Question about GE JKP90 Electric Double Oven
After self cleanin our GE jkp90 oven we get an F9 code when we cook above approx 450 degrees. Once it gets to temperature the F9 comes on the display, locked flashes, and the oven shuts off. Sometimes the door latch will lock and sometimes it won't. This fault only happens at very high temps.
  • 472 Answers
Sounds like you have a bad interface or control unit ... being a g.e oem authorized service tech for the last 18 years we see this alot... the self cleans should be removed on these things... it literally gets the units to hot and starts melting and destroys the components on these things... the control board will actually come with a new door latch mechanism as well and that normally is the culprit.... the thermostat is connected to the erc ( erc being the control board) and when the unit says it is high temp the erc faults you need a new control board assembly.... god luck
Posted on Dec 31, 2010
  • scheetzfamil Dec 31, 2010
    where can I go to get the replacement control board/door latch mechanism?
Oven shows an F2 flashing after self cleaning along with a beeping sound.
Hello there and thank you for choosing fixya
The F-2 error code Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Jun 29, 2011 | GE JKP15 Electric Single Oven
Get an error code of f4 when trying to set temperature
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor.
Could be a result of:
· contamination on terminals
· pinched wire in oven temperature sensor circuit
· cold solder joint on control
Possible Solutions:
· Disconnect power to range and remove oven temperature sensor connector from control.
· Measure oven temperature sensor resistance at oven temperature sensor connector (take care not to damage terminals in block) - Should read 1100 ohms at room temperature (approx 72 degrees F).
· Measure each oven temperature sensor lead from connector block to ground. If shorted, look for pinched or cut wire in oven temperature sensor circuit.
· Check connector terminals - Look for deformed or corrosion on terminals. Repair or replace. If all above is ok replace control.
Hope helps.
Jun 21, 2011 | GE Ovens
Whenever I bake at a temperature above 370 degrees in my model jkp90s, it gets a f9 error code and attempts to lock the oven door. Is this a common problem with this model GE oven? Is there something...
Hi jrsinister,
Error F9 has something to do with the lock switch. There two things that you can check to solv the problem. First, check wiring to door lock switch (the wire harness may be connected wrong). The other ne is to check for stuck lock switch.
Hope this helps.
Thank you for using FixYa.
Apr 05, 2011 | GE JKP90 Electric Double Oven
F9 error code while using the convection baking function
This is a lock switch error code. Check wiring to door lock switch (the wire harness may be connected wrong). Check for stuck lock switch. If the switch cannot be re adjusted, it must be replaced.
Jul 30, 2009 | GE Ovens
Gas Oven doesn't work under 450 degrees
most common issue is a bad bake ignitor, easy fix, probalby about $75, located on the side of the bake burner, simple to replace a few screws and 2 wires
Nov 17, 2008 | GE JGRP17 Gas Single Oven
GE self cleaning radiant oven - model JB578GP
I went out to my circuit breakers and turned the circuit off, let the oven cool, and powered it back up after about 2 hours. Fine now.
Feb 17, 2008 | GE Profile JT912 Electric Single Oven
F3 code and beeping
F3 - F4 Open oven temperature sensor (circuit) (over 2700 ohms) or, shorted oven temperature sensor. Could be a result of:
· cold solder joint on control. · Disconnect power to range and remove oven temperature sensor connector from control.
Nov 17, 2007 | GE Profile Advantium SCB2001KSS Stainless...
Double 27" oven Model No.911.48489 show F9,later beeping
The F9 error message usually means that the oven temperature is above 600 degrees F. Check that the fan is operating. Make sure that it is not blocked. Make sure the vent areas are not blocked. There could also be a welded relay contact or high resistance in the oven sensor leads or connections.
Oct 02, 2007 | GE JTP85 Electric Double Oven
GE JKP90 Electric Double Oven Logo
147 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
