Question about Kenmore 65234 Bottom Freezer Refrigerator
Refrigerator doesnt cool, but freezer works. shows 5 6 7 on freezer control settings.
  • 1,772 Answers
Werwe
wer
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
4 Thumbs - Very Helpful
3 Thumbs - Helpful
rer
Posted on Dec 31, 2010
Temperature settings 1, 2, 3, 4, 5 means
refrigerator dial settings work from hot + 5 degrees (5) to real cold (1) 0 degrees and in the freezer section they work in the opposite direction (1) is cool - is minus 5 degrees and ( 5) is minus 25 degrees
those figures are example figures to show how the temperature in the units will be in relation to the dial numbers
Apr 27, 2015 | LG LSC26905TT Side by Side Refrigerator
I have a GE GSF25TGTB that has twice gotten warm enough to melt the ice in the bin and drip water all over the food in the freezer. I have checked the thermistors in test mode and #5 shows O (open). I...
Check the defrost timer/control board... it seems to be sticking in defrost...
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | GE Refrigerators
My refrigerator is not cold. the freezer has started to frost over. i have been letting it defrost for about 5 hours now. how much longer should i wait to start it up again and what do i do if defrosting...
Just wait till all the ice is gone... a hair dryer will speed things up...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
heatman101
Oct 29, 2010 | Refrigerators
The digital display resets to 0 F for BOTH the Freezer and Refrigerator after I change the temps (for eg to -4F for the freezer and 34F for the refrigerator) Also the the refrigerator and freezer are...
The OF OF display is the OFF setting, used for display purposes, so the light and controls light, but the refrigerator does not run while it is on display at a dealer. Try pushing in and holding the top two buttons on the left side of the display for about 5 seconds at the same time to get it out of the display mode. You should be able to set temps then.
Jun 20, 2010 | Samsung RFG297AARS (285 cu ft) Bottom...
Freezer works fine, fridge cool not cold.
if the freezer is freezing and the fan working in the freezer and the fan at the compressor is working and you have no frost build up on the back wall of the freezer caused from a defrost problem -then turn your controls back to the middle. one of the controls is a thermostat control and the other control is merely an air diverter from the freezer to the refrigerator. if you close this diverter down too much (by putting it on 9)it will leave most of the air in the freezer.
bottom line if the freezer is working properly and freezing good all the time then the refrigerator should be ok as well unless you have diverted most air to the freezer. allow 24 hours after you have changed the settings.
you can feel air blowing in the back of the refrigerator at the top next to the freezer and can adjust the diverter control and feel the difference it makes. most of the time the control you use is labeled freezer and if you put both controls on 9 then your freezer will be the coldest but the refrigerator won't get as much air. the thermostat control can be left at 5 or higher (this is the control that turns the refrigerator off) but leave the other control at 5
if this doesn't work you have probably got problems with your freezer also and may not know it yet.
May 26, 2010 | GE GTS22KBP Top Freezer Refrigerator
Frige and freezer are not cooling!!! Help
chances are the fan motor has quit have a tech replace it if this is not the problem it could be a sealed system issue or a defrost problem
Dec 14, 2008 | Maytag MFD2560HES Bottom Freezer French...
Touch Temp Controls
If the touch control doesn't respond then it's most likely bad. They don't normally act up, they either work or they don't.
Jan 05, 2007 | LG Bottom Freezer Refrigerator w/ Swing...
Kenmore 65234 Bottom Freezer Refrigerator Logo
79 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
