Question about Linksys Wireless-G WRT54GS Router (e125894)
What do I do after the router is reset to the factory default condition?
  • 536 Answers
You have the choice of using the installation program on the CD that came with the router or connecting to the router and then using your browser to go to:
http://192.168.1.1/
and then log in with password "admin" (no username).
Once in to the web page for the router, you'll want to set up the basic wireless and security settings.
On the basic setting page, change the SSID to something unique and change the administrator password to something other than "admin".
On the security page, enable WPA2 security and provide a passphrase to use. Make sure that you write down the passphrase and the administrator passwords for future reference.
This should get you set-up enough to know that your network is secure.
Note that after you change the SSID and the admin password, you will have to first find the new SSID and connect to it again and also supply the new administrator password.
Good Luck
Thanks for using FixYa and Happy New Year.
Posted on Dec 31, 2010
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
Can I reset my password for my WRT54G router?
Yes,
Find the hole on the unit that says "RESET", stick a pin in a... it should reset to factory default settings (i.e. the condition the router was when you purchased it).
If you need further help, reach me via phone at https://www.6ya.com/expert/jim_8aa10a90cbbc76ff
Feb 24, 2011 | Linksys Wireless-G Broadband Router
How do I reset my Linksys WRT400N Router to factory defaults
Reset There are two ways to reset the Router's
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router's web-based utility.
There should be a small hole with a red circle around it on the back of the router next to the power plug hole. Use a pin or straighten paper clip to push the tiny button.
Jan 11, 2011 | Linksys WRT400N Router
Problem with installation cd asking for password?,step 7, i've tried admin but it didn't work
Just try with putting admin it is default password or you can try to put password as password. If it is work then great otherwise you have to reset the setting .in router there is one small hole just insert any pin inside and press it all the light will flash that means it is reset to factory setting and all the setting which is saved is erase . now access the router with default ip 192.168.1.1 and do the setting according to the internet .
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Dec 29, 2010 | Linksys Wireless-G WRT54G Router
How do i reset the password to linksys wireless-g
You can reset the Linksys back to the default settings by -
Power up the Linksys, use a straighten paper clip and press the pinhole RESET button at the back of the router for 30 secs.
Open a browser and enter the configuration URL
http://192.168.1.1
The default login = admin
The default password = admin
Dec 29, 2010 | Linksys Wireless-G Broadband Router
I have WGT624 v2 used for years and in a pretty good condition. Unfortunately, it suddenly doesn't work recently. No internet connection at all. The power LED light keep blinking and the color change...
Step 1 With the unit on, place a paper clip into the hole on the back on the unit labeled Reset.
Step 2 Hold paper clip down for 10 seconds and release.
Note: Do not repower unit during this procedure.
Step 3 The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults.
Note: The factory defaults username is admin, and there is no password.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 20, 2010 | NetGear WGT624 Wireless Router
I am looking for the Security Key
Unfortunatly there is no way of accessing the router security key if you have forgotten it however you can reset your router to factory default here is how
" The Reset button is located on the right side of the product label. There are two ways to reset the Router to its factory defaults. Either press and hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen in the Router's browser-based utility The Reset button is located on the rightside of the product label. There are two ways toreset the Router to its factory defaults. Either pressand hold the Reset Button for approximately five seconds, or restore the defaults from the Administration > Factory Defaults screen inthe Router's browser-based utility" was this helpful?
Oct 05, 2010 | Cisco Linksys E1000 WirelessN Broadband...
Retrieve password
Generally, you can not retrieve a lost password from a router. You will likely be able to RESET the router to factory condition by pressing / pressing & holding a reset button on the router itself.
You should check the router documentation or manufacturer's web page to see exactly how a reset is done on your particular model router, and learn what the default username and password combination is once reset.
Please rate this replay - good luck!
Sep 07, 2010 | Computers & Internet
Wrt54gc wirless router lights keep blinking. cannot connect via wireless router, modem is ok.
which lights keep blinking ? I would do a factory reset - button on the back - hold for at least 10secs it should then reset back to the factory condition connect the modem to the wan port
quite often the default settings may work with the modem.
post back a comment and detail the status of each light on the router also the make and model of the modem and the status of each light on the modem
Mar 21, 2010 | Linksys (WRT54GC) Router
Linksys Wireless-G WRT54GS Router (e125894) Logo
50 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
