftsman motor. What could the problem be?
If the motor is a 115/230 volt motor and is running on 115 volts but the wiring is configured for 230 volt operation, the motor will be weak.
Apr 05, 2014 | Leeson Table Saw Motor - 113627
F1 pops up on washing (cabrio) machine during start up. We change load and level. Next time it does it again. Macxhine is three years old. It has started this in the last month.
Keypad/User Interface Failure
F then 2 flashes when in:
Diagnostics Test mode if a stuck key is detected.
Standby mode if there is a user interface mismatch.
DISPLAY (Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
Console and Indicators
This test is performed when any of the following situations occurs during the Console and Indicators Diagnostic Test:
None of the indicators light up No beep sound is heard Some buttons do not light indicators None of the indicators light up:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P11 connector is inserted all the way into the machine/motor control.
2. Visually check that the user interface assembly is properly inserted in the console assembly
3. If both visual checks pass, replace the user interface assembly.
4. Plug in washer or reconnect power.
5. Activate the Console and Indicators Diagnostic Test mode to verify repair.
6. If indicators still do not light, the machine/ motor control has failed: Unplug washer or disconnect power. Replace the machine/motor control assembly.
Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
No beep sound is heard:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the P5 connector is inserted all the way into the machine/motor control. If visual check passes, replace the user interface assembly.
2. Plug in washer or reconnect power.
3. Activate the Console and Indicators Diagnostic Test mode to verify repair.
4. If replacing the user interface assembly failed: Unplug washer or disconnect power. Replace the machine/motor control assembly. Plug in washer or reconnect power. Activate the Console and Indicators Diagnostic Test mode to verify repair.
Some buttons do not light indicators:
1. Perform steps in Accessing & Removing the Electronic Assemblies, and visually check that the console electronics and housing assembly is properly inserted
into the front console. If visual check passes, replace the user interface assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%$@#
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
What is an F1 code? My machine is less than 2 years old - why would this be happening
Aug 13, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Whirlpool Cabrio Top Loading washer model WTW6400SW1. During the past month, I have been seeing the "LD" error code ("slow to drain") but not the "F1" code during middle of the wash cycle before...
Aug 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
1hp Water Ace dual jet water pump hums, doesn't pump
DOES YOUR NEW MOTOR HAVE A START CAPACITOR BUILT INSIDE OF IT TO HELP IT START. OR DOES IT REQUIRE A CAPCITOR START / RELAY BOX ABOVEGROUND. ALSO IF YOUR OLD MOTOR WAS 220V AND THE NEW ONE IS 115V YOU HAVE 2 HOT WIRES AND NO NEUTRAL. THE NEW MOTOR REQUIRES 1 HOT AND 1 NEUTRAL. HOPE THIS HELPS, JODY
Jul 18, 2009 | Plumbing
Pump trips circuit braker as soon as it is turned on
The problem is either in the spa or the circuit breaker itself is faulty. I would begin by changing the circuit breaker as it is much cheaper than a new pump.
Jul 06, 2009 | Pool & Spa
Sprinkler pump quits after 30 seconds?
call the company you purchased it through...that would be a warranty issue...sounds like it is overheating.
Jun 11, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
JVC AL-E300 Turntable
More than likely your motor might be bad. There is nothing else that controls the speed. Are you sure you purchased the correct size belt? Turn on the unit, without connecting the belt, and touch the motor shaft, and see if it fluctuates. You can also just get a marker, and marker a point on the motor shaft. When you turn it on, it will act as a visual indication as to it's speed.
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 07, 2008 | Audio Players & Recorders
Boating Logo
100 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Mike
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
