The oil light comes on - Computers & Internet
  • Jeffrey Groves
    Jeffrey Groves Dec 31, 2010
    That must be a really old motherboard!
    Problem Solver:
  • 11 Answers
Joking? Ok, remove the dipstick from computer operation. Neener. If you are serious tell us which light is or isn't working properly: power, disk, network card. Good luck and thanks for asking.
Posted on Dec 31, 2010
Why does my oil light come on after the car warms up?
Why does my oil pressure light came on when I stop?
Low pressure means there either isn't enough oil in the system or the oil pump isn't circulating enough oil to keep the critical bearing and friction surfaces lubricated. If the light comes on while at speed, do your best to pull off the road quickly, turn the engine off, and investigate the problem to avoid damage.
Why Does Your Car's Oil Light Come On? - Popular Mechanics
www.popularmechanics.com/cars/how.../why-does-your-cars-oil-light-come-on-865772... Search for: Why does my oil pressure light came on when I stop?
Why does my oil light come on after the car warms up Google Search
May 28, 2014 | 2006 Suzuki Forenza
Yamaha xjr 1300 electrical fault oil light comes on with headlight
Just sorted my problem with oil light coming on when lights are switched on. Removed the back off the clocks and realised there was a missing oil light bulb, and the holder was out of place. It was the light from the dash light coming through the hole for the oil light which made it look like the oil light was lit. put new bulb into oil light holder and all back in place everything now working 100%. Happy days !!! Hope this helps
A.
Jan 02, 2013 | Yamaha Motorcycles
2004 lincoln avaitor oil light comes on the engine shuts down
Does the oil light come on BEFORE the engine shuts down? I have to ask because it is NORMAL for the oil light to be on when the engine is not running. I had a customer that said the same thing just last week. After we wasted a bunch of time (which the customer ended-up paying for) checking the oil level, the oil pressure, and verifying correct oil pressure gauge, light, and sending unit operation, it turned out that the crankshaft position sensor was bad and causing the engine to shut down and it had absolutely NOTHING to do with the oil light - it was functioning as designed.
If the oil light is coming on before the engine shuts down, the first thing you need to do is check your oil level. If the oil level is OK, you need to check the oil pressure with a gauge to determine if there is an actual engine oil pressure problem or if the oil pressure sending unit, gauge or light is malfunctioning. Also, it is highly advisable to not drive the vehicle AT ALL if the oil pressure light is coming on while driving until the cause of the light coming on has been determined and repairs have been made. Otherwise, SEVERE ENGINE DAMAGE may result.
Feb 21, 2012 | Cars & Trucks
Hi there !! my car now haw 65.000 milles i'd change oil 3 weeks ago , but now the light comes on , what could it be ??? could you please tell me what happen , 'cause i want to sell the car soon...
WHAT LIGHT COME ON.IF LOW OIL LIGHT COMES ON CHECK OIL DIP STICK.OIL LEVEL SHOULD BE ON THE FULL MARK.IF OIL LIGHT COME ON CHECK OIL DRAIN PLUG AND OIL FILTER EITHER ONE COULD BE LOOSE LEAKING OIL.IF OIL LIGHT NOT COMING ON AND YOU SEE SERVICE ENGINE LIGHT THAT CAR TO ANY AUTO PARTS STORES.THEY WILL CODE SCAN CAR FREE AND TELL YOU WHAT TROUBLE CODE YOU ARE GETTING.
Sep 11, 2011 | 2002 Suzuki Grand Vitara
What causes the oil light to come on?
The oil light will come on orange if your oil level is low. The oil light will come on red if your oil pressure is low. The oil light will come on, then turn off if your oil level sensor needs replacing. Alex
Aug 04, 2011 | 2001 Chevrolet Cavalier
Oil level low light comes on. When I turn
some cars with oil level warning light on, it doesn't mean that its only reading the engine oil level is low, sometime the transmission fuid too. Did you check your transmission fluid if it is ok or not? try to check and let us know, ok.
Mar 14, 2010 | 1999 Buick Century
How low is my oil when the light comes on. My oil light did not come on until my car was completely empty of oil. Is that normal?
No, not normal at all! If your oil light comes on, stop driving before you ruin the engine! The light indicates not necessarily low oil, but lack of pressure. Either way, you need to get it fixed. If you add oil and the problem comes back soon, then you have other problems, like leaks, or a failing oil pump.
Nov 17, 2009 | 2001 Audi A6
Oil light comes on. Just got oil change. Is oil
Most likely POOR OIL PRESSURE. DO NOT run theengine till you connect with the shop that changed the oil. Could be many possibilities i.e. wrong oil, bad filter, not enough oil . Hope this helps
May 02, 2009 | Mercury Marquis Cars & Trucks
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
