Question about Bosch Axxis WFL 2060 Front Load Washer
My Bosch 2060 Front end loader will not drain/spin
My Bosch 2060 stops at drain cycle, (will not drain) however if I manually drain the water out from the front side drain I can get to the spin cycle, I took the machine apart and cleaned the hoses in the front and still have the same problem. I would appreciate any help. Thank you
Donna
also at: bmeringdol at aol dot com
  • 1 more comment
  • April Pierrot Jul 17, 2008
    Mine is a Bosch WFG 2020. It stopped with water still in the bottom and won't rinse or drain. It comes to the END cycle with a flashing red light.
    I checked the U-bend and it seems clear... any suggestions. I manually drained it, and set the cycle and it runs again till the drain, and then stops.
  • Anonymous Mar 26, 2014
    won't stop draining cycle
    won't stop drain cycle even when empty
Get the pennies or dimes out of the accordian style black hose at the bottom of the washer. You will need to lay the washer against something so you can get in from underneath. Take a plyers and squeeze the medal clamp so the hose can slip off. I found 3 dimes that acted like washers. The machine will drain.
Posted on Jul 19, 2008
SOURCE:
Stops at drain cycle and then won't spin
does the unit start atleast? does any humming sound come from unit?
Jul 17, 2008 | Bosch Axxis WFL 2060 Front Load Washer
How do I winterize bosch front loader washing machine
Turn off the water supply to the washer, and disconnect the inlet hoses, remove the drain outlet hose and lay it down to drain any water in the hose.
Remove filter, and drain water off inside.
That should do it.
Hope this helps.
Dec 10, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Water wont drain from my front loader bosch axxis washer and no spin cycle
You can check the drain or the filter. You will have to pull it out of the space it is now to access it. Items will get stuck in the drain clogging it.
May 05, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2061 motor starts running and then stops
Hi ! I have problem with my Bosch Washer wfl 2061 .. It was running till stoped to
realease drain water out... But no drain water come out.. I have checked drain water host... Nothing thaere.. Water was still in the drum Tank... Whoever knows this problem , please kindly suggest or help me to do something.. Thanks.. Peace [email protected] , [email protected]
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch axxis door won't open
michele99, So when you put it on drain, do you here the machine trying to drain the water? After it finishes draining, (you have to wait a few minutes, it should then have a blinking light
on the Finished/Door locked light.
Are you waiting for it to finish?
May 08, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Drum Does Not Turn
The belt that turns the drum has broken.
Mar 11, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WLF 2260
suspect you have filter blocked or a foreign object in pump. put drain hose as low as possible in a bowl and drain as much water as you can undo filter but be carefull, water will come out in considerable quantities. clean filter check nothing stuck in pump impellor
Jun 14, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
How do I know when it's done?
TAKE NOTE IF THE WATER HAS DRAINED OUT. RE START THE CYCLE ONCE MORE AND IF IT HAPPENS AGAIN, THE TIMER CONTROL IS DEFECTIVE.
Jan 10, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Axxis WFL 2060 Front Load Washer Logo
786 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
jimorris77
Dw Wooten
Dw Wooten
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
