Question about Briggs & Stratton Garden
On a Briggs & Stratton motor 281707-0162-01, where on the carburetor does the throttle link spring hook? This is the long but very small diameter spring wrapped around the throttle link.
  • 1 more comment
  • Bob O'Donnell Jan 01, 2011
    can you show me a drawing? I know where it hooks up on the engine, but I don't know where it hooks up on the carb.
    Or does it isimply go to the same toggle as the link?
  • Bob O'Donnell Jan 02, 2011
    It is the carburetor side I don't know. Does the spring simply attach to the same crank on the carburetor side as the linkage does?
  • 2,926 Answers
One side connects to the engine governor linkage, the other end attaches to the throttle plate that activates the throttle opening. There should be a hole on this plate that will allow the end of the spring to connect to.
Posted on Jan 03, 2011
  • 22,219 Answers
It goes to the metal bar coming up from the cooling fan area where their is a flap on the end of this bar that acts as the govenor ,the air flow puts pressure on the flap this pulls the rod back which has the spring attached to teh throttle butterfly on the carb and pulls it back as the rpm goes up ,simple but it works
Posted on Jan 01, 2011
  • 297 Answers
On the black piece of plastic where the throttle linkabe hooks, there is a small hole for the spring on the tractor side.
Hope this helps, Matt
Posted on Jan 02, 2011
Need a throttle linkage diagram for a briggs & stratton engine model 9S502 type 0620-B1
David, This is what I found in google search for B&S carb. linkage diagram, you can also do a search because there are lots more.
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Linkage Spring replacement on Briggs Stratton Quattro 4 HP Murray Lawn...
Repairing Lawnmowers For Profit Part 61 Governor Spring Help
briggs and stratton governor linkage diagrams Google Search
briggs and stratton carburetor linkage diagrams Google Search
Jun 10, 2016 | Briggs & Stratton Garden
Cub cadet 30 inch 1450 briggs and stratton
About 625 results (0.89 seconds) Search Results
    Why wont my engine start - Briggs & Stratton
    www.briggsandstratton.com/.../why-wont-my-engine-st...
    Briggs & StrattonThe most common reason an engine will not start is due to an interruption in fuel ...(such as Briggs & Stratton carburetor cleaner to clean carburetor parts and body. ...gasoline be purchased in small quantities, not more than a 30 day supply. ... that canflood the engine, or cut the air supply enough that engine will not run.Missing: inch ‎major
    Information about the Carter, Kohler and Walbro Carburetors
    gardentractorpullingtips.com/carbfuel.htm
    Information about the Kohler Carburetor, Various Fuels and Fuel Systems. ... (Updated 5/23/15); Repairing Various Older Briggs & Stratton Carburetors. ... If used on a smaller engine, due to the larger venturi, the engine will not receive the ... which converts to 1.181 inches (30 ÷ 25.4 = 1.181"), but actually measures 1.200".
    Notes on the Troubleshooting and Repair of small Gasoline ...
    www.repairfaq.org/sam/lmfaq.htm
    May 19, 2015 - Timing; Lawn mower will not start after the blade hit an obstruction; Flywheel ... on Briggs and Stratton repair; Experience with Briggs & Stratton carburetor .... NEVER attempt to run a gasoline engine indoors. ..... For 2 stroke engines, special oil (not the usual 10W-30/40 type motor oil, nor WD40 or 3-In-One!) ...
    Briggs & Stratton - YouTube
Jan 21, 2016 | Garden
How do I refit linkages and springs and in what order on unidentified lawn mower?
Linkage & Spring replacement on a Briggs & Stratton ...
? 7:13
https://www.youtube.com/watch?v=8atnwA4D5lM
Jun 26, 2010 - Uploaded by paisteboy
In this video I replace the two spings at the linkage on the carburetor of my Murray Lawn Mower that has a ...
4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close ...
Nov 24, 2015 | Garden
How do I remove the carburetor of a Briggs & Stratton model 287707?
remove the air cleaner assembly,then unscrew the 2 threaded bolts, should be 8mm head visable once air cleaner removed. disconnect fuel pipe,choke and throttle linkeges and backlash spring
Sep 26, 2014 | Briggs & Stratton Garden
21 hp briggs and stratton motor model # 407677 type 0258 trim e1. Motor runs wide open even at idle. Already check the screws on the governor butterflies all are tight. Governor moves freely. Springs...
Its a carb problem. Here is link for the carb overhaul kit - http://www.amazon.com/BRIGGS-STRATTON-797890-KIT-CARB-OVERHAUL/dp/B005F6QHI8
Here is a good walk-through for repairs. The site seems like it has a few bugs. I can't post the direct link to the articles because the pictures don't come through for me and I don't want to give you something that isn't beneficial.
Below is the link to the main page.
http://outdoorpowerinfo.com/repairs/
The articles for your carburetor are: Briggs and Stratton V-Twin 2-Barrel Nikki Carburetor - Part 1 & 2
There are pictures. If they don't come trough try clinking the links on the main page a few times until you get the articles with pictures.
Aug 25, 2014 | Measuring Tools & Sensors
I have a Briggs & Stratton 10 HP engine, model 220707 that I could use some help with the governor spring on?.
Should see a bracket with holes in it .and a small throttle bracket that has a hook shape the spring locks on to it.
May 20, 2014 | Briggs & Stratton Briggs Stratton Intek V...
Briggs and stratton 35 classic. Need piccy of arrangement of carb/choke links and springs as think someone has changed them and mower no work. Model 9D902. Lever which may be choke, does not stay in place...
check youtube,guy on there has pics of spring set up,and still pics to follow the video.
check this name on youtube:4 HP Briggs & Stratton Quatro Motor Spring & Linkage Close Up Detail
Apr 25, 2011 | Briggs & Stratton Briggs Stratton...
Motor runs wide open when set @ slow speed
It could be that the governor spring has become disconnected or has broken on an end where it hooks onto the throttle linkage. If the spring is OK & throttle linkage is not binding it could mean the governor drive inside the engine has failed preventing the governor from operating correctly. You may need to take the engine to a mechanic to fix the problem.
Sep 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
640 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
