Question about Garden
My lawn mower will run for 3-4 min then slowly die out , replaced spark plug,air filter, new oil ( to proper level) clean gas tank and screen Model LV195 EA.
    Sergeant:
    Champion:
  • 226 Answers
Try clean the carbarpor out i use choke and carb cleaner from napn
Posted on Dec 31, 2010
My lawn tractor craftsman 14.5hp IC OHV B&S stalls approx. 5 mins after starting so I restart and it can stall in another 10-15 min again and so on.
you may have some debris in your gas tank blocking the pickup tube. It will float away when the mower dies, then block the tube after it runs again.
Jan 03, 2017 | Craftsman Garden
John deere lt133
Engine oil does a couple of things, lubricates and cools. Your crankcase probably takes about 2 qts. Fill it to full and park it over something clean to see if there are leaks.
For your engine to run it needs fuel and air. If the engine is dying, more than likely you have a fuel/air issue. Check your fuel lines for leaks, replace your fuel filter. Clean or replace your air cleaner. Make sure your tank cap can breathe, so air can replace the gas going to the engine.
Jul 19, 2014 | John Deere Garden
Toro lawn mower troubleshooting
Clean the carb, gas tank and fuel line (s). Replace air filter with a new one, I wouldn't recommend that you run it without the filter because that allows dirt and grass debri to enter the carb, fuel line and gas tank.
Replace the plug with a new one that is recommended for your engine.
Check oil level.
Other option is lawn mower repair shop....
Hope this helps, I had the same problem.
May 11, 2013 | Garden
Model lv195ea
There is not a governor on newer mowers. Ease mower thru grass slowly, if starts to slow down stop, let mower speed up. In tall grass only use 1/2 of the deck width with side discharge open. Ensure spark plug is clean and gapped properly, replace once a year. Ensure air filter is clean, replace once a year. Ensure oil is full. 30w oil. Always use Stabile in gas. Use carb cleaner and clean outside of carb to ensure choke lever is free to rotate.
May 09, 2013 | Toro Garden
Toro self propelled lawn mower dies after an hour
maybe u have to much oil in it or there mite be a stone in the carberator or petrol tank thats blocking the petrol ?
Aug 07, 2012 | Toro Garden
Mower isnt running properly. changed the spark plug, cleaned the air filter, and checked the oil level, still wont run properly. mower is only 1yr old. any suggestions?
It could be a couple of other things. But the things you have already doe are good!
1. Is it possible that water got in the fuel or fuel tank?This would cause the mower to run rough.
2. You may have a dirt in the carburetor, restricting the gas flow.
3. You may need to replace the gasket and diaphragm ($5.00) in the carburetor. You should do this anyway if you are gonna remove the carb. to clean it.
I'm attaching a Video to help you do this; just click the link::
This carburetor may not be exactly like your, but very close.
Good Luck!
Jim
Aug 11, 2011 | Yard Machines 158cc Push Lawn Mower #11a...
I have a 16 year-old MTD lawn tracotr with a 12.5 hp briggs & strattion engine. The tractor will run for 5 minuted then quit. It appears that the n(new) fuel filter is not full, thus gas is not...
Were the engine rpm's steady when it died? If it was hunting, the carb. probably needs cleaned.
The fuel filter can maintain an air bubble in it and still flow plenty of fuel. So does it restart after it dies? You can check the cap by running with the cap a little looser and see if it dies, I have not ever encountered a cap failure, but you could look to see if the vent hole in the cap is plugged.
If you had a crack in the fuel line or were sucking air in somewhere it probably would not run right from the outset.
Aug 12, 2010 | Toro Lawnmower 20099 Mower Mowers Lawn
Lawn mower runs and then putters down, won't die but runs slow.
clean the air filter,wash out in turps if foam type,then wash in soapy hot water,then rinse,let dry,then put litle bit of clean engine oil in it,squeeze.drain all fuel,and put fresh in.may have to pull carb to bits and blow out,and reassemble.put new spark plug in.is it a briggs engine,or tecumseh?
Jul 11, 2010 | Garden
Motor runs for 5-10 min. then starts missing and quits.
Check your spark first,if you do not have spark your problem is the coils-if you do have spark the problem probaly lies withone of your valves getting stuck after getting hot and soonas it cools down a little it closes and then you can restart it till it gets hot again.Hope this helps
Jul 04, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Nannie what can be wrong with my power devil petrol lawn mower the engine wont keep running then cuts out petrol and oil ok
Check air filter, check screen in bottom of fuel tank,
New spark plug and also check the spark.
If there is a weak spark, the coil may need to be replaced.
If you have good spark, clean air filter, and clean fuel tank screen, then the carberator will need to be pulled of and cleaned out with solvent
Jun 23, 2009 | Mtd 22" Yard Machine Push Mower
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
