Question about Pyle PT649D Single Cassette Deck
Does this unit come with speakers - Pyle PT649D Single Cassette Deck
  • Pyle Master
  • 5,056 Answers
If it has no volume control or terminals for speakers then it is a hi-fi seperate and needs to be connected to an hi-fi amp to work.
Posted on Jan 03, 2011
Receiver shuts off when loud content comes on TV
Hello Jerry, This means that the unit is going into protection mode. The unit will only go into protection mode for 2 reasons. The first reason would be if there is a short within the unit itself. The second reason would be if one of the speaker connections is causing a short. To isolate which of the two is the issue, you would first turn the unit off and unplug all of the speakers. Turn the unit back on with no speakers connected and raise the volume up. If the unit turns off with no speakers connected then we know that the issue is internal and would have to go in for repair. If the unit stays on, that will tell us that one or more of the speaker connections was causing the issue. If that is the case I would check all of your speaker connections and possibly start with fresh copper connections. Thanks, FJD
Feb 24, 2016 | Onkyo TX-DS575 Receiver
I need the the speaker connections to the unit
On any amplifier "unit", speaker connections should be obvious at rear or the device. So, what kind of "unit" do you want to use with your speaker? Some "units" are not working with external or additional speakers.
May 24, 2015 | Audio Players & Recorders
I have kenwood car stereo.it shows protect mode..soo what is the main problem? wand what is the solution? pls help
Hi, the unit enters protect mode when the output impedance is too low causing the power transistors to draw too much current. A short may be internal or external to the head unit. The thing to do is first disconnect the speakers to see if the unit will come out of protect. If this does not work, the short is internal, and the head unit must be repaired or replaced. If disconnecting the speakers DOES resolve the short, then the speakers and wiring must be checked for a short. The easiest way to do this is to use an ohmmeter at the speaker connector. Check the impedance of each pair of speaker wires. The impedance should be between 4-8 ohms. Anything less than 4 ohms may cause the unit to protect, depending on the exact design of the unit. If you find any wire pairs to have less resistance than the others, access the speaker to check the impedance of the speaker alone. If the speaker has an impedance of 4-8 ohms, the problem is a shorted wire. Please let me know if you have questions, and thanks for using FixYa.
Mar 20, 2011 | Kenwood KSC-310CCS Center Channel Speaker...
As soon as the speakers are turned on, there is a popping noise through the speakers then the receiver shuts off and stand bye light blinks
Sounds as if you may have a bad speaker component that is causing the unit to go into a protection mode to protect the unit from shorted speakers/outputs. Try to unplug the speakers entirely and then turn on the unit...If it still does this and goes into standby with the speakers disconnected then there is a problem probably in the audio amplifier circuit that will need servicing by a technician. If the unit stays on..then I would try to put different speakers on the unit to see if it works..if so, then suspect your speakers...if not , then suspect the receiver
Jan 06, 2011 | Audio Players & Recorders
It keeps blinking protetor
The protector circuit protects your amplifier from shorted speakers . One of your speakers , or more speakers are shorted out . To figure it out easily follow these instructions . Turn the unit off . Now unplug all of the speaker wire connections from the back of the unit . Turn the unit on . Make sure the volume is turned all the way down . The protector light should not light up . If it does , the problem is inside the unit itself and we'll have to be repaired at the shop . If the protector light is off than continue on as follows . Connect the speakers one at a time to the unit . Each time you connect a speaker , turn the volume control up and back down making sure the protector light does not come on . When you connect the bad speaker , the protection light should come on . Whichever speaker makes the lights come on when connected is the bad speaker and should be replaced .
Oct 21, 2010 | Sony STR-DA2ES 6.1 Channels Receiver
Bmw e36 speakers do not work
hi, the speakers dont have fuses, they run directly from the head unit, sounds like the head unit has a blown output, or the speaker has just given up, you can buy the removal keys from ebay, or most auto shops,( very cheap )..remove the unit, and try the speaker that is working on the wires of the speaker that isnt, this will tell you if its the speaker, or the unit
Sep 03, 2009 | 1997 BMW M3
Yamaha rxv-992 receiver wont power up
Disconnect all your speakers from the receiver. Turn the power on, and see if it stays on. If the unit shuts off with all the speakers disconnected, then you most likely have a faulty unit, and it will need to be repaired or replaced.
If the unit stays on with all the speakers disconnected, then you most likely have a bad speaker or a bad connection with the speaker wire.
Starting with one speaker, hook it up, and turn the unit on, and again see if the unit stays on, or if it shuts off. Do this until the unit shuts off when you connect a speaker.
Then disconnect all the other speakers, and leave the suspect speaker attached. Again, try to power up the unit. If it fails with that speaker attached, but works when it is not attached, then that speaker is your problem.
Sep 02, 2008 | Audio Players & Recorders
Denon AVR-3802
I have repaired many of these Denon receivers over the last few years.
Since the headphones work, that means if you dis-connect the speakers it will turn on and not go into protect (when power cuts off a few seconds after turning the unit on).
The most likely problem is a bad speaker. to find out which speaker is causing the problem, do this.
Start out with just one speaker connected and then turn on the unit. If it turns on and plays music, you know that speaker is good.
Now turn the unit off again and add another speaker and keep the first speaker connected. Once again, if the unit plays, that speaker is also good.
Keep doing this same procedure one speaker at a time. As soon as you connect a speaker and then try to turn on the unit and it goes into protect, the speaker you just connected is bad.
To confirm that this speaker is the bad speaker, dis-connect all speakers and only plug the suspected bad speaker into a speaker jack that worked with one of the other speakers.
If the unit still goes into protect you know then that you have found the bad speaker.
If the unit still goes into protect, that speaker is bad and you will need to take it in for repair or replace it.
make sure you use 8 ohm speakers. if i remember correctly these Denons can use 6 ohm speakers, but those are harder to find and most home speakers are 8 ohms.
If the unit does not go into protect and that suspected bad speaker plays in one of the other speaker jacks, what you really have is a bad channel in the amplifier, the channel that the suspected bad speaker was previously connected to.
If you find out you have a bad channel, you will need to take it in to an repair center. Preferably an authorized Denon service center. There are not very many of those around. I work at the only authorized Denon service center in the entire state of Michigan.
If I can be of more assistance, don't hesitate to ask. And a good rating is always appreciated. :)
Jun 22, 2008 | Denon AVR-3802 Receiver
Unit turns on, then clicks off with a "protect" message
You have a bad speaker on this unit or the audio output circuit is in need of repair. Try to disconnect all of the speakers and then turn on the unit. If it still stays in protect, you will need to have this unit serviced, unless you understand how these solid state circuits work. If the unit does come on without the speakers, turn off the unit and add one speaker at a time until the unit will not turn on. Disconnect that speaker and have it checked out or have the wiring checked out. Good Luck
Jul 14, 2007 | JVC FS-G5 CD Shelf System
Pyle PT649D Single Cassette Deck Logo
47 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
