Question about Kenmore Dryers
Heats initially then shuts off
Model 110.71804000 when my dryer starts it heats up but then shuts off and blows cold air
    Sergeant:
  • 287 Answers
Sounds like the Thermal cut out is activating - look for a clogged lint filter or if you have it ducted exhaust the duct may be blocked.
The thermal cutoff may also be faulty requiring a service man to replace it
Posted on Jul 08, 2008
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
9yr old model Maytag window a/c - just blows cold for 30 seconds - then blows warm. Was perfect until this happened. Is it worth fixing? What would be the usual fix for this?
The compressor is shutting off on overload after running for a few seconds. The overload cools down and starts the compressor running again until the overload heats up and shuts the unit off again.
Aug 02, 2011 | Heating & Cooling
I have a whirlpool dryer M460-G (SN#MH4612126 ? LGR7646EQ3). The dryer does not heat up. I checked the back and cleaned all the lint. The gas ignites and heats some time but not all the time and when it is...
Replace your gas valve coils!! They will allow the dryer to heat initially, but fail after about the 3rd or 4th iginition sequence.
Part number 279834 and are around $20.
They are located on top of the valve and held on by a steel bracket with two phillips head screws. Plug and play wires you cant mess up.
Fix it up!!
Aug 14, 2010 | Roper REX4634KQ Electric Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
2003 Jeep Liberty. Starts out blowing cold air
it could be many things, maybe compressor heats up and shuts down, or cooling fans are cooling condensor or expansion valve is bad, a good tech will be able to diagnose this,
Mar 24, 2010 | 2003 Jeep Liberty
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Maytag dryer does not maintain heat and clothes smell
Check coils on burner assembly. Often when a dryer heats initially and then stops heating a coils has gone bad.
Nov 09, 2007 | Maytag MDG7600AW Gas Dryer
Dryers Logo
71 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
